First post, by smevans526
Can a voodoo1 (something like the Diamond Monster 3D 3dfx Voodoo1 4MB PCI) be installed/operate on a pure DOS system? Be aware that I am not too familiar with Voodoo. Every guide (and driver installation) I find involves installation under Windows 95 and then booting into DOS. But the system I'm considering would be DOS only -- maybe windows 3.x as well...
Reply 1 of 9, by clueless1
It can be done. Here's some reading for you:
Revised list of Voodoo games for DOS.
Voodoo 1 in only MS DOS Environment
Good luck! I'm sure others will chime in with more...
Reply 2 of 9, by meljor
Yes, for glide dos games you don't even need a driver. Just the right .ovl file for the card in the game directory is enough. Most glide supporting games already have the right files so just install the game in dos and off you go... sometimes games came out before the voodoo and got a 3dfx patch later that needs to be installed to support 3dfx cards.
Reply 3 of 9, by smevans526
I think a better way to ask is will it work for *all* DOS games. That above mentioned thread discusses MDK as needing Windows and the .dll.
BLOOD looks to be another example; I got lost in the subsequent technical lingo, though. So maybe it would work on a DOS only system. GTA looks to be the only game I'm interested in that would work under pure DOS.
If what I wrote is flawed, let me know
Reply 4 of 9, by Gamecollector
ANY 3dfx card can be used in pure DOS.
You need the card and glide2x.ovl in any %path% directory.
Glide2x.ovl is included in Win9x drivers. Use last retail drivers for the specific card and pkunzip.
The compatibility isn't perfect. As the example - Voodoo2 + fast CPU = statically linked games not work.
Reply 5 of 9, by Imperious
A 3dfx Voodoo 1 and 2 can not be used in any system as the only video card. It is a 3d card only, You need a 2d card for dos/windows and a passthrough
cable going between the 2d card and the voodoo card.
PC's from XT 8088, 486, Pentium MMX, K6, Athlon, P3, P4, 775, to current Ryzen 2600.
Reply 6 of 9, by CHiLL72
True, but that was not the question here I believe.
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 7 of 9, by derSammler
For all DOS games that have Glide support, yes. There are no compatibility issues with a Voodoo1. Note, however, that the number of DOS games with Glide support isn't that high.
Reply 8 of 9, by smevans526
???? Um... Thanks?
If the game has a DOS executable, and is known to have glide support, will the game operate with glide on DOS?
We'll keep it simple with the Voodoo1. There is a thread concerning Voodoo2 compatibility (Voodoo 2 DOS Glide compatibility matrix), and yes, it seems to mostly work.
I'll keep focused on MDK, though. This game is a DOS/Win95 game -- but my understanding is that glide will only operate with the Windows version. Am I correct?
Sometimes claims of glide compatibility are misleading. There is much talk of a glide version of Dungeon Keeper. The gold version even has a 3dfx logo on the box. But it is just D3D, which can then coincidentally talk to a Voodoo card.
