First post, by Tymo486DX2
I am looking for any manual of that board.
I have found picture of oryginal manual
Juko ST
Route 66 MHz😎
Reply 1 of 13, by Tymo486DX2
I am looking for description of ASIC chip NEC manufactirer.
NEC ASIC Japan 567 8838KK???
I can't see it!
Maybe somebody have it or know it.
Some versions of that motherbord have VDL ASIC 500.
Route 66 MHz😎
Reply 3 of 13, by Grzyb
There's also something in TH99:
http://www.uncreativelabs.de/th99/m/A-B/32279.htm
http://www.uncreativelabs.de/th99/m/I-L/33437.htm
The chipset seems to be Tamarack TD3300A:
1.99 MiB
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 4 of 13, by Tymo486DX2
It is not equal. You linked to UX torbo, clone of Juko ST.
I have got it.
I am still looking for manual from 1st photo.oryginal Juko ST much more
heavy then lightly UX turbo manual.
Try to look once more time very carefully at first photo of this topic.
Route 66 MHz😎
Reply 5 of 13, by jesolo
Tymo486DX2 wrote on 2020-07-16, 11:00:
It is not equal. You linked to UX torbo, clone of Juko ST. I have got it. I am still looking for manual from 1st photo.oryginal […]
I have got it.
The UX Turbo manual is already 12 pages. What more are you looking for not already mentioned in this manual?
Reply 6 of 13, by kalohimal
I have the exact same board, which I bought new in 1990. It is a Unique UX Turbo. The manual is the same as the one linked above.
jesolo also has another thread where the utility disk is available.
1.85 MiB
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 7 of 13, by jesolo
kalohimal wrote on 2020-07-16, 14:15:
I noticed that you also have a math co-processor on your motherboard. What is your math co-processor's speed rsting?
Since the CPU runs at 12 MHz, I didn't want to insert a math co-processor that could potentially be overclocked. As far as I'm aware they didn't make math co-processors faster than 10 MHz, but I'm speaking under correction.
It's possible that, on this board, the math co-processor runs asynchronously to the CPU, but I haven't investigated this further.
Reply 8 of 13, by kalohimal
It's a C8087-3 which is 5MHz. You're right about the FPU running at the same clock speed as the CPU (both of their clock pins are connected), so yeah it won't work in turbo. It was so long ago I could hardly remember what happened. It was probably inserted many years after the board was put into storage, after a friend gave it to me. I could not afford one when the computer was new (was still a college student back then).
Reply 9 of 13, by jesolo
kalohimal wrote on 2020-07-16, 16:47:
It's good you kept your motherboard - I recently went a bit overboard with my motherboard.
Installed in a case with an 8-bit VGA card and an XT-IDE adapter with a 32 MB CF card 😊. A very nice DOS 3.3 PC.
Reply 11 of 13, by st31276a
Just a quick stupid question if I may? I just dug one of these out of an attic. The manual does not say explicitly, but I assume this board requires an XT type unidirectional keyboard? Being a later clone with its keyboard controller integrated into the chipset makes me wonder.
Reply 12 of 13, by Grzyb
st31276a wrote on 2023-12-11, 10:46:
Yes, XT keyboard.
