Pariah
First post, by lowenz
Question about Pariah, playing with "Effects" (shaders) on (and of course dgVoodoo2).
Why in the video cutscene (XBox one?) the communication tower level "big blue light core" (?) has a powerful bloom and in game it's not there?
You can see the bloom applied to the "halo" but not to the core.
Shading issue or cutted feature in the PC release?
Reply 1 of 16, by lowenz
It seems cutted in the XBox release too!
It's from a previous version of the game? You can see it in the.....loading screens 🤣!
Reply 2 of 16, by lowenz
Always in the tower (power generators section below) you can see this "depth fogging" problem playing with the shaders enabled (no issues disabling them) and walking around.
It's related only to some surfaces/textures/objects!
Reply 3 of 16, by lowenz
You can see it very well here (and it's not related to the MSAA, enabled or disabled the issue is there)
D3D8 engine of course.
It's not related to HasNVidiaTexM32Tex in the config file, that variable doens't make any difference with dgVoodoo2 (set to 1 is needed using standard or tweaked MS D3D8 on recent GPUs).
Reply 4 of 16, by lowenz
No, it was from an old version you can see in the.....loading screens 🤣
More important the fogging bug!
Reply 5 of 16, by lowenz
Dege wrote:
AFAIR I didn't debug this game so I can't say much about its rendering technique.
I remember you've tested it to fix z-fighting on some surfaces and cubemap issues about the lighting on the weapons skin ('cause I've already ask for this 😁 but now I'm testing with the FX - bloom & motion blur - shaders on)
Reply 6 of 16, by lowenz
Dege wrote:
And what about the XBox version? Is it present there as well? 😀
Ah, you mean the depth fogging? The fogging bug is NOT present in the PC version with MS D3D8.dll (standard or UCyborg tweaked one to get back the VSync).
It's dgVoodoo2 related.
Reply 7 of 16, by Dege
lowenz wrote:
You can see it very well here (and it's not related to the MSAA, enabled or disabled the issue is there) D3D8 engine of course. […]
Which level is it? I think I never get there. 😁
I only have a savegame, spawning me in the forest (2nd level).
Reply 8 of 16, by lowenz
Communication Tower sublevel, to power up the generators.
It's at the beginning of the sublevel, after the first ladder.
Take a look around and go at the dead end of the corridor.
Reply 9 of 16, by lowenz
I can of course provide you the save game checkpoint!
Reply 10 of 16, by Dege
That'd be cool, thanks! Could you attach it here?
Reply 12 of 16, by Dege
Thanks! I've just fixed it. I remember somebody reported very similar fogging bug in FFXI. I hope it'll fix that as well.
Reply 13 of 16, by lowenz
Just how can you be so talented? 😁 You're incredible, man!
Having HasNVidiaTexM32Tex enabled is needed using dgVoodoo or not?
Setting it to "1" (like using MS D3D8) can create some problems?
Reply 14 of 16, by Dege
Thanks, but it's not about talent. I debugged tons of games in the recent years, I have my established tools and methods for debugging, experience for what to guess and look for, and some bugs prove to be easy to fix. (On the other hand, there are very hard ones, almost impossible to debug.)
HasNVidiaTexM32Tex: I didn't yet look at what it changes.
Reply 15 of 16, by Dege
HasNVidiaTexM32Tex: I don't know what this option controls. Suggested by the name, I guessed it's the presence of the texm3x2tex instruction in the shaders. But it's all for the same what I set it to (0 or 1), the game creates shaders with texm3x2tex's either way.
Reply 16 of 16, by lowenz
With MS D3D8 and modern hardware+drivers if you do NOT enable that option you got perfect bla*N*k frames using the shader FX (Bloom, Motion Blur)
