First post, by Solplay
This post and the post below does not include models released after Sharp's 2018 buyout of Toshiba's PC division. In terms of years, this means only models from 1985 to 2017 are included.
Model name identifiers:
Consumer: Satellite, Satego, Equium, Libretto, Qosmio, Chromebook, KIRA, NBxxx, ACxxx
Professional: Satellite Pro, Tecra, Portege
Mixed: Txxxx
Notes: Japan exclusive models are given a dynabook prefix (e.g. dynabook VX1), but a few are branded with their international model's name and may not have the dynabook branding. This is no longer the case for models produced after 2017.
Model number identifiers:
0: Europe, the Middle East and Africa or Asia-Pacific region (e.g. Satellite M20)
5: North American region (e.g. Satellite M35)
Notes: Some models were region exclusive. For example, the Satellite J82 was a Japan exclusive model. Most tend to be available in all regions, but they may not have the dynabook branding (e.g. libretto W100). NA and EMEA models use a dash to indicate the configuration (e.g. P25-S509 & P20-204), while Japanese models use a slash to indicate the configuration (e.g. WX/3727CDS & SS2110 DS10L/2).
Part number suffixes:
U: United States (of America)
A: Australia (& New Zealand)
C: Canada
E: Europe (, the Middle East and Africa)
L: Latin America (& Asia-Pacific)
N: Nippon (Japan)
Notes: There are some suffixes that are rarely used but exist, such as K (South Korea).
UEFI and BIOS developers:
BIOS: Toshiba, Phoenix
UEFI: Insyde, AMI
Notes: WLAN, WWAN, and LCD whitelists are not present in Toshiba's firmware. For modifications, use https://github.com/LongSoft/ToshibaComExtractor for Toshiba BIOS images compressed in .COM files. For models with a Phoenix BIOS, use Phoenix BIOS Editor Pro (2.1.0.0, 2.2.0.1, 2.2.13) or phcomp.exe and phxdeco.exe. For UEFI-based models, use https://github.com/LongSoft/UEFITool if the UEFI's vendor is unknown. Otherwise, use Insyde H2OEZE and H2OUVE for Insyde UEFIs or Aptio V UEFI Editor for AMI UEFIs. Alternatively, use AMIBCP for older AMI UEFIs.
Notebook manufacturers:
1985 to 2012: Toshiba, Compal, Quanta, Inventec
2013 to 2017: Toshiba, Quanta, Inventec, Pegatron
Notes: To identify the original manufacturer of your notebook, you must have access to the motherboard. The motherboard should have a model code printed on it, for example: FGQSY1 = Toshiba, LA-5821P = Compal, DABY3CMB8E0 = Quanta, 6050A2493501-MB-A02 = Inventec, AR10ACL = Pegatron.
Models released before 2013:
Please check the warnings for all models, they are documented here as 'Warning' notes.
T series
T1xxx series:
T1000LE
T1000SE
T1000XE
T1100
T1100+
T1200
T1200F
T1200FB
T1200H
T1200HB
T1200XE
T1600
T1800
T2xxx series:
T2000
T2000SX
T2000SXE
T2100
T2200SX
T3xxx series:
T3100
T3100E
T3100SX
T3200
T3200SX
T3200SXC
T3300SL [JP: DynaBook V386/25 J3100SL]
T4xxx series:
T4400
T4400C
T4400SX
T4400SXC
T4500
T4500C
T4600
T4600C
T4700
T4700CS
T4700CT
T4800CT
T4850CT
T4900CT
T5xxx series:
T5100
T5200
T5200C
T6xxx series:
T6300SX
T6400
T6400C
T6400SX
T6400SXC
T6400DX
T6400DXC
T6400MM
T6600C
Satellite series
Suffixes:
No suffix: Monochrome LCD with CCFL backlight, does not apply to models that were never offered with monochrome display panels
C: Color STN LCD with CCFL backlight
CS: Color DSTN LCD with CCFL backlight
CT: Color TN TFT LCD with CCFL backlight
CDS: Color DSTN LCD with CCFL backlight + CD-ROM, CD-R, or CD-RW optical disc drive
CDT: Color TN TFT LCD with CCFL backlight + CD-ROM, CD-R, or CD-RW optical disc drive
DVD: Color TN TFT LCD with CCFL backlight + DVD-ROM optical disc drive + MPEG2 GPU hardware acceleration
D: AMD CPU
T: Touchscreen display panel
Satellite T1xxx series, low-end:
T1850
T1850C
T1900
T1900C
T1910
T1910CS
T1920
T1920CS
T1950
T1950CS
T1950CT
T1960C
T1960CS
T1960CT
Predecessor: No predecessor.
Satellite T2xxx series, mid-end:
T2100/T2105
T2100CS/T2105CS
T2100CT/T2105CT
T2110
T2110CS/T2115CS
T2130/T2135
T2130CS
T2130CT
T2140
Satellite 3x series, low-end:
30CDT
35DVD
Satellite 1xx series, low-end:
100CS/105CS
105CT
110CS/115CS
110CT/115CT
Predecessor: T1xxx series.
Satellite 2xx series, low-end:
200CDS/205CDS
200CDT
210CS
210CT
220CS
220CDS/225CDS
230CX
230CDX
Notes: The 'X' suffix indicates that the model has a FRSTN LCD panel.
Predecessor: T2xxx series.
Satellite 3xx series, mid-end:
300CDS/305CDS
300CDT/305CDT
310CDS/315CDS
310CDT/315CDT
320CDS/325CDS
320CDT/325CDT
330CDS/335CDS
330CDT/335CDT
Satellite 1xxx series, low-end:
1555CDS
1605CDS
1620CDS
1625CDT
1640CDT
1675CDS
1695CDT
1710CDS
1715XCDS
1730CDT
1000/1005
1100/1105 [JP: DynaBook E5]
1110/1115 [JP: DynaBook E6]
1130/1135 [JP: DynaBook E7/E8] {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Li-Ion 18650 battery}
1700
1730/1735
1750/1755
1800/1805 [JP: DynaBook T2/T3/T4]
1900/1905 [JP: DynaBook P5]
1950/1955 [JP: DynaBook P5]
Notes: An 'X' suffix indicates that the model has a 13" display panel.
Warning: The 1130/1135's 2-pin blue cell CMOS battery is soldered to the motherboard.
Predecessor: 1xx series.
Satellite 2xxx series, low-end:
2060CDS/2065CDS
2060CDT/2065CDT
2100CDS/2105CDS
2100CDT
2140CDS
2140XCDS
2180CDT
2210CDT
2210XCDS
2230CDS
2250CDT
2250XCDS
2500CDT/2505CDT
2505CDS
2510CDS/2515CDS
2520CDS
2530CDS
2540CDS/2545CDS
2540XCDT/2545XCDT
2550CDT
2590CDS/2595CDS
2590CDT/2595CDT
2590XDVD/2595XDVD
2610CDT
2610DVD/2615DVD
2650XDVD/2655XDVD
2670DVD/2675DVD
2695DVD
2710DVD/2715DVD
2710XDVD/2715XDVD
2750DVD/2755DVD
2750XDVD
2770XDVD/2775XDVD
2800DVD/2805DVD
2400/2405 [JP: DynaBook T5]
2410/2415 [JP: DynaBook T6]
2800/2805 [JP: DynaBook A1/A2]
Notes: An 'X' suffix indicates that the model has a 13" display panel. For the 2540XCDT/2545XCDT and later models, this stands for a 14.1" display panel.
Rebadges: Satellite 1400/1405 = 2400/2405, Satellite 1410/1415 = 2410/2415, Satellite Pro 2100 = 2410/2415
Warning: The 2410/2415 will revert to a strange 969x768 resolution if a new generic GPU driver from NVIDIA is installed in any OS, likely due to a customized EDID that Toshiba uses in its own NVIDIA GPU driver.
Predecessor: 2xx series.
Satellite 3xxx series, mid-end:
3000/3005
Notes: The DynaBook V1/V2 is loosely based off the 3000/3005's design. None of its parts are compatible with the 3000/3005.
Rebadges: Satellite 1200 = 3000/3005, Satellite Pro 3000 = 3000/3005
Predecessor: 4xxx series.
Satellite 4xxx series, mid-end:
4000CDS/4005CDS
4000CDT/4005CDT
4010CDS/4015CDS
4010CDT/4015CDT
4020CDS
4020CDT/4025CDT
4030CDS
4030CDT
4060CDT
4060XCDT
4070CDS
4070CDT
4080CDT
4080XCDT/4085XCDT
4090CDS
4090XCDT
4090XDVD
4100XCDT
4100XDVD
Notes: An 'X' suffix indicates that the model has a 14.1" display panel.
Predecessor: 3xx series.
Satellite 5xxx series, high-end:
5000/5005 [JP: DynaBook G3/G4] {R. Socket 370 CPU} {R. 2x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
5100/5105 [JP: DynaBook G5/G6/G6C/G7/G7C] {R. Socket 478 CPU} {R. proprietary AGP GPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
5200/5205 [JP: DynaBook G8/G9] {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Warning: The 5000/5005 is prone to overheating due to an undersized CPU heatsink, which either leads to a shutdown in older BIOS versions or throttling to a slower FSB frequency in newer BIOS versions. If there is room, adding more thermal mass to the heatsink by taping small copper heatsinks with thermal adhesive may solve the problem. Replacing the original fan with a fan that has a higher CFM rating may work if the motherboard is able to supply enough power, but this is very unlikely.
