Lord of the Rings
First post, by dnewhous
Well, now, first off I can say that I think the reason the Soundblaster music sounds quite limited on this game is that it is original Soundblaster music.
Now, the reason I am posting is that I have the Interplay CD. On this version once Lobelia hits Frodo with an umbrella the game freezes up. The sound effect is better than I heard before. I am using DOSBox - X.
Daniel L Newhouse
Reply 1 of 41, by Jorpho
dnewhous wrote on 2021-03-03, 03:56:
I have no idea why you are posting. Why are you trying to run this game in DOSBox-X? Why are you posting this in the DOS subforum?
Reply 2 of 41, by dnewhous
DOSBox -X is better. It is a DOS game. I could also point out that the file 10th.bat does not work. The collection itself is Windows 95 compatible. I had to manually install the games by copying the games subdirectory to my dosgames subdirectory.
Daniel L Newhouse
Reply 3 of 41, by Jorpho
dnewhous wrote on 2021-03-03, 05:16:
DOSBox-X has specific uses. In many cases it is no better than standard DOSBox.
Are you expecting anyone here to know what that means? Are you referring to an Interplay 10th anniversary anthology? Are we supposed to guess? Wouldn't it be easier to help you if you provided more details?
If the game is incorrectly installed, then that might explain why it is freezing.
Reply 4 of 41, by dnewhous
Jorpho wrote on 2021-03-03, 05:24:
It's the 10th anniversary anthology. I swear the game is correctly installed. Save game works.
Daniel L Newhouse
Reply 5 of 41, by Jorpho
dnewhous wrote on 2021-03-03, 05:27:
If it was correctly installed, then why would you be having a problem? What are you expecting here?
What do you mean when you say "the file 10th.bat does not work"? How did you try to get it to work?
Reply 6 of 41, by dnewhous
Jorpho wrote on 2021-03-03, 05:34:
Bug fixes. I got one before.
mount E E:\
cd E:\
10th.bat
Odd error message.
Daniel L Newhouse
Reply 7 of 41, by Jorpho
dnewhous wrote on 2021-03-03, 05:36:
Bug fixes. I got one before. […]
mount E E:\
cd E:\
10th.bat
Yeah, someone just told you in your other thread that you are not supposed to do that.
Odd error message.
Don't you think that error message might offer some useful clues as to what is wrong? Wouldn't it be great if you could say what it was, instead of just saying that it is "odd"?
Reply 8 of 41, by dnewhous
Falcon 3.0 has the same problem that "soundblaster" as a music mode means original soundblaster, and the music sounds bad.
The error message is device unavailable in module "Open."
The text of 10th.bat is
@ECHO OFF
CD 10TH
10TH.COM
Daniel L Newhouse
Reply 9 of 41, by dnewhous
The game works better in DOSBox. It doesn't freeze. The wolf howl sounds are there!
oplmu did not improve the quality of the music.
Daniel L Newhouse
Reply 10 of 41, by Jorpho
dnewhous wrote on 2021-03-03, 12:54:
The error message is device unavailable in module "Open." […]
@ECHO OFF
CD 10TH
10TH.COM
If you did not mount a directory as drive C before trying to run 10th.bat, then that would likely cause an odd error message. This was also discussed in your other thread.
You may also enjoy 60 seconds guide to getting your game to run in DOSBox .
Reply 11 of 41, by dnewhous
Yes, you have to mount C and E before 10th.bat will work. When you do you get video and no audio in DOSBox -X.
Daniel L Newhouse
Reply 12 of 41, by Jorpho
dnewhous wrote on 2021-03-07, 21:05:
Are you mounting your CD-ROM as drive D in DOSBox? Like you were told to do in your other thread? And like it says in the 60 Seconds guide?
Please post exactly what you are typing when you try to install the game.
Reply 13 of 41, by dnewhous
The corrected command is mount d e:\ and it doesn't change the result.
Also, I have a Lenovo and the DVD drive on my computer is E:\.
Daniel L Newhouse
Reply 14 of 41, by Jorpho
dnewhous wrote on 2021-03-07, 23:53:
That was not my question. Please post everything that you are typing in DOSBox when you try to install the game. Are you typing EXACTLY the same things when you run the game in DOSBox-X?
Reply 15 of 41, by dnewhous
mount c c:\dosgames
mount d e:\
d:
10th.bat
The splash screen starts without audio.
Daniel L Newhouse
Reply 16 of 41, by Jorpho
dnewhous wrote on 2021-03-08, 13:22:
This still isn't clear. Are you expecting audio for some reason? Is there audio at the splash screen in DOSBox but not in DOSBox-X?
Reply 17 of 41, by dnewhous
Jorpho wrote on 2021-03-08, 19:44:
DOSBox gets the same result. A peculiar error message in the status window.
Daniel L Newhouse
Reply 18 of 41, by Jorpho
dnewhous wrote on 2021-03-08, 20:35:
Okay, so: why do you think there's a problem? Don't you think it's likely that the splash screen doesn't have sound at all, even on original hardware?
If you spent two minutes trying to Google that message, you would learn that it is insignificant.
shell: redirect output to null - what does it mean
Reply 19 of 41, by dnewhous
Jorpho wrote on 2021-03-08, 20:58:
I imagine the splash/install screen does have audio on original hardware. I noticed that they just bumped the revision on DOSBox -X and the directdraw version is no longer available.
Daniel L Newhouse
