First post, by s.mouse
Hey,
Thought I would share my experience of testing my Asus VL/I-486SVGOX4 with an AMD 5x86 133 and 30 pin simms. This board very similar to the VL/I-486SV2GOX4 but features 30 pin simm slots which I think is pretty cool. I was curious to test if using 30 pin ram performed any differently to 72pin and if the same timings could be achieved. The board has 2 x VLB slots, no integrated I/O, is based on the SIS 471 chipset and has a PS/2 mouse port header. My board is the X4 version which has circuitry for 3.3 volt CPUs
My board is an older revision 1.2, I couldn't find jumper pin information anywhere online, Revision 1.5 has extra rows of jumper pins and I couldn't find any patterns when comparing which jumpers might correlate to what. So it was just trial and error. I managed to get it all up and going and system has been stable so far.
I can confirm VL/I-486SV2GOX4 bios versions work on this model and include support for the amd 5x86 133
I couldn't find any other threads where this board was paired with the 5x86 133. Turns out the board preforms quite well as per attached photo quake returned a result of 14.3 FPS and doom 1429 realteks.
Tests were performed with a VLB ARK 1000 VL video card and 16mb of 30 pin ram. I found Fastest bios settings were not a problem with either 72pin or the 30 pin ram.
Enjoy 😀
1.99 MiB
1.26 MiB
1.26 MiB
1.64 MiB
1.22 MiB
    1.56 MiB
Reply 2 of 3, by alvaro84
In a different mothrboard (with opti895 chipset) I found that 33MHz FSB at the tightest timings is not too far fetched, not even with 30-pin SIMMs.. The dividing parameter set was 40MHz/fastest. Hardly any 4x4MiB sets could do a problem-free Goldmemory at this height, but strangely it seemed much easier for 4x1MiB sets.
But a DX4-capable VLB board deserves its 16MiB, doesn't it? I may run into games or demos with it that don't find 4MiB enough. I also like to use disk caching sometimes.
As for 72-pin modules, I found it easier to pick 40MHz/fastest capable. But I had no such luck at 50MHz/fastest, let alone the cache chips that could do it. I don't have a single set for that speed.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 3 of 3, by Bruno128
Hi there s.mouse and thanks for the contribution.
I've got an Asus VL/I-486SVGOX4 rev. 1.5 and my aim is the same as yours to run AMD 5x86-133 on it.
I see that you've managed to run BIOS ver. 0402 Beta (11/19/97-sis-85c471-i486sv2gc-00) while I originally had an older ver. 0303 (10/11/94-SIS-85C471-I486SV2G-00) installed.
Flashed a 27C512 CDIP-28 with a BIOS ver. 0402 (11/03/95-SIS-85C471-I486SV2G-00), replaced it while cleaning stuff with alchohol and set the jumpers accordingly:
  • JP7: 1-2
  • JP8: 1-2
  • JP18: 1-2, 5-6
  • JP19: 1-2, 5-6
  • JP20: 1-2
  • JP21: 1-2, 3-4, 5-6
  • JP22: 1-2
  • JP23: 3-4 (important one, info differs across some manuals)
  • JP24: 1-2, 4-5
  • JP25: 2-3
  • JP26: 2-3
  • JP27: 2-3
Please note that several revisions of the board has a different number for basically the same jumpers that confused me at first.
edited: updated pics and info
Now playing: Red Faction on 2003 Acrylic build
SBEMU compatibility reports
