First post, by BLockOUT
I have issues with my good old sound blaster pro 2 model number CT1690. I have tried the card with 3 different motherboards already and i dont know how to fix it.
it should not need any drivers at all. Altho i did install some SB16 pro 2.0 install disks on one machine and it always said that there was no card on addres 220.
I HAVE COMPLETELY RECAPPED THE CARD WITH NEW CAPACITORS AND IT DID NOT FIX IT.
1) Aopen Pentium3 motherboard: The card seems to work SOMETIMES. I run a game and sometimes it Detects the card and sometimes it does not detect. It is a lottery, but at least works. with Wolf3d it works but after some minutes the game just crashes.
2) With a pcchips M919 motherboard: The card never worked, and games do not detect it.
3) With FIC 486-PIO3 motherboard : the card never worked and games do not detect it.
i have touched every bios setting, leaving irq resources to PCI, then leaving to ISA only, changing jumpers on the card, tried everything.
There are no signs of broken traces. card is in good shape.
What other things could i try? maybe replacing the voltage regulator 7809 that is on the card ?
i dont want to give up, since it is such a good card and hard to find
this is the card:
