First post, by tangles
- Newbie
Hi all,
I have a 486 machine (pics below 😊) which I'm using type 47 to set up a 128mb CF card with, as the motherboard does not support auto-detect. I can successfully format the CF card using fdisk/format (while booted from floppy 6.22 boot disk) and read/write to it in DOS, but then when connecting it to my Win XP machine via a USB card reader, it insists I need to format it before I can use it.
As I have to manually specify the Cylinders, Heads, and Sectors, could it be that I have the values wrong?
I've tried to google this but can only really find instances of people not getting the CF to work under DOS at all, which isn't my issue. I don't know much about the filesystems of the era, is it actually possible to read a 6.22 formatted disk under winxp?
Thanks,
Tangles
PS. Pics of the old beast!