Satellite Axx & Axxx series, low to mid-end:
A10/A15 [JP: dynabook A8/A9/A11/AX1/dynabook Satellite A10/A11/AW1] {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A20/A25 {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. CMOS 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A30/A35 [JP: DynaBook P7/P8] {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Li-Ion 18650 battery}
A40/A45 {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A50/A55 [JP: dynabook Satellite T10/T11/T12/T20]
A60/A65 [JP: dynabook AX/dynabook Satellite AW2] [EMEA: Equium A60]
A70/A75 [JP: dynabook AX]
A80/A85 [JP: dynabook TX/PX/dynabook Satellite A20/AW3/AD1] [EMEA: Equium A80]
A100/A105 [JP: dynabook AX/dynabook Satellite AW5/AW6/TX/TXW] [EMEA: Equium A100]
A110 [EMEA: Equium A110]
A130/A135
A200/A205 [JP: dynabook Satellite TX/TXW] [EMEA: Equium A200]
A210/A215 [EMEA: Equium A210]
A300/A305
A300D/A305D [EMEA: Equium A300D]
A350/A355
A350D/A355D
A500/A505
A500D/A505D
A660/A665 [JP: dynabook Satellite AXW]
A660D/A665D
Rebadges: Satellite 2450/2455 = A20/A25, Satellite 2430/2435 = A30/A35, Satellite Pro A10 = A10/A15, Satellite Pro A60 = A60/A65, Satellite Pro A100 = A100/A105, Satellite Pro A110 = A110, Satellite Pro A200 = A200/A205, Satellite Pro A210 = A210/A215, Satellite Pro A300 = A300/A305, Satellite Pro A300D = A300D/A305D, Tecra A1 = A10/A15, Tecra A2 = A50/A55, Tecra A3X = A50/A55, Tecra A7 = A100/A105
Warning: The A30/A35 may suffer from intermittent speaker cut-outs with the audio codec still functioning, cause is unknown. The A70/A75 has two design defects that may result in a sudden shutdown or a loose DC-in power socket. The forced shutdown is caused by the lack of grounding on the palmrest, causing any sort of static electricity conducted through the aluminium speaker mesh or the touchpad's left and right buttons to reach the motherboard. The loose DC-in power socket is caused by cracked lead-free solder joints or a broken DC-in power socket pin, which could progress to a disconnected DC-in power socket (much worse). In some cases, the DC-in power socket pins may oxidize, leading to disconnected pins or a loose DC-in power socket. Both of these problems can be solved by using aluminium foil to connect the affected areas to other parts of the notebook's aluminium frame to dissipate the shock, and resoldering the DC-in power socket respectively. The A30/A35's 2-pin white cell CMOS battery is soldered to the motherboard.
Predecessor: 5xxx series.
Satellite Cxxx series, low-end:
C600/C605
C640/C645 [JP: dynabook B240] {R. Socket G2 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C640D/C645D
C650/C655 [JP: dynabook Satellite A50/B252]
C650D/C655D
C660/C665 [JP: dynabook Satellite B350]
C660D/C665D
C670/C675 [JP: dynabook Satellite B371]
C670D/C675D
C840/C845
C840D/C845D
C850/C855
C850D/C855D
C870/C875 [JP: dynabook Satellite B372]
C870D/C875D
Notes: The B40-A is a rebadge of the Satellite C640/C645 with an Ivy Bridge CPU instead of a Sandy Bridge CPU. Motherboard is interchangeable with the Sandy Bridge variant of the C640/C645, but it may not be compatible with the Arrandale variant.
Rebadges: Satellite Pro C640 = C640/C645, Satellite Pro C650 = C650/C655, Satellite Pro C650D = C650D/C655D, Satellite Pro C660/C665 = C660/C665, Satellite Pro C660D = C660D/C665D, Satellite Pro C840/C845 = C840/C845, Satellite Pro C850 = C850/C855, Satellite Pro C870 = C870/C875, Satellite B40-A= C640/C645, Satellite Pro B40-A = C640/C645
Warning: Most, if not all models of this series has serious build quality issues such as extreme keyboard flexing, easily broken screw posts, failing to idle higher than package c-state C3 on configurations with a HM70 PCH, and failure to initialize the audio codec and fan via ACPI on operating systems older than Windows 7.
Predecessor: No predecessor. Shares a lot of parts with the Lxxx series but with less performance and colors available.
Satellite Exxx series, mid-end:
E100/E105
E200/E205
E300/E305
Predecessor: No predecessor. Best Buy Blue Label exclusive models.
Satellite Jxx series, mid-end:
J10/J11/J12 {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. MiniPCI Type IIIB with PCI} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
J30/J31/J32 {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. MiniPCI Type IIIB with PCI} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
J40 {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
J50 {R. Socket 479 CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. IDE FDD} {R. MiniPCI Type IIIB with PCI} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
J60/J61/J62/J63 {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. IDE FDD} {R. full MiniPCIe with PCIe} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
J70/J71/J72 {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. IDE FDD} {R. full MiniPCIe with PCIe} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
J80/J81/J82 {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. SATA ODD} {R. IDE FDD} {R. full MiniPCIe with PCIe} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: Starting from the J50 onwards, the modem port is no longer available despite the fact there is a modem-shaped port located at the back.
Satellite Lxx & Lxxx series, mid-end:
L10/L15 [EMEA: Equium L10] {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
L20/L25 [EMEA: Equium L20] {R. Socket 479 CPU} {R. 2x DDR2 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIB with PCI} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
L30/L35 [JP: dynabook Satellite P1W] [EMEA: Equium L30] {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. MiniPCI Type IIIB with PCI} {R. Li-Ion 18650 battery}
L40/L45 [EMEA: Equium L40] {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Li-Ion 18650 battery}
L100 [JP: dynabook Satellite P10] [EMEA: Equium L100]
L200 [JP: dynabook Satellite T30/T31]
L300/L305 [JP: dynabook Satellite T40/T41/T42/T43] [EMEA: Equium L300]
L300D/L305D [JP: dynabook Satellite PXW/EXW]
L350/L355 [EMEA: Equium L350]
L350D/L355D [EMEA: Equium L350D]
L450/L455
L450D/L455D
L500/L505 [JP: dynabook BX]
L500D/L505D
L510/L515
L550/L555
L550D/L555D
L630/L635
L640/L645
L640D/L645D
L650/L655
L650D/L655D
L670/L675
L670D/L675D
L730/L735
L730D/L735D
L740/L745
L740D/L745D
L750/L755
L750D/L755D
L770/L775
L770D/L775D
L830/L835
L840/L845
L840D/L845D
L850/L855 [JP: dynabook T552]
L850D/L855D
L870/L875
L870D/L875D
L950/L955
L950D/L955D
Rebadges: Satellite Pro L10 = L10/L15, Satellite Pro L20 = L20/L25, Satellite Pro L40 = L40/L45, Satellite Pro L100 = L100, Satellite Pro L300 = L300/L305, Satellite Pro L300D = L300D/L305D, Satellite Pro L350 = L350/L355, Satellite Pro L450 = L450/L455, Satellite Pro L500 = L500/L505, Satellite Pro L510 = L510/L515, Satellite Pro L550 = L550/L555, Satellite Pro L630 = L630/L635, Satellite Pro L640 = L640/L645, Satellite Pro L650 = L650/L655, Satellite Pro L670 = L670/L675, Satellite Pro L730 = L730/L735, Satellite Pro L740 = L740/L745, Satellite Pro L750 = L750/L755, Satellite Pro L770 = L770/L775, Satellite Pro L830 = L830/L835, Satellite Pro L850 = L850/L855, Satellite Pro L870 = L870/L875, S845 = L845, S845D = L845D, S850/S855 = L850/L855, S855D = L855D, S870/S875 = L870/L875, S875D = L875D, S950/S955 = L950/L955, S950D/S955D = L950D/L955D, M840 = L840/L845, Tecra L2 = L20/L25
Warning: The L10/L15 and the L20/L25 uses a proprietary AC'97 modem card. The L30/L35 and the L40's 2-pin blue cell CMOS battery is soldered to the motherboard.
Satellite Mxx & Mxxx series, low to mid-end:
M30/M35 [JP: dynabook V9/VX/VX1] {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M30X/M35X {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Li-Ion 18650 battery}
M40/M45 [JP: dynabook VX] {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Li-Ion 18650 battery}
M40X [EMEA: Equium M40X] {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Li-Ion 18650 battery}
M50/M55 [JP: dynabook TW] [EMEA: Equium M50]
M60/M65
M70 [EMEA: Equium M70]
M100/M105 [JP: dynabook Satellite CW1/CW2]
M110/M115
M200/M205
M300D/M305D {R. Socket S1g2 CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M300/M305
M500/M505
M640/M645
Notes: An 'X' suffix indicates that the model has an updated design. The M30X/M35X and the M40X uses a design resembling an A70/A75.
Rebadges: Satellite Pro M30 = M30/M35, Satellite Pro M40 = M40/M45, Satellite Pro M40X = M40X, Satellite Pro M50 = M50/M55, Satellite Pro M70 = M70, Satellite Pro M200/M205 = M200/M205, Satellite Pro M300 = M300/M305, Tecra A4 = M40/M45, Tecra A5 = M50/M55, Tecra A6 = M100/M105
Warning: The M30X/M35X and the M40X have two design defects that may result in a sudden shutdown or a loose DC-in power socket. The forced shutdown is caused by the lack of grounding on the palmrest, causing any sort of static electricity conducted through the aluminium speaker mesh or the touchpad's left and right buttons to reach the motherboard. The loose DC-in power socket is caused by cracked lead-free solder joints or a broken DC-in power socket pin, which could progress to a disconnected DC-in power socket (much worse). In some cases, the DC-in power socket pins may oxidize, leading to disconnected pins or a loose DC-in power socket. Both of these problems can be solved by using aluminium foil to connect the affected areas to other parts of the notebook's aluminium frame to dissipate the shock, and resoldering the DC-in power socket respectively. The M30X/M35X, M40X, and the M40/M45's CMOS battery is soldered to the motherboard, seems to be a 2-pin white cell.
