First post, by Yuuker
I recently got a pretty good deal on a 486-mobo, cpu an ram combo. Came with 4mb of ram (guess it could a been worse) but whats confusing me is its type.
Its 32pin, and i only really see (and usually hear about) 30 or 72pin when i do searches for kits online.
Is 32pin some un-normal standard? I'm *relatively* new to retro-builds, can i assume its backwards comparable with the more common 30pin ram or, am i a little outa-luck on an upgrade here?
Thanks! 😀
Reply 1 of 3, by lazibayer
Could you please take some pictures of the RAM and mobo? I only know old macs use 32pin SIMMs.
Reply 2 of 3, by yawetaG
Mac PC upgrade board? Basically that's a PC on a expansion board that you can plug into a Mac, and it would be useless without the its special software or Mac (obviously).
Other options are some proprietary industrial solution that happens to use a 486 processor, or maybe a NEC PC-98 or compatible system (which do not work with conventional MS-DOS or Windows, you need a special version because the hardware architecture is entirely different).
Reply 3 of 3, by luckybob
it is really 30-pin. I have some simms with an extra pin on each end. At least on mine, they aren't even connected.
