First post, by appiah4
- l33t++
I'm currently installing Windows 95 on a 4GB Compact Flash (as the PC I am using has a BIOS limitation with detecting drives beyond 4GB apparently, and the <4GB drives I have are slow and loud..) and I was wondering if I need to do anything to make sure the OS inflicts less wear and tear on the Compact Flash, particularly because of the pagefile and swap behavior..