Satellite Pxx & Pxxx series, high-end:
P10/P15 {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Li-Ion 18650 battery}
P20/P25 {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Li-Ion 18650 battery}
P30/P35 [JP: dynabook WX] {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Li-Ion 18650 battery}
P100/P105 [EMEA: Satego P100]
P200/P205 [EMEA: Equium P200, Satego P200]
P200D/P205D [EMEA: Equium P200D]
P300/P305 [EMEA: Equium P300]
P300D/P305D
P500D/P505D
P740/P745
P740D/P745D
P750/P755
P750D/P755D
P770/P775
P770D/P775D
P840/P845 [JP: dynabook T642]
P840T/P845T
P850/P855
P870/P875
Notes: The P30 has a Socket T variant (P30-S701TD), but it is extremely rare and was likely produced in low quantities due to cooling issues.
Rebadges: Satellite Pro P100 = P100/P105, Satellite Pro P200 = P200/P205, Satellite Pro P300 = P300/P305, Satellite Pro P300D = P300D/P305D, Satellite Pro P770 = P770/P775
Warning: The P10/P15 and the P20/P25 do not support running the FSB and RAM at a 1:1 ratio (200 MHz : 200 MHz). Installing DDR333 or DDR400 stick(s) will result in a strange FSB:DRAM ratio of 5:4 (200 MHz : 160 MHz). Note that this bug was never fixed in the latest BIOS of either model. The P30/P35's GPU is passively cooled, which has resulted in dead or overheating GPUs (doesn't affect the P10/P15 and the P20/P25 despite being passively cooled as well). This only affects the dedicated GPU variants; the integrated GPU variants are not affected as they don't produce sufficient heat to cause damage. The P10/P15, P20/P25, and the P30/P35's CMOS battery is soldered to the motherboard, seems to be a 2-pin yellow cell.
Satellite Txxx series, low to mid-end:
T110/T115
T110D/T115D
T130/T135
T130D/T135D
T210 [JP: dynabook N510]
T210D/T215D
T230/T235
T230D/T235D
Rebadges: Satellite Pro T110 = T110/T115, Satellite Pro T130 = T130/T135, Satellite Pro T230 = T230/T235, Portege T110 = T110/T115, Portege T130 = T130/T135, Portege T210 = T210, Portege T230 = T230/T235
Satellite Uxxx series, mid to high-end:
U200/U205 [JP: dynabook SS MX/M35/M36/M37] {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
U300/U305 [JP: dynabook SS M40/M41/M42] [EMEA: Equium U300] {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. 2x full MiniPCIe with PCIe} {R. HDA modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
U400D/U405D {R. Socket S1g2 CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
U400/U405 [JP: dynabook SS M50/M51/M52/dynabook CX] [EMEA: Equium U400] {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. IDE ODD} {R. 2x full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
U500/U505 [JP: dynabook SS M60] {R. Socket G1 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA HDD} {R. SATA ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Li-Ion 18650 battery}
U840/U845 {R. 2x DDR3L RAM} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
U845T {R. 2x DDR3L RAM} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
U840W/U845W [JP: dynabook R542] {R. 1x DDR3L RAM} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
U920T/U925T [JP: dynabook R822] {R. 1x DDR3L RAM} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. Li-Ion Polymer battery}
U930/U935 {R. 2x DDR3L RAM} {R. 2.5" SATA HDD} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. Li-Ion Polymer battery}
U940/U945 {R. 2x DDR3L RAM} {R. 2.5" SATA HDD} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. Li-Ion Polymer battery}
Notes: A 'W' suffix indicates that the model has a display panel with a 21:9 aspect ratio.
Rebadges: Satellite Pro U200 = U200/U205, Satellite Pro U300 = U300/U305, Satellite Pro U400 = U400/U405, Satellite Pro U500 = U500/U505, Tecra M6 = U200/U205, Tecra M8 = U300/U305, Portege M500 = U200/U205, Portege M600 = U300/U305, Portege M800/M805 = U400/U405, Portege M805D = U400D/U405D
Warning: The U840W/U845W has BGA RAM. The U920T/U925T uses its battery pack as the CMOS battery. The U500/U505, U930/U935 and the U940/U945's CMOS battery is soldered to the motherboard, seems to be a 2-pin blue cell.
Satellite Xxxx series, high-end:
X200/X205 [JP: dynabook Qosmio WXW] [EMEA: Satego X200] {R. Socket P CPU} {R. 2x proprietary PCIe GPU} {R. 2x DDR2 RAM} {R. 2x 2.5" SATA HDD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Li-Ion 18650 battery}
Warning: The CMOS battery is soldered to the motherboard, seems to be a 2-pin blue cell.
Satellite Pro series
Suffixes:
D: AMD CPU
Satellite Pro T2xxx series, mid-end:
T2150CDS/T2155CDS {R. 1x 80ns FPM RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Ni-MH 18650 battery}
T2150CDT {R. 1x 80ns FPM RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Ni-MH 18650 battery}
T2400CT {R. 1x 70ns FPM RAM} {R. 2.5" IDE HDD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Ni-MH 18650 battery}
T2450CT {R. 1x 70ns FPM RAM} {R. 2.5" IDE HDD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Ni-MH 18650 battery}
Satellite Pro 4xx series, mid-end:
400CS/405CS {R. 1x 70ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
400CDT {R. 1x 70ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
410CS/415CS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
410CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
420CDS/425CDS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
420CDT/425CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
430CDS/435CDS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
430CDT/435CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
440CDT/445CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
440CDX/445CDX {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
460CDT/465CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
460CDX/465CDX {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
470CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
480CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
490CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
490XCDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The 'X' suffix indicates that the model has a FRSTN LCD panel. The 'X' prefix indicates that the model has a 13.3" display panel.
Satellite Pro 4xxx series, mid-end:
4220XCDT {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4260DVD {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4270XDVD {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4270ZDVD {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4280XDVD {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4280ZDVD {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4310CDT {R. Socket 495 CPU} {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4320DVD {R. Socket 495 CPU} {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4340XDVD {R. Socket 495 CPU} {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4360XDVD {R. Socket 495 CPU} {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4380XDVD {R. Socket 495 CPU} {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4600 {R. Socket 495 CPU} {R. 2x PC100 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. IDE FDD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The'X' suffix indicates that the model has a 14.1" display panel, the 'Z' suffix indicates that the model has a 15" display panel. Not sure if the 4200 series are using BGA CPUs, Socket 495 or MMC-2 CPUs.
Predecessor: 4xx series.
Satellite Pro 6xxx series, mid to high-end:
6000/6050 {R. Socket 479 CPU} {R. 2x PC133 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
6070/6100{R. Socket 478 CPU} {R. proprietary AGP GPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The 6070/6100's Bluetooth functionality resides on a board (PA3121U-1BTM) connected to the motherboard via an on-board connector.
Warning: The 6070/6100 has several design defects that may lead to a drifting pointing stick, loose solder joints on the VRAM chips, dead DC/DC daughterboard, loose GPU daughterboard connector, and a overheating hard drive. These problems were likely caused by cracked out lead-free solder and a horrible cooling system. The 6070/6100 will revert to a strange 969x768 resolution if a new generic GPU driver from NVIDIA is installed in any OS, likely due to a customized EDID that Toshiba uses in its own NVIDIA GPU driver.
Satellite Pro Mxx series, mid-end:
M10/M15 [JP: DynaBook V7/DynaBook Satellite M10] {R. Socket 479 CPU} {R. proprietary AGP GPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The M10/M15's Bluetooth functionality resides on a board (PA3232U-1BTM) connected to the motherboard via a non-universal proprietary cable.
Predecessor: 6xxx series.
Satellite Pro Sxxx series, low to mid-end:
S500L [JP: dynabook Satellite L35/L36/B450] {R. Socket P CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
S750 [JP: dynabook Satellite B451/B551/B651] {R. Socket G2 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
S850 [JP: dynabook Satellite B452/B552/B652] {R. Socket G2 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The S850, S750, and the S500L were never sold in NA as they were intended to be the successors of the Satellite Jxx series, which served a niche market that required old ports and slots (e.g. parallel, serial, floppy) to be present. In this case, the S850 and the S750 had a modem (EMEA-exclusive), a standard serial port and a Type II CardBus slot (Japan-exclusive, EMEA variant has an ExpressCard/54 slot) which were no longer present on any Toshiba notebook. Dedicated GPU, WWAN, and smart card reader options were not carried over from the Satellite Pro S500. The docking port (S850) and fingerprint reader are retained only for EMEA variants. All Japanese variants are offered with a keyboard without a numpad, which is the same keyboard used in the Tecra A11. This series is the last to feature keyboards with a key travel of 2.5 mm. The S500L won't POST with a quad-core CPU installed, unless the following modifications are done: electrically insulate pin D8, AA7, AA8, AC8, AE8 and bridge pin AD26 to pin D22 (cover reserved pins and provide power to the 2nd FSB). Bridge pin B23 to pin A20 (force the CPU's FSB down to 800 MHz). Add 2 APIC entries in the ACPI table of the BIOS (initialize the additional 2 cores).
Warning: The S500L is the last model in this series to use a Toshiba BIOS which could be difficult to modify, unlike the other models. If a quad-core CPU is installed in any model, use a 90 W charger as the included 75 W charger may not be sufficient to charge and power the system simultaneously. The integrated webcam and microphone is optional for Japanese variants, standard for EMEA variants. WLAN cards and their respective antennas are optional on all Japanese variants, this means if the model did not originally come with a WLAN card, the antennas won't be there either.
Predecessor: Satellite Jxx series (indirect). Based off the Tecra A11's design.
Qosmio series
Qosmio Exx series, high-end:
E10/E15 {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. MiniPCI Type IA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The E10/E15's Bluetooth functionality resides on a board (PA3232U-1BTM) connected to the motherboard via a non-universal proprietary cable.
