First post, by tabm0de
So i got myself a "compaq presario 7220" and i really cant find any manual and having a hard time accessing bios, i have tried with pressing F1 and F10 but nothing helps, keyboard is working so thats not a problem, even tried a orignal compaq keyboard with same problem.
    43.01 KiB
naa, nothing yet...
Reply 1 of 4, by ODwilly
Have you tried delete, f2, f8, and the whole menagerie of f keys OEMs like to use? The only other thing I could thing of would be if the hdd had the bios on it, but that machine looks fairly new to have that issue.
Reply 2 of 4, by gerwin
This Dutch article suggests that this BIOS menu requires data to be present on a special Harddisk partition?
https://gathering.tweakers.net/forum/list_messages/435717
Reply 3 of 4, by Taylor7108
Hmmm have you tried replacing the 3V battery on the board? This is a cheap way to troubleshoot and is probably necessary anyway, at this point.
Hope this helps!
Current Build: 486 DX2 66 / 16MB RAM / 2GB CF / CL5428 VLB 1MB / Aztech 2316 Sound / DOS 6.22
Reply 4 of 4, by tabm0de
Thanks for the reply's but it is as gerwin sausage, it needs program on disk the old user formatted the disk hehe but I found the "compaq f10 setup" floppy image 😀
naa, nothing yet...
