mouse drivers
First post, by phinix
I just installed DOS and it doesn't have mouse.com
Where can I find some mouse drivers?
I remember back in 90s using files like smouse etc
Where can I get a driver?
Reply 1 of 18, by Grzyb
This one should cover most mice:
ftp://ftp.elf.stuba.sk/pub/pc/utilmisc/ctmous19.zip
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 4 of 18, by Jo22
If CuteyMouse fails, you can also try these period-correct drivers :
Re: CuteMouse not working properly
Re: How do you get a serial mouse working
Reply 5 of 18, by phinix
cyclone3d wrote on 2020-08-29, 23:58:
ctmouse
Pretty much the smallest footprint mouse driver available.
Should I run it under DOS?
Does it edit my autoexec/config.sys so its there when rebooted?
Or do I always need to run this exe when I want mouse in DOS?
Reply 6 of 18, by debs3759
Ideally you would add it to autoexec.bat so it runs on each boot.
Reply 7 of 18, by phinix
I added etc, ran it, cursor show up but my mouse is not responding.
I wonder if its faulty mouse.
I have IBM ps/2 mouse plugged via ps/2-Serial adapter to serial port.
Reply 8 of 18, by phinix
I tried pmouse, also doesn't work.
Reply 9 of 18, by Grzyb
Are you sure that PS/2 mouse is serial-compatible?
Not all PS/2 mice can be used with such adapter, and I think some may even get damaged - PS/2 is 5 Volt, serial is 12 Volt...
Reply 10 of 18, by Jo22
I second that. PS/2 mice have to actively support the other modes. Most adapters are just mechanical adapters.
Modern optical PS/2 mice usually support PS/2 and USB, while classic PS/2 mice support PS/2 and RS-232.
Very old mice from the PS/2 era may support PS/2 only.
Modern USB mice, by comparison, support USB only or USB+PS/2, but never serial.
Old serial mice may or may not PS/2 mode. Depends if they are actually PS/2 mice with a serial chord or not, I think.
Reply 11 of 18, by phinix
Hmmm... I don't know, need to search for it...
It is IBM 33G5430 mouse.
I have Asus P5A-B motherboard, also have USB/MIR card, but only with USB sockets, no PS/2.
Is there a way to add PS/2 socket to this board?
Reply 12 of 18, by Jo22
phinix wrote on 2020-08-31, 08:39:
Hi, according to this site, "ps2mouse.zip" is the original driver for DOS:
http://greyghost.mooo.com/pccbbs/options/ps2mouse.zip
Not sure if it supports the serial port, though. It seems to be intended for the IBM PS/2 line.
Edit:
I'm not sure, sorry. However, you can also go the other way round.
There are serial mice emulators. You plug a PS/2 or USB mouse in and connect the emulator to the old PC's serial port.
Example: https://hackaday.com/2017/10/09/a-converter-y … o-serial-mouse/
Edit: Another one -> https://trolsoft.ru/en/sch/mouse-ps2-to-serial
Reply 13 of 18, by Law212
When I installed Ctmouse , my mouse stopped working in windows.... Trying to find a mouse driver . running windows 95 on a 486 DX2-66
Reply 14 of 18, by Caluser2000
Law212 wrote on 2021-01-25, 00:27:
What mouse type did windows 95 indicate?
Reply 15 of 18, by Cyberdyne
Most compatible is Microsoft Mouse driver Version 8.20. Older ones are not compatible with Windows 3.1x and newer. And that 9.01 version does not bring anything new to the table, only more memory hog.
Reply 16 of 18, by Jo22
MS Mouse 9 apparently fixed that slowness issue.
Re: Moving Mouse dramatically slows down CPU
Edit: Small edit.
Reply 17 of 18, by Law212
Caluser2000 wrote on 2021-01-25, 04:29:
I'm not sure what happened but its working fine now.... No idea what happened.
Reply 18 of 18, by ve2vdi
phinix wrote on 2020-08-29, 19:58:
I just installed DOS and it doesn't have mouse.com Where can I find some mouse drivers? I remember back in 90s using files like […]
http://greyghost.mooo.com/pccbbs/ps1/mouse.com