Qosmio Fxx & Fxxx series, high-end:
F10/F15 {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. MiniPCI Type IA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
F20/F25 {R. Socket 479 CPU} {R. proprietary PCIe GPU} {R. 2x DDR2 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. MiniPCI Type IA with PCI} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
F30 {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2x 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. MiniPCI Type IA with PCI} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
F40/F45 {R. Socket P CPU} {R. proprietary PCIe GPU} {R. 2x DDR2 RAM} {R. 2x 2.5" SATA SSD} {R. IDE ODD} {R. 2x full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Li-Ion 18650 battery}
F50/F55 [JP: dynabook Qosmio FX] {R. Socket P CPU} {R. proprietary PCIe GPU} {R. 2x DDR2 RAM} {R. 2x 2.5" SATA SSD} {R. SATA ODD} {R. 2x full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
F60 [JP: dynabook Qosmio V65/T750] {R. Socket G1 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. half MiniPCIe with USB} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
F750/F755 [JP: dynabook Qosmio T751/T851] {R. Socket G2 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The F60's Bluetooth functionality resides on a board (PA3750U-1BTM) connected to the motherboard via a non-universal proprietary cable, likewise with the F50/F55 (PA3633U-1BTM), F40/F45 (PA3608U-1BTM), F30 (PA3418U-1BTM), and the F10/F15 (PA3232U-1BTM). The F60 had an optional MiniPCIe with USB slot. The F50/F55 had an optional fingerprint reader and MiniPCIe with PCIe slot that was used to connect a SpursEngine media accelerator card to the board.
Warning: The F40/F45's CMOS battery is soldered to the motherboard, seems to be a 2-pin blue cell.
Qosmio Gxx series, high-end:
G10/G15 {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2x 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. MiniPCI Type IA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
G20/G25 {R. Socket 479 CPU} {R. 2x DDR2 RAM} {R. 2x 2.5" SATA SSD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. MiniPCI Type IA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
G30/G35 {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2x 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. MiniPCI Type IA with PCI} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
G40/G45 {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2x 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
G50/G55 [JP: dynabook Qosmio GX] {R. Socket P CPU} {R. proprietary PCIe GPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. 2x full MiniPCIe with PCIe} {R. 2x full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The G50/G55's Bluetooth functionality resides on a board (PA3608U-1BTM) connected to the motherboard via a non-universal proprietary cable, likewise with the G40/G45, G30/G35, G20/G25 (PA3418U-1BTM), and the G10/G15 (PA3232U-1BTM). The G50/G55 had an optional MiniPCIe with PCIe slot that was used to connect a SpursEngine media accelerator card to the board. Compatible AC'97 modem cards: Foxconn T60M665 (Agere LU97 & CSR BlueCore 01), Ambit T60M283 (Agere LU97), Ambit T62M159 (Conexant Smart V.92), Askey 1456VQL4A(INT) (Agere LU97), Askey V1456VQL-P1(INT) (Agere LU97), Askey 1456VQL1V-1(INT) (Agere LU97), Billionton MDCAZS2 (?).
Qosmio Xxxx series, high-end:
X300/X305 [JP: dynabook Qosmio WXW] {R. Socket P CPU} {R. proprietary PCIe GPU} {R. 2x DDR3 RAM} {R. 2x 2.5" SATA SSD} {R. SATA ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Li-Ion 18650 battery}
X500/X505 [JP: dynabook Qosmio GXW/G60/G65] {R. Socket G1 CPU} {R. proprietary PCIe GPU} {R. 2x DDR3 RAM} {R. 2x 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. half MiniPCIe with USB} {R. full MiniPCIe with USB} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
X770/X775 {R. Socket G2 CPU} {R. MXM 3.0 Type B GPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. Li-Ion 18650 battery}
X870/X875 {R. Socket G2 CPU} {R. MXM 3.0 Type B GPU} {R. 4x DDR3L RAM} {R. 2x 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. Li-Ion 18650 battery}
Notes: The X500/X505's Bluetooth functionality resides on a board (PA3751U-1BTM) connected to the motherboard via a non-universal proprietary cable, likewise with the X300/X305 (PA3633U-1BTM). MXM GPUs without an LVDS display-out are not guaranteed to work in the X870/X875 and the X770/X775. Most modern MXM GPUs will have contact issues with the GPU heatsink's placement as the VRM and VRAM may be in different positions, making next to no contact with the GPU heatsink. Modifications will be needed if the GPU heatsink makes no contact with the MXM GPU. Compatible HD Audio modem cards: Agere Delphi D40 AM5 (LSI CV92-T48B), Agere Delphi D40 AM3 (LSI CV92-T48B), Agere Athens AM2 (LSI CV92-T48B), Conexant RD01-D620 (Conexant CSM92-SP), Conexant RD01-D480 (Conexant CX11252 HSFi), Conexant RD02-D450 (Conexant CX11252 HSFi), Conexant RD02-D330 (Conexant CX11252 HSFi), Conexant RD02-D110 (Conexant CSM92-SP).
Rebadges: Satellite P500/P505 = X500/X505
Warning: The X870/X875, X770/X775, and the X300/X305's CMOS battery is soldered to the motherboard, seems to be a 2-pin blue cell. The X770/X775 has a NVIDIA GeForce GTX 560M 1.5 GiB GDDR5 (192-bit) with Optimus [10DE:1251]. The X870/X875 has a NVIDIA GeForce GTX 670M 3 GiB GDDR5 (192-bit) with Optimus [10DE:1213], however this applies only to configurations without NVIDIA 3D Vision. X870/X875 configurations with NVIDIA 3D Vision have Optimus disabled.
Predecessor: Gxx series.
Tecra series
Suffixes:
CDM: Color TN TFT LCD with CCFL backlight + CD-ROM, CD-R, or CD-RW optical disc drive + MPEG2 GPU hardware acceleration
D: AMD CPU
Tecra 5xx series, mid-end:
500CS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
500CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
510CDS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
510CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
520CDS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
520CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
530CDS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
530CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
550CDS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
550CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: Not sure if the models without a removable CPU are truly unupgradable, they could be using MMC-1, Socket 5 or Socket 7.
Tecra 7xx series, high-end:
700CS {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
700CT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
700CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
710CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
720CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
730CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
730XCDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
740CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
750CDM {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
750CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
750DVD {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
780CDM {R. MCA CPU} {R. 2x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
780DVD {R. MCA CPU} {R. 2x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: An 'X' suffix indicates that the model has a modular SelectBay HDD. This is used exclusively for the 730CDT. Not sure if the models without a removable CPU are truly unupgradable, they could be using MMC-1, Socket 5 or Socket 7.
Tecra 8xxx series, high-end:
8000 {R. MMC-1/MMC-2 CPU} {R. 2x PC66/PC100 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
8100 {R. Socket 495 CPU} {R. 2x PC100 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
8200 {R. Socket 495 CPU} {R. 2x PC100 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The 8000 has 2 variants - Pentium II and III. The Pentium II variant uses the MMC-1 socket and is limited to PC66 RAM, whereas the Pentium III variant uses the MMC-2 socket and is limited to PC100 RAM.
Predecessor: 7xx series.
Tecra 9xxx series, high-end:
9000 {R. Socket 479 CPU} {R. 2x PC133 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
9100 {R. Socket 478 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The 9100 and the 9000's Bluetooth functionality resides on a board (PA3121U-1BTM) connected to the motherboard via an on-board connector.
Predecessor: 8xxx series.
Tecra TE2xxx series, mid-end:
TE2000 {R. Socket 479 CPU} {R. 2x PC133 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
TE2100 {R. Socket 478 CPU} {R. proprietary AGP GPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
TE2300 {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The DynaBook V4/V5 is loosely based off the TE2000's hardware design. None of its parts are compatible with the TE2000.
Rebadges: Satellite M20 = TE2300
Warning: The TE2100 has several design defects that may lead to a loose GPU daughterboard connector or a dead GPU, which can cause pointing stick drift even when no pressure is applied. These problems were likely caused by cracked out lead-free solder and a horrible cooling system. The TE2100 will revert to a strange 969x768 resolution if a new generic GPU driver from NVIDIA is installed in any OS, likely due to a customized EDID that Toshiba uses in its own NVIDIA GPU driver.
Predecessor: No predecessor. Was intended to be the 14.1" variant of the Satellite Pro 6xxx series.
Tecra Ax & Axx series, mid to high-end:
A8 [JP: dynabook Satellite K10/K11/K15/K16/K17] {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A9 [JP: dynabook Satellite K20/K21/K22] {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A10 [JP: dynabook Satellite K30/K31/K32V/K33/L20/L20E/L21] {R. Socket P CPU} {R. proprietary PCIe GPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A11 [JP: dynabook Satellite K40/K41/K42/K45/K46/K47/L40/L41/L42/L45/L46/L47/B550/B650] {R. Socket G1 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The A11, A10, and the A9 (additional MiniPCIe with PCIe slot) had an optional MiniPCIe with USB slot. The A11 and the A10 had an optional smart card reader slot. The A11, A10, A9, and the A8 had an optional fingerprint reader. The A11's Bluetooth functionality resides on a board (PA3798U-1BTM) connected to the motherboard via a non-universal proprietary cable, likewise with the A10 (PA3608U-1BTM), A9, and the A8 (PA3418U-1BTM).
Rebadges: Satellite Pro A120 = A8, Satellite Pro S200 = A9, Satellite Pro S300 = A10, Satellite Pro S500 = A11, Tecra P5 = A9, Tecra S5 = A9, Tecra P10 = A10, Tecra S10 = A10, Tecra P11 = A11, Tecra S11 = A11.
Warning: Quad-core CPUs will not work in the A9, A10, and the A11. Socket and/or BIOS modifications are required for them to work.
Predecessor: Sxx series.
