First post, by pan069
- Oldbie
So, I got this Compact Flash to IDE (presumable bootable) and I'm just trying this out. So, I checked out the instructions on the PCB and it refers to the usual jumper pin 1 etc. However, the 3 pin headers have triangles denoting one side of the pin layout. Now, I assume that this triangle refers to pin 1? But, on the other hand, triangle, 3, does it mean that the triangle is at pin 3? Why would you not just label it "1" instead of a triangle? Very weird, not to mention confusing...
So, just to double check, the triangle is pin 1, correct?
Also, I'm attaching this to a floppy molex and there is a jumper setting to choose +5v or +3.3. I assume this needs to be +5v?
