First post, by Bondi
So I finally got my IBM 3D Sound card. But it has no dongle.
I'm 99% sure that it uses the standard Hirose (HRS) 25 pin connector.
Model ## NX30TA-25PAA + NX-25T-CV
All measurements match at least. Here is original pdf with full details.
The attachment NX.pdf is no longer available
I'm about to receive the connectors, and will be able to confirm if they fit.
In the meanwhile I would like to ask if:
- anyone happen to have the pinout of the audio cable?
- or could anyone, who has the original cable, determine the 3 audio out pins with a tester?
Any help with this will be highly appreciated!!
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 1 of 14, by Kahenraz
I would be happy to help with this but I do not have an oscilloscope, which I think might be needed in this case to visualize the output by a fine-pitch probe.
I checked with both Digikey and Mouser. This part isn't normally stocked and has to be special ordered with an (unknown) minimum quantity. I submitted a request for a quote with Digikey but I would expect the minimum to be significant as they would have to setup and tool for it specifically.
https://www.mouser.com/ProductDetail/Hirose-C … TiBCdSCwA%3D%3D
Note that "availability" is "Non-Stocked, Call for Quote".
Reply 3 of 14, by Kahenraz
See attached images for reference.
The HRS logo appears "up" when the connector is inserted into the pcmcia card, aligned with the sticker that shows the product name and IBM logo.
The dongle has two stereo connectors, one blue, one black. I don't recall which one is the microphone and which is for audio out so I will refer to them by their color.
The pinout is as follows, counting from the rightmost pin as pin 1 when looking at the pins of the male connector with the HRS logo facing up.
Black female 3.5mm:
Pin 3 (ring)
Pin 4 (sleeve)
Pin 5 (tip)
Blue female 3.5mm:
Pin 7 (ring)
Pin 8 (sleeve)
Pin 9 (tip)
I'm using the terms sleeve, ring, and tip to eliminate any ambiguity as to how to wire this up.
Reply 4 of 14, by Kahenraz
Adding this additional picture to make sure that which pin I'm referring to as "pin 1" is clear.
The attachment 2020-02-19.jpg is no longer available
Tested using a cable I made. Each part of the 3.5mm male end was checked for identification and continuity.
The attachment IMG_20200219_155801.jpg is no longer available
Reply 6 of 14, by Kahenraz
Please share your experience when you get your parts from DigiKey.
I'm very curious as to what they will send you as the OEM connector I have is plastic-welded together.
Reply 9 of 14, by Kahenraz
Oh, wow. That's a really nicely made connector for soldering. I was wondering how it would fit together, as the original IBM cable doesn't come apart.
Reply 10 of 14, by Benedikt
Soldering? Aren't those insulation-displacement contacts that you simply push into your insulated wires?
Reply 11 of 14, by Bondi
And...it's working 😀
Kahenraz, thank you so much for yor help! Audio out was the first(black) jack, BTW.
Benedikt, yes, that's right, no soldeirng. Insulated wires work just fine, if they are thin enough. In my case I had to strip them.
Reply 13 of 14, by amang
Thanks for showing us this information. How thick are your insulated wires? Also, what's the part near the end of the audio socket called?
Reply 14 of 14, by Bondi
amang wrote on 2020-06-27, 01:50:
I'm glad it was useful. My wires are 0.8 mm thick. That part is a ferrite bead https://en.wikipedia.org/wiki/Ferrite_bead