Tecra Mx & Mxx series, mid to high-end:
M1 {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M2/M2V {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M3 {R. Socket 479 CPU} {R. 2x DDR2 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M4 [JP: dynabook R10] {R. Socket 479 CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M5 {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. proprietary IDE ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M7 {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M9 {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. proprietary IDE ODD} {R. 2x full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M10 [JP: dynabook Satellite B10/B11/B12] {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M11 {R. Socket G1 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The M11, M10, M9 (additional MiniPCIe with PCIe slot), and the M7 had an optional MiniPCIe with USB slot. The M11 and the M10 had an optional smart card reader slot. The M11, M10, and the M9 had an optional fingerprint reader. The M11's Bluetooth functionality resides on a board (PA3798U-1BTM) connected to the motherboard via a non-universal proprietary cable, likewise with the M10 (PA3608U-1BTM), M9, M7, M5, M4 (PA3418U-1BTM), M3, M2/M2V, and the M1 (PA3232U-1BTM). A 'V' suffix indicates that the model has an Extreme Graphics 2 GPU instead of a GeForce FX Go5200 GPU. This is used exclusively for the M2.
Rebadges: Satellite R10/R15 = M4, Satellite R20/R25 = M7
Warning: Quad-core CPUs will not work in the M9, M10, and the M11. Socket and/or BIOS modifications are required for them to work.
Predecessor: 9xxx series.
Tecra Rxx & Rxxx series, high-end:
R10 {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R840 [JP: dynabook R741] {R. Socket G2 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R850 [JP: dynabook R751] {R. Socket G2 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R940 [JP: dynabook R742] {R. Socket G2 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R950 [JP: dynabook R752] {R. Socket G2 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The R10's Bluetooth functionality resides on a board (PA3608U-1BTM) connected to the motherboard via a non-universal proprietary cable. The R840 (G83C000C82JP) and the R940's (G83C000C83JP) Japanese variants utilize matte keyboards which tend to be uncommon options for international variants without an AccuPoint (G83C000D62US), although a few configurations were offered with glossy keyboards (G83C000BB2JP).
Rebadges: Satellite R840/R845 = R840, Satellite R850 = R850, Satellite R945 = R940, Satellite Pro R850 = R850. The rebadged R840 and R940 are generally equipped with glossy keyboards (G83C000BB2US).
Warning: The R840, R940, R850, and the R950 were never offered with quad-core CPUs due to insufficient thermal mass needed to cool them under load. However, they do work with quad-core CPUs installed but will likely throttle. If any quad-core CPU is installed, using a 90 W (integrated graphics) or 120 W (dedicated graphics) charger is recommended. The R840, R940, R850, and the R950's Japanese variants may or may not have a webcam and a microphone. Package state C7 is disabled if the R840, R940, R850, R950 is charging. Note that all models excluding the R10 has a glossy silver sticker finish applied on their hinge covers, which chips off easily and can leave quite a mess that looks similar to glitter. It is very time consuming to scrape the gloss off, so leaving it alone would be recommended.
Tecra Sx series, high-end:
S1 {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
S2 {R. Socket 479 CPU} {R. proprietary PCIe GPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
S3 {R. Socket 479 CPU} {R. proprietary PCIe GPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
S4 {R. Socket M CPU} {R. proprietary PCIe GPU} {R. 2x DDR2 RAM} {R. 2.5" SATA HDD} {R. proprietary IDE ODD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The S4 and the S3's Bluetooth functionality resides on a board (PA3418U-1BTM) connected to the motherboard via a non-universal proprietary cable, likewise with the S2 and the S1 (PA3232U-1BTM). Compatible HD Audio modem cards: Agere Delphi D40 AM5 (LSI CV92-T48B), Agere Delphi D40 AM3 (LSI CV92-T48B), Agere Athens AM2 (LSI CV92-T48B), Conexant RD01-D620 (Conexant CSM92-SP), Conexant RD01-D480 (Conexant CX11252 HSFi), Conexant RD02-D450 (Conexant CX11252 HSFi), Conexant RD02-D330 (Conexant CX11252 HSFi), Conexant RD02-D110 (Conexant CSM92-SP). Compatible AC'97 modem cards: Foxconn T60M665 (Agere LU97 & CSR BlueCore 01), Ambit T60M283 (Agere LU97), Ambit T62M159 (Conexant Smart V.92), Askey 1456VQL4A(INT) (Agere LU97), Askey V1456VQL-P1(INT) (Agere LU97), Askey 1456VQL1V-1(INT) (Agere LU97), Billionton MDCAZS2 (?).
Rebadges: Tecra A3 = S2, Tecra P4 = S4
Portege series
Suffixes:
D: AMD CPU
Portege T3xxx series, high-end:
T3400 {R. 1x 80ns FPM RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
T3400CT {R. 1x 80ns FPM RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
T3600CT {R. 1x 70ns FPM RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Portege 3xx series, mid-end:
300CT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
320CT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Predecessor: T3xxx series.
Portege 6xx series, high-end:
610CT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
620CT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
650CT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
660CDT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Portege 1xxx series, mid-end:
1601 [JP: dynabook SS 1600/1610/1620/SX] {R. 1x DDR1 RAM} {R. 2.5" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
1700 [JP: dynabook SS 1700MY] {R. 1x DDR2 RAM} {R. 2.5" SATA HDD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Portege 2xxx series, high-end:
2000 {R. 1x proprietary PC100 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
2001 [JP: DynaBook SS 2000/S4/S5] {R. 1x proprietary PC100 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
2010 {R. 1x proprietary PC100 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
2011 [JP: DynaBook SS 2010/S6] {R. 1x proprietary PC100 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
Notes: The largest HDD available for the 2011, 2010, 2001, and the 2000 is the Toshiba MK8007GAH.
Predecessor: 3xxx series & 7xxx series.
Portege 3xxx series, mid-end:
3010CT/3015CT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
3020CT/3025CT {R. 1x 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
3110CT/3115CT {R. 1x PC66 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
3410CT [JP: DynaBook SS 3330/3330V] {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
3440CT {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
3480CT {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
3490CT {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
3500/3505 {R. 2x PC133 RAM} {R. 2.5" IDE HDD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
Notes: The 3500/3505's Bluetooth functionality resides on a board (PA3232U-1BTM) connected to the motherboard via a non-universal proprietary cable.
Portege 4xxx series, mid to high-end:
4000/4005 {R. 2x PC100 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4001 [JP: DynaBook SS M3/M4] {R. 2x PC100 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4010 {R. 2x PC133 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4101 [JP: dynabook C4100/C4110/C4120/C7/C8/C9] {R. Socket 479 CPU} {R. 2x PC133 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4111 [JP: dynabook C8] {R. Socket 479 CPU} {R. 2x PC133 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
4130 [JP: dynabook CX1] {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The 4000/4005, 4001, and the 4010's Bluetooth functionality resides on a board (PA3121U-1BTM) connected to the motherboard via an on-board connector.
Portege 7xxx series, high-end:
7000CT {R. 1x PC66 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
7010CT/7015CT {R. 1x PC66 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
7020CT/7025CT {R. 1x PC66 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
7140CT {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
7200CT {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
7200CTE {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
7220CTE {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: An 'E' suffix indicates that the model has a Savage IX8 GPU instead of a CyberBlade e4 GPU. This is used exclusively for the 7200CT.
Predecessor: 6xx series.
Portege Axxx series, mid-end:
A100 [JP: dynabook C8/C9/C4110/C4120] {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A200 [JP: dynabook CX/CX1] {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A600/A605 [JP: dynabook SS N10/N11/N12/dynabook NXE] {R. 1x DDR2 RAM} {R. 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The A600/A605 had an optional MiniPCIe with USB slot. The A600/A605's Bluetooth functionality resides on a board (PA3418U-1BTM) connected to the motherboard via a non-universal proprietary cable, likewise with the A200 (PA3232U-1BTM).
Warning: The A600/A605 used Panasonic UJ-844 IDE ODDs which are 7 mm thin. This means 12.7 mm and 9.5 mm ODDs will not fit.
Portege Mxxx series, mid to high-end:
M100 {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. proprietary IDE ODD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M200/M205 [JP: dynabook SS M200] {R. Socket 479 CPU} {R. 2x DDR1 RAM} {R. 2.5" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M300 [JP: dynabook SS MX/M10/M11] {R. 1x DDR1 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M400/M405 {R. Socket M CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. proprietary IDE ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M700 {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. proprietary IDE ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M750 {R. Socket P CPU} {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M780 {R. Socket G1 CPU} {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
M930 {R. 1x DDR3 RAM} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe}
Notes: The M780, M750, M700, and the M400/M405 had an optional MiniPCIe with USB slot. The M780's Bluetooth functionality resides on a board (PA3750U-1BTM) connected to the motherboard via a non-universal proprietary cable, likewise with the M750, M700 (PA3608U-1BTM), M400/M405 (PA3418U-1BTM), M300, M200/M205, and the M100 (PA3232U-1BTM).
Warning: The M930 uses its main battery pack as its CMOS battery. It does not have a dedicated CMOS battery. If the main battery pack completely loses charge, the BIOS and the RTC settings will be cleared. Quad-core CPUs will not work in the M700, M750, and the M780. Socket and/or BIOS modifications are required for them to work.
