Dark Seed 1 Problem
First post, by Devilot
When I run it with the .exe, it runs fine... except that it freezes on a black screen after certain important scenes, like Mike Dawson going to bed, or answering the door to recieve the package. At first, I thought it was just taking a while, like the game starting up, but it seems to be genuinely frozen.
Note: Deleted an unnecessary comment.
EDIT: Sorry if this problem has already been solved before. Searching for Darkseed didn't come up with anything similar, and searching for "Dark Seed" got too many irrelevant results to even hope to find if there was a solution
EDIT: Sorry about not including it the first time: Here's what of the help guidelines request for information I can get easily--I will add more as I find it:
Processor type: AMD Athlon XP. Can't remember the number it used, but it's got a clock speed of 1.66 GHz.
Amount and Type of RAM: 512 Megs DDR, don't know what speed.
Video Card: ATI Radeon 9600 XT 128 Meg.
Sound Card: Sound Blaster Audigy 2 ZS Platinum
Operating System: Windows XP
Sound Mode Used: Sound Blaster emulation
Version of Emulator: DOSBox 0.61
Steps taken to fix problem: Tried tweaking CPU cycles and frame skip to rush through it if it was slowdown rather than freezing.
Reply 1 of 7, by dhruba.bandopadhyay
0.65 & 0.70 is fine with Mike answering the door. I haven't gone to bed yet as am stuck in the library with a black screen when librarian shows me a book.
Please sign the Blood source code release petition
Reply 2 of 7, by SKARDAVNELNATE
I was able to play Darkseed all the way through. Both the 3.5 and CD version. This was with 0.65. Haven't played it recently.
Reply 4 of 7, by VisitntX
I finished the game in 0.65 without problems.
You should download the latest version of dosbox to run that game (i guess that with 0.63 the game runs fine too).
Reply 6 of 7, by VisitntX
smartdrv is a tsr program that active caches for make the hdd faster, is not needed for videos or other things and dosbox surely don't need that MS-DOS program to run.
Reply 7 of 7, by SKARDAVNELNATE
Was 3.5 the latest update?
No. 3.5 was media type. As in 3.5" disks. Which puts my mention of the CD version into context.
