First post, by Electronicguitar
Having installed VDM Sound XP pro SP2 is not booting anymore. Deinstalling VDM does not help, only deleting everything related to vdm sound in the registry helps - and that the security center is complaining of not having installed firewall and virusscanner - this problem was meantioned earlier.
Not beeing able to have a proper installation of vdm sounds I can't use the suggested way and leave VDM on the computer
(which is bad because I can't play Ultima 1 with sound either)
Someone having an idea?
Thanks Electronicguitar