Portege Rxxx series, high-end:
R100 [JP: dynabook SS 2100/S7/S8/S9] {R. 1x DDR1 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
R111 [JP: dynabook SS 2110/2120] {R. 1x DDR1 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. CR2032 2-pin CMOS battery} {R. Li-Ion Polymer battery}
R150 {R. 1x DDR1 RAM} {R. 2.5" IDE HDD} {R. MiniPCI Type IIIB with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R200/R205 [JP: dynabook SS SX/S20/S21] {R. 1x DDR2 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIA with PCI} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion Polymer battery}
R300 [JP: dynabook SS SX/S30/S31] {R. 2x DDR2 RAM} {R. 2.5" SATA SSD} {R. full MiniPCIe with PCIe} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R400 {R. 2x DDR2 RAM} {R. 1.8" IDE SSD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion Polymer battery}
R500 [JP: dynabook SS RX1] {R. 1x DDR2 RAM} {R. 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R600 [JP: dynabook SS RX2/RX2L] {R. 1x DDR2 RAM} {R. 2.5" SATA SSD} {R. IDE ODD} {R. full MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R700/R705 [JP: dynabook RX3/R730] {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. full MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R830/R835 [JP: dynabook R731] {R. 2x DDR3 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. half MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R930/R935 [JP: dynabook R732/R733] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. half MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The R700/R705, R830/R835 and the R930/R935 had an optional MiniPCIe with USB slot. The R700/R705's Bluetooth functionality resides on a board (G86C00051410) connected to the motherboard via a non-universal proprietary cable, likewise with the R600, R500, R400, and the R200 (PA3418U-1BTM). The largest HDD available for the R400, R200, R111, and the R100 is the Toshiba MK8007GAH. Compatible HD Audio modem cards: Agere Delphi D40 AM5 (LSI CV92-T48B), Agere Delphi D40 AM3 (LSI CV92-T48B), Agere Athens AM2 (LSI CV92-T48B), Conexant RD01-D620 (Conexant CSM92-SP), Conexant RD01-D480 (Conexant CX11252 HSFi), Conexant RD02-D450 (Conexant CX11252 HSFi), Conexant RD02-D330 (Conexant CX11252 HSFi), Conexant RD02-D110 (Conexant CSM92-SP).
Rebadges: Satellite R630 = R700/R705, Satellite R830 = R830/R835, Satellite R930 = R930/R935, Tecra R700 = R700/R705
Warning: The R600 and the R500 used Panasonic UJ-844 IDE ODDs which are 7 mm thin. This means 12.7 mm and 9.5 mm ODDs will not fit. The R200/R205's MiniPCI slot only accepts MiniPCI cards that are half the size of Type IIIA cards due to space constraints, which limits you to the Askey WLL3091-D4 (PA3426U-1MPC) or the Wistron NeWeb DCMA-81. The form factor used by these low-profile MiniPCI cards were never part of the MiniPCI standard. The R700/R705, R830/R835, and the R930/R935's Japanese variants may or may not have a webcam and a microphone. The R700/R705, R830/R835, and the R930/R935 has a glossy silver sticker finish applied on their hinge covers, which chips off easily and can leave quite a mess that looks similar to glitter.
Predecessor: 2xxx series.
Portege Sxxx series, mid-end:
S100 [JP: dynabook SS LX/L10/L11] {R. 2x DDR2 RAM} {R. 2.5" IDE HDD} {R. IDE ODD} {R. MiniPCI Type IIIA with PCI} {R. AC'97 modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: Compatible AC'97 modem cards: Foxconn T60M665 (Agere LU97 & CSR BlueCore 01), Ambit T60M283 (Agere LU97), Ambit T62M159 (Conexant Smart V.92), Askey 1456VQL4A(INT) (Agere LU97), Askey V1456VQL-P1(INT) (Agere LU97), Askey 1456VQL1V-1(INT) (Agere LU97), Billionton MDCAZS2 (?).
Portege Zxxx series, high-end:
Z830/Z835 [JP: dynabook R631] {R. 1x DDR3 RAM} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. half MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery}
Z930/Z935 [JP: dynabook R632] {R. 1x DDR3L RAM} {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. half MiniPCIe with USB} {R. Ni-MH 2-pin CMOS battery}
Notes: The Z930/Z935 and the Z830/Z835 had an optional half MiniPCIe with USB slot.
Rebadges: Satellite Z830 = Z830/Z835, Satellite Z930 = Z930/Z935
Predecessor: Mxxx series (indirect).
Libretto series
Suffixes:
CS: Color STN LCD with CCFL backlight
CT: Color TN TFT LCD with CCFL backlight
Libretto x0, xx0 & xxx0 series, high-end:
20CT/20CTA {R. 1x proprietary 60ns FPM RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
30CT/30CTA [JP: libretto M1] {R. 1x proprietary 60ns FPM RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
50CT [JP: libretto 50M] {R. 1x proprietary 70ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
60CT/60CTA [JP: libretto D2/M2] {R. 1x proprietary 70ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
70CT/70CTA [JP: libretto M3] {R. 1x proprietary 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
100CT/100CTA {R. 1x proprietary 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
110CT {R. 1x proprietary 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
SS 1000CT/SS 1000CTA/SS 1010CT {R. 1x proprietary 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
ff 1050CS/ff 1100CT/ff 1100V {R. 1x proprietary 60ns EDO RAM} {R. 2.5" IDE HDD} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Warning: Installing 9.5 mm HDDs might be a problem as the factory installed HDD used in all models are 8.45 mm thick.
Libretto Lx series, high-end:
L1/L2/L3 {R. 1x PC100 RAM} {R. 2.5" IDE HDD} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
L5 {R. 1x PC133 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIA with PCI} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: RAM form factor is MicroDIMM for all models. The largest HDD available for the L5 is the Toshiba MK8007GAH.
Predecessor: xxx0 series.
Libretto Uxxx series, mid-end:
U100/U105 {R. 1x DDR1 RAM} {R. 1.8" IDE HDD} {R. MiniPCI Type IIIA with PCI} {R. HDA modem} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: Bluetooth functionality resides on a board (PA3418U-1BTM) connected to the motherboard via a non-universal proprietary cable. Compatible HD Audio modem cards: Agere Delphi D40 AM5 (LSI CV92-T48B), Agere Delphi D40 AM3 (LSI CV92-T48B), Agere Athens AM2 (LSI CV92-T48B), Conexant RD01-D620 (Conexant CSM92-SP), Conexant RD01-D480 (Conexant CX11252 HSFi), Conexant RD02-D450 (Conexant CX11252 HSFi), Conexant RD02-D330 (Conexant CX11252 HSFi), Conexant RD02-D110 (Conexant CSM92-SP). The largest HDD available for this model is the Toshiba MK8007GAH.
Warning: The MiniPCI slot only accepts MiniPCI cards that are half the size of Type IIIA cards due to space constraints, which limits you to the Askey WLL3091-D4 (PA3426U-1MPC) or the Wistron NeWeb DCMA-81. The form factor used by these low-profile MiniPCI cards were never part of the MiniPCI standard.
Predecessor: Lx series.
Libretto Wxxx series, mid-end:
W100/W105 {R. full MiniPCIe with SATA} {R. half MiniPCIe with PCIe} {R. Li-Ion Polymer battery}
Notes: Bluetooth functionality resides on a board (PA3798U-1BTM) connected to the motherboard via a non-universal proprietary cable.
Warning: The W100/W105 uses its main battery pack as its CMOS battery. It does not have a dedicated CMOS battery. If the main battery pack completely loses charge, the BIOS and the RTC settings will be cleared.
NB series
Suffixes:
D: AMD CPU
Classmate PC CMx series, low-end:
CM1 {R. 1x DDR2 RAM} {R. 2.5" SATA SSD} {R. full MiniPCIe with PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: Suspected to be a derivative of the NB100/NB105 with a touchscreen and a rugged rubberized shell. Specifications are not confirmed. Japan exclusive.
NB1xx series, low-end:
NB100/NB105 {R. 1x DDR2 RAM} {R. 2.5" SATA SSD} {R. full MiniPCIe with PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: Bluetooth functionality resides on a board (PA3633U-1BTM) connected to the motherboard via a non-universal proprietary cable.
Predecessor: Libretto Uxxx series.
NB2xx series, low-end:
NB200/NB205 [JP: dynabook UX] {R. 1x DDR2 RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with PCIe} {R. Li-Ion 18650 battery}
NB250/NB255 [JP: dynabook UX] {R. 1x DDR3 RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with PCIe} {R. Li-Ion 18650 battery}
Notes: The NB200/NB205's Bluetooth functionality resides on a board (PA3608U-1BTM) connected to the motherboard via a non-universal proprietary cable for it.
Warning: The NB200/NB205 uses its main battery pack as its CMOS battery. It does not have a dedicated CMOS battery. If the main battery pack completely loses charge, the BIOS and the RTC settings will be cleared. The NB250/NB255's CMOS battery is soldered to the motherboard, seems to be a 2-pin blue cell.
Predecessor: NB1xx series.
NB3xx series, low-end:
NB300/NB305 [JP: dynabook UX] {R. 1x DDR2 RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with PCIe} {R. Li-Ion 18650 battery}
Notes: Bluetooth functionality resides on a board (PA3608U-1BTM) connected to the motherboard via a non-universal proprietary cable.
Predecessor: NB2xx series.
NB5xx series, low-end:
NB500/NB505 [JP: dynabook N200] {R. 1x DDR3 RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
NB510/NB515 {R. 1x DDR3 RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
NB520/NB525 [JP: dynabook N300/N301] {R. 1x DDR3 RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
NB550D/NB555D {R. 1x DDR3 RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The NB550D/NB555D was never sold with an AMD C70 APU.
Predecessor: NB3xx series.
AC series
AC1xx series, low-end:
AC100 [JP: dynabook AZ] {R. full MiniPCIe with USB} {R. Li-Ion 18650 battery}
Notes: Unlike every model in this list, this is a fanless ARM notebook. It runs Android 2.1 Eclair.
