First post, by aha2940
Hi guys
I have a 1995 IBM 360CE laptop. It works well, except for the battery which does not hold charge at all. Anyway, I want to replace the original HDD (340MB, currently working with no issues) with a 500MB CF card. I already got the adapter and the CF card, tested them in another PC, they work well. The problem is, that the laptop will not boot when I replace the HDD with the adapter+CF card combo. Checking with more detail, I see the HDD is a regular one inside some type of "caddy" which connects not only the usual 44 pins of the HDD but also the additional 4 jumpers on the far right (see pic). from my googling (https://stason.org/TULARC/pc/hard-drives-hdd/ … -ATA2-FAST.html), these pins are used to determine the master/slave/cable select settings of the drive, however since the CF adapter does not have these pins, I guess that's why the laptop fails to boot with it. I am attaching some pics of the PC, the original HDD inside the caddy and the way the adapter connects to the caddy (missing the above-mentioned pins). Any idea what should I connect there to make the drive recognized by the laptop?
Thanks and sorry about the huge post.
    519.72 KiB
    CF adapter to caddy connection
    669.4 KiB
    HDD to caddy connection
    525.33 KiB
    laptop HDD without caddy
    628.13 KiB
    laptop HDD (caddy) disassembled
    601.01 KiB
    laptop HDD (caddy) detail
Reply 1 of 2, by Bondi
I've read somewhere that one of the wires/lines on the ribbon cable has to be cut in order a CF is seen by BIOS. But I don't remember the details.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 2 of 2, by aha2940
Fixed. I switched the master/slave jumper on the adapter (which AFAIK was always on master, but it's not clearly labeled) and it was detected without a problem. I installed DOS 6.22 on the CF card without any issues.
Thanks!
