First post, by Tmp2k
So attempt 1 involved an 865G chipset mobo and the best AGP card with Win98 support - Radeon 9800 Pro. This was OK, but then I discovered the ASRock xxxdual-xxx boards and their AGP+PCIe options. But I can't get the VIA-880Pro chipset working properly under Win9x on that board. This was attempt 2.
So I'm back with the 865G chipset and a new mobo, a new plan (and some new requirements). So let me know what you think of this plan, and if the spec could be improved...
MOBO: GA-8I865GME-775-RH r6.6 - 775 / i865G / 2GB DDR / SATA / ALC 655 Sound
CPU: Core 2 Duo - E8600 3.3GHz - Or if I cant' find one an E8500 3.1GHz
RAM: 2GB
GPU for Win2K onwards: AGP Radeon HD 3870 (should be an AGP version but can't find any) or HD3850 (found several AGP versions for sale)
GPU for Win3.x and Win9x: PCI Riva TnT2 and/or some version of Voodoo PCI
Sound: Ensonic PCI 3000 for DOS/Win3.x (maybe Win9x if I cant get the ALC655 working)
Onboard ALC655 as I need WaveRT support in later versions of windows. The 655 should support it but I've not tried yet.
Are there any better GPU choices? I need the best PCI GPU with Win3.x support and this will also be used for Win9x gaming. Then I need the best AGP GPU full stop.
Reply 1 of 2, by Srandista
Sorry, but I have to react. Best AGP card for Win98 definitely isn't 9800 Pro. I'm not much into Nvidia cards, so I can't speak for them, but even for ATI, you can use much more powerful cards in Win98. Specifically X850 XT PE, which is supported by 6.2 driver.
Reply 2 of 2, by Tmp2k
That didn't come up when I posted about it at the time, but it's a moot point anyway as I'm using PCI for win98 now and agp for 2K and newer.