Accessories:
Docks
Proprietary:
T1100/T1200/T3100/T3200/T5100 Expansion Chassis (PA7310U)
Libretto PC Card Adapter (PCCADPM1) {Compatibility: Libretto 20CT/20CTA, 30CT/30CTA}
Libretto I/O Adapter (CAB0331A) {Compatibility: Libretto 20CT/20CTA, 30CT/30CTA}
I/O Adapter (CAB0334A) {Compatibility: Libretto 50CT, 60CT/60CTA, 70CT/70CTA}
I/O Adaptor (CAB0346A) {Compatibility: Libretto 50CT, 60CT/60CTA, 70CT/70CTA}
I/O Adaptor (CAB0356A) {Compatibility: Libretto 100CT/100CTA, 110CT}
I/O Adapter (PA2725UJ) {Compatibility: Libretto SS 1000CT, SS 1000CTA, SS 1010CT}
Port Replicator (PA2720UJ) {Compatibility: Libretto 50CT, 60CT/60CTA, 70CT/70CTA}
Port Replicator (PA2726UJ) {Compatibility: Libretto SS 1000CT, SS 1000CTA, SS 1010CT}
Enhanced Port Replicator (PA2718U) {Compatibility: Libretto 50CT, 60CT/60CTA, 70CT/70CTA}
Enhanced Port Replicator (PA2719U) {Compatibility: Libretto 100CT/100CTA, 110CT}
Libretto DVD Dock SuperMulti (PA3433U/E-1DV2) {Compatibility: Libretto U100/U105}
T2100 series Port Replicator (PA2708U) {Compatibility: Satellite T2xxx, Satellite Pro T2150CDS/T2155CDS, T2150CDT}
T2400 Port Replicator (PA2704U) {Compatibility: Satellite Pro T2400CT, T2450CT}
Port Repricator (PA2703U) {Compatibility: Portege T3xxx, Portege 610CT, 620CT}
Satellite Port Replicator (PA2731U/UE/UE2) {Compatibility: Satellite 4xxx, Satellite Pro 4xxx}
Noteworthy Port Replicator (NWPR100) {Compatibility: Satellite 1xx}
Xtend Port Replicator (R405) {Compatibility: Satellite 220CDS/225CDS, Satellite Pro 440CDT/445CDT, 440CDX/445CDX, 460CDT/465CDT, 460CDX/465CDX, 480CDT}
CD-ROM Dock (PA2661U) {Compatibility: Portege 300CT}
CD-ROM Dock (PA2662U) {Compatibility: Portege 3xx}
Mini I/O Adaptor (PA2729U) {Compatibility: Portege 3010CT/3015CT, 3020CT/3025CT}
Mini I/O Adapter (PA2735U) {Compatibility: Portege 3110CT/3115CT}
Network I/O Adaptor (PA2734U) {Compatibility: Portege 3110CT/3115CT}
I/O Adaptor (PA2728U) {Compatibility: Portege 3010CT/3015CT, 3020CT/3025CT, Portege 7xxx}
I/O Adaptor (PA3041U-1PRP) {Compatibility: Portege 3410CT, 3440CT, 3480CT, 3490CT}
LAN Port Replicator (PA3040U/E-1PRP) {Compatibility: Portege 3410CT, 3440CT, 3480CT, 3490CT}
Multimedia Port Replicator (PA3042U/E-1DST) {Compatibility: Portege 3410CT, 3440CT, 3480CT, 3490CT}
Z1xT Dock (PA5105U-1PRP/1PRPA) {Compatibility: Portege Z10T-A/Z15T-A}
Z1xT Keyboard Dock (PA5172U-1ESU, PA5172E-1EKU) {Compatibility: Portege Z10T-A/Z15T-A}
Z2xT/WT2x Keyboard Dock (PA5228U-1ESU, PA5228E-1EKU) {Compatibility: Portege Z20T-B, Z20T-C, Portege WT20-B}
Expansion Station (PA3018U/E-1DST) {Compatibility: Tecra 8100, 8200}
CD Network Dock (PA2723U/E) {Compatibility: Portege 7000CT, 7010CT/7015CT, 7020CT/7025CT}
10/100 Network/DVD Dock (PA2722U/E) {Compatibility: Portege 7000CT, 7010CT/7015CT, 7020CT/7025CT}
10/100 Network/DVD Dock II (PA3007U/E-1DST) {Compatibility: Portege 7xxx}
10/100 Network Port Replicator (PA2724U) {Compatibility: Tecra 8000}
10/100 Network Port Replicator II (PA3017U/E-1PRP) {Compatibility: Tecra 8100, 8200}
Tablet Multi Dock (PA3315U-1PRP) {Compatibility: Portege M200/M205}
Tablet Multi Dock II (PA3315U-2PRP) {Compatibility: Satellite R10/R15, Portege M200/M205, Tecra M4}
Express Port Replicator (PA3508U/E-1PRP) {Compatibility: Satellite Pro S200, S300, Portege M400/M405, M700, M750, Tecra R10, Tecra M7, M9, M10, Tecra A9, A10}
Express Port Replicator II (PA3680U/E-1PRP, PA3680E-2PRP) {Compatibility: Satellite Pro S500, Portege M780, Tecra M11, Tecra A11}
Slim Port Replicator (PA3156U/E-1PRP, PA3156U-2PRP) {Compatibility: Portege 2xxx, Portege R100, R111, R200}
Slim Port Replicator II (PA3603U/E/C-1PRP) {Compatibility: Portege A600/A605, Portege R500, R600}
Slim Port Replicator III (PA3681U/E-1PRP, PA3681E-2PRP) {Compatibility: Portege A600/A605, Portege R500, R600}
Advanced Port Replicator (PA3082U/E-1PRP) {Compatibility: Satellite Pro 6000/6050, 6070/6100, Portege 4000/4005, 4001, 4010, Tecra TE2000, TE2100, Tecra 9000, 9100}
Advanced Port Replicator II (PA3082U/E-2PRP) {Compatibility: Satellite Pro M10/M15, Portege M100, Tecra TE2300, Tecra M1, Tecra S1}
Advanced Port Replicator III (PA3314U/E-1PRP) {Compatibility: Satellite R10/R15, Portege M200/M205, M300, Portege S100, Tecra M2/M2V, M3, M4, Tecra A2, A3, A3X, A4, A5, Tecra S2}
Advanced Port Replicator III Plus (PA3474U/E-1PRP) {Compatibility: Satellite Pro A120, Tecra M5, Tecra A6, A7, A8, Tecra S1, S3, S4}
Hi-Speed Port Replicator (PA3838U/E-1PRP) {Compatibility: Portege R700/R705}
Hi-Speed Port Replicator II (PA3916U/E/C/A-1PRP) {Compatibility: Satellite Pro S850, Portege R700/R705, R830/R835, R930/R935, Tecra R840, R940, Tecra R850, R950}
Hi-Speed Port Replicator III 120W (PA5116U/E/A/L-1PRP, PA5116U/E/A-2PRP, PA5116E-3PRP) {Compatibility: Portege Z30(T)-A/Z35-A, Z30(T)-B, Z30(T)-C, Portege Rxx, Tecra Zxx, Tecra Axx}
Hi-Speed Port Replicator III 180W (PA5117U/E-1PRP, PA5117E-2PRP) {Compatibility: Tecra W50-A}
Enhanced Port Replicator (PA2711U/UX) {Compatibility: Satellite 1xx, Satellite 200CDS/205CDS, 200CDT, 210CS, 210CT, Satellite Pro 400CS/405CS, 400CDT, 410CS/415CS, 410CDT, 420CDS/425CDS, 420CDT/425CDT, 430CDS/435CDS, 430CDT/435CDT}
Enhanced Port Replicator II (PA2713U) {Compatibility: Portege 650CT, 660CDT, Tecra 5xx, Tecra 710CDT, 720CDT, 730CDT, 730XCDT, 740CDT}
Enhanced Port Replicator II (PA2716U) {Compatibility: Tecra 750CDM, 750CDT, 750DVD, 780CDM, 780DVD, Tecra 8000}
Enhanced Port Replicator III (PA2717U) {Compatibility: Satellite 4xxx, Satellite Pro 440CDT/445CDT, 440CDX/445CDX, 460CDT/465CDT, 460CDX/465CDX, 470CDT, 480CDT, 490CDT, 490XCDT, Satellite Pro 4xxx}
Enhanced Port Replicator IV (PA3024U/E-1PRP) {Compatibility: Satellite Pro 4xxx}
Enhanced Port Replicator V (PA3028U/E-1PRP) {Compatibility: Tecra 8100, 8200}
Desk Station II (PA8600U) {Compatibility: T1000LE, T1000SE, T1000XE, T1200XE, T2000, T2000SX, T2000SXE}
Desk Station III (PA8601U) {Compatibility: T3100SX}
Desk Station IV (PA2701U) {Compatibility: T2200SX, T3300SL, T4400C, T4400SX, T4400SXC, T4500, T4500C, T4600, T4600C, T4700CS, T4700CT, T4800CT, T4850CT, T4900CT}
Desk Station IV Plus (PA2700U) {Compatibility: T4500, T4500C, T4600, T4600C, T4700, T4700CS, T4700CT, T4800CT, T4850CT, T4900CT}
Desk Station V (PA2712U) {Compatibility: Tecra 700CS, 700CT}
Desk Station V Plus (PA2710U) {Compatibility: Portege 650CT, 660CDT, Tecra 5xx, Tecra 7xx, Tecra 8000}
Notes: The Desk Station V Plus is not compatible with the Tecra 700CS and the Tecra 700CT. The Satellite Port Replicator and the Enhanced Port Replicator III is not compatible with the Satellite 4000CDS/4005CDS, 4000CDT/4005CDT, 4010CDS/4015CDS, 4010CDT/4015CDT, 4020CDS, and the 4020CDT/4025CDT. The Expansion Station is compatible with the Tecra 8100 and the Tecra 8200, assuming either model is docked to the 10/100 Network Port Replicator II (connected to the expansion station via proprietary cable). The Advanced Port Replicator II is compatible with models that support the original Advanced Port Replicator. The Advanced Port Replicator III Plus is compatible with models that support the original Advanced Port Replicator III. The Hi-Speed Port Replicator III 120W can be docked with a Tecra W50-A, assuming the included 120W charger is replaced with a third-party 180W charger like the Delta ADP-180HB D.
