Sphere478 wrote on 2021-02-16, 03:21:I'm trying to play mist and stratosphere but the only sound card I have while I'm waiting for the other one won't work under the […]
imi wrote on 2021-02-16, 02:48:what exactly are you trying to do?
do you have on board audio by any chance?
what do you mean "transmit it over the network"? su […]
what do you mean "transmit it over the network"? sure you can stream or copy audio via the network to play back on your other PC but I don't know how that would help you with whatever you're doing?
and yes there are ways to make the PC speaker play audio in Win9x but still... what exactly do you want to do?
I'm trying to play mist and stratosphere but the only sound card I have while I'm waiting for the other one won't work under the OS I'm trying to run the games in. I was wondering if there was a way to get it to play over the pc speaker while I wait for the sound card that I will use.
darry wrote on 2021-02-16, 02:55:
Sphere478 wrote on 2021-02-16, 02:42:
I have a k6 computer that I am running windows ME on at the moment all I have to play sound is a audigy SE and I'm told that 9x won't support it. I have a audigy 2 zs coming from my friend but he hasn't mailed it yet and I don't know when it will arrive is there a way I can get sound out of the pc speaker or something? or maybe transmit it over the network to my speakers on my windows 10 computer that shares the same setup. the other option is I just wait for the zs I don't want to buy another sound card just to use for a few weeks. so if there isn't a way I'll just live without sound.
In a pinch, you should be able to use any generic class compliant USB audio device . See https://docs.microsoft.com/en-us/windows-hard … --usbaudio-sys- for features and limitations .
that occurred to me to try usb sound but I don't have any at my disposal.
If you type "usb sound" into Amazon, you can probably find something with a 4 star or higher rating that will likely ship to your location (at least if you are in North America) for less than 20 $US, including shipping .
EDIT: And receive it within 48 hours, if you are lucky . Alternatively, any local computer shop should have some. Also, I would not expect fantastic audio quality at those prices . If you want something with better quality, a Fiio E10K is great but significantly more expensive (about 76 $US).
EDIT2 : Oh, and if you try a USB sound device under Windows and find the volume abnormally low, run the patches below once the USB device is connected and its drivers are installed . Source ( http://www.mdgx.com/web.htm ) .
Also, you may notice, that the volume mixer icon does not show with a USB audio device set as default (at least it did not for me). You can manually invoke the mixer by running sndvol32.exe , which will let you adjust levels .
P.S. There is a similar set of fixes for Windows ME .
Microsoft Windows 98 SE WDM/USB Audio Driver WDMAUD.DRV 4.10.2223, KMIXER.SYS 4.10.2223, PORTCLS.SYS 4.10.2223, SBEMUL.SYS 4.10.2223, SYSAUDIO.SYS 4.10.2223, USBAUDIO.SYS 4.10.2224 + WDMAUD.SYS 4.10.2226 Fix:
Direct download [374 KB, English].
MUST install current Drivers for your particular WDM/USB Audio device BEFORE installing this Fix!
Example:
Crystal sound cards require Driver 6.13.10.4140. OLDer ones do NOT work!
The attachment win98_usb_audio_1_269601USA8.exe is no longer available
Microsoft Windows 98 SE PortCls Devices PORTCLS.SYS 4.10.2224 Fix:
Direct download [210 KB, English].
MUST install WDM/USB Audio Driver Fix above FIRST!
The attachment win98_usb_audio_2_321467usa8.exe is no longer available
EDIT3 : Corrected references .