Universal:
dynadock USB Port Replicator VGA (PA3541U-2PRP)
dynadock USB Port Replicator DVI (PA3542U/E/A-2PRP)
dynadock U (PA3575U/E/A-1PRP)
dynadock U3.0 (PA3927U/E/A-1PRP, PA3927U/E/A-2PRP)
dynadock V (PA3778U/E/A-1PRP, PA3778E-2PRP)
dynadock V3.0 (PA5082U/E-1PRP)
dynadock 4K (PA5217U/E/A-1PRP)
dynadock WiAC (PA5238U-1PRP)
Thunderbolt 3 Dock (PA5281U/E/A-1PRP, PA5281U/E/A-2PRP)
dynabook USB-C Dock (PA5356U/E/A-1PRP)
dynadock wireless U (PA3686U-1SET)
Wireless UWB Port Replicator (PA3529U-2PRP)
Adapters:
Advanced Port Replicator Security Plate (PA3120U-1ETC/2ETC)
Hi-Speed Port Replicator III Balance Block (PA5248E-1PBB)
Desk Station V Plus Docking Adapter (PA2714U) {Compatibility: Portege 650CT}
Desk Station V Plus Docking Adapter (PA2715U) {Compatibility: Portege 660CDT}
Enhanced Port Replicator III Adapter (PA2721U) {Compatibility: Tecra 8000}
Enhanced Port Replicator III Spacer (PA2730U) {Compatibility: Satellite 4xxx, Satellite Pro 4xxx}
Notes: The Enhanced Port Replicator III Spacer is not compatible with the Satellite 4000CDS/4005CDS, 4000CDT/4005CDT, 4010CDS/4015CDS, 4010CDT/4015CDT, 4020CDS, and the 4020CDT/4025CDT.
Chargers
Suffixes:
No suffix: IEC C8 socket for power cord
xACA: IEC C8 socket for power cord
xAC3: IEC C6 socket for power cord
Notes: Some chargers have identical part numbers but they do not share the same plug or socket dimensions.
Miscellaneous:
230 W, 19 V, Singatron 2MJ-3432-007 4-pin socket (PA3673E-1AC3 [IEC C14 socket])
180 W, 19 V, Singatron 2MJ-3432-007 4-pin socket (PA3546U-1ACA, PA5084E/PA3546E-1AC3 [IEC C14 socket])
20 W, 18 V, proprietary half-octagonal 4-pin plug (PA2400U [IEC C14 socket])
120 W, 15 V, isosceles trapezoidal 4-pin plug (PA3237U-3ACA, PA3237U-1ACA, PA3507E-1AC3, PA3507U-1ACA [IEC C6 socket])
40 W, 15 V, proprietary 'binoculars' 2-pin plug (PA8709U [IEC C14 socket])
30 W, 15 V, symmetrical rectangular 2-pin plug (PA2501U)
65 W, 20/15/9/5 V, Female USB Type-C (PA5352U-1ACA [USB Power Delivery 3.0])
45 W, 20/15/9/5 V, Female USB Type-C (PA5279U-1ACA [USB Power Delivery 3.0])
10 W, 5 V, Female USB Type-A (PA5194N/PA3996N-1ACA, PA3996D-1AC3 [USB Battery Charging 1.2 - Dedicated Charging Port])
Notes: The isosceles trapezoidal 4-pin plug's polarity is arranged this way: / + + \ (top), | - - | (bottom). The Hitachi 1A187WI/1A187WI-2 has an isosceles trapezoidal 4-pin plug and can be used to power any model that is compatible with this plug. It supplies 150 W in comparison to the PA3237U-3ACA, but it is restricted to 100 V AC 50/60 Hz outlets and is 79% efficient.
6.3 x 3.0 mm 1-pin coaxial plug:
120 W, 19 V (PA3290U-1ACA)
30 W, 18 V (PA2478U/PA2431U)
90 W, 15 V (PA2521U-3ACA, PA3954U/PA2521U-1ACA, PA2521E-2AC3, PA3954E-1AC3)
75 W, 15 V (PA3283U-5ACA, PA3283U-3ACA, PA3283U-2ACA, PA3755U/PA3469U/PA3283U/PA3215U/PA3201U/PA3083U-1ACA, PA3378E-3AC3, PA3755E/PA3469E-1AC3, PA3378E-2ACA/1ACA [IEC C6 socket])
60 W, 15 V (PA3282U-2ACA, PA3282U/PA3260U-1ACA, PA2444U)
45 W, 15 V (PA3241U-2ACA, PA3241U/PA3153U-1ACA, PA2450U)
40 W, 15 V (PA2484U)
30 W, 15 V (PA2500U/PA2440U/PA2411U)
21 W, 15 V (PA2426U/PA2409U)
30 W, 12 V (PA7487U)
26 W, 12 V (PA7485U)
20 W, 12 V (PA8706U)
10 W, 12 V (PA8713U)
10 W, 9 V (PA8701U/PA7482U)
Notes: PA3290U-1ACA was bundled with the Satellite A60/A65, A70/A75, Satellite P10/P15, P20/P25, P30/P35. Later revisions of the Satellite P20/P25 with the GeForce FX Go5700 GPU switched to a PA3290U-3ACA or a PA3290E-3AC3.
5.5 x 2.5 mm 1-pin coaxial plug:
150 W, 19 V (PA3413U/PA3337U-1ACA)
120 W, 19 V (PA5181U/PA5083U/PA3717U-1ACA, PA5181E/PA5083E/PA3717E-1AC3, PA3381U-1ACA [IEC C6 socket])
90 W, 19 V (PA5180U/PA5035U/PA3716U-1ACA, PA5180E/PA5115E/PA5035E/PA3716E-1AC3)
75 W, 19 V (PA5179U/PA5034U/PA3715U-1ACA, PA5034E/PA3715E/PA3468E-1AC3)
65 W, 19 V (PA5367U/PA5178U/PA3917U/PA3714U/PA3467U-1ACA, PA5367E/PA5178E/PA5114E/PA3917E/PA3714E/PA3467E-1AC3)
45 W, 19 V (PA5177U/PA3822U-1ACA, PA5177E/PA3822E-1AC3)
30 W, 19 V (PA3743U-1ACA, PA3743E-1AC3)
25 W, 5 V (PA3543U-1ACA)
Notes: PA3413U-1ACA was exclusively bundled with the Satellite P30-S701TD as it needed more power to run Socket T Pentium 4 CPUs.
4.0 x 1.7 mm 1-pin coaxial plug:
45 W, 19 V (PA5192U/PA5177U/PA5072U-1ACA, PA5192E/PA5072E-1AC3)
30 W, 19 V (PA3922U-1ACA, PA3922E-1AC3)
Tips
Software:
  • Manual fan control is nearly impossible on models that were built by Toshiba. Many were equipped with an embedded controller that doesn't expose any register(s) related to fan control, so avoid them if you need it. If you're trying to find the register that controls the fan, try http://rweverything.com/ or https://github.com/hirschmann/nbfc. As a workaround, try undervolting if you don't have the INTEL-SA-00289 Plundervolt patch applied on notebooks with Skylake or later CPUs. Underclocking is the last resort, but it has no risk of instability.
Batteries:
  • Leak-prone nickel-metal hydride CMOS/BIOS batteries were mostly used in old to new Toshiba-built models. These cells can't be replaced with lithium-ion coin cells due to voltage differences. Outsourced old models generally used a non-removable lithium-ion coin cell, which were usually soldered to the motherboard. In newer outsourced models and Toshiba-built models, these were made removable by either implementing a coin cell battery holder or a 2-pin JST SH socket.
  • Old models with nickel-cadmium and nickel-metal hydride battery packs may leak out electrolyte, be careful as these leaks could damage the motherboard.
  • Old and new models might have lithium-ion polymer pouch cells in their battery packs which have no way of venting out gas, eventually causing the pouch cell to expand. Models with lithium-ion cylindrical cells have pressure valves that are able to vent out excess gas, preventing the cylindrical cell from expanding. Avoid all models with lithium-ion polymer cells if you don't want to risk a chance of a bloated battery. Most models that utilize lithium-ion polymer battery packs are usually thin, so staying with thick models would be the recommended option
Display panels:
  • All models equipped with a cold cathode fluorescent lamp (CCFL) backlight will eventually develop a red/pink tint on the display and get dimmer over time, due to mercury adsorption and phosphor coating degradation respectively from regular usage. Fixing this requires replacing the CCFL backlight, although an easier way would be to replace the entire display panel.
  • CCFL backlit display panels are driven by a DC-to-AC inverter. If the inverter fails, the CCFL backlight will not get any power and leave the display panel dark. Anything shown on the display panel can still be seen, but only with a flashlight pointed at it. To fix this, replace the inverter but make sure it is the correct inverter for your model. Most inverters built for TN LCDs will most likely overheat when used with a IPS LCD, as IPS LCD CCFL backlights generally draw more power on average compared to TN LCDs.
  • Light-emitting diode (LED) backlit panels do not suffer from the same problems that CCFL backlit panels do, but they are not immune from problems related to aging. These either manifest as getting dimmer over time, or outright failure. They also do not have a DC-to-AC inverter, instead, they use an LED driver to power the backlight. Unlike inverters, LED drivers are generally hard to remove as they are part of the display panel.
  • If you are buying a replacement panel, make sure to check the minimum values in its datasheet. Typical is usually stated but minimum is not, because it is generally much lower than the typical value. For example, if you were to buy a panel and get an oddly low contrast ratio or brightness from the panel lottery, you might be disappointed if you didn't check its datasheet for minimum values. To play it safe, either check the minimum values or buy a panel with better specs to compensate for the possibility that it could be much lower than average. Note that this is only important if you care about the following specs: contrast ratio, response time, brightness, color gamut, horizontal and vertical viewing angles.
CPUs:
  • Models with a removable CPU may not necessarily be capable of accepting the fastest CPU available for its socket. Use MCExtractor to determine if your UEFI/BIOS accepts the CPU that you're upgrading to. If the UEFI/BIOS does not contain the appropriate microcode revision and platform, you must add it in manually via proprietary BIOS editors or hex editors. This is not guaranteed to work as some motherboards do not have a compatible VRM revision or UEFI/BIOS code to power or initialize the CPU.
  • If the CPU that you have chosen works, you should consider reapplying thermal paste and additionally remove dust from the heatsink if there is any. One thing to note is the amount of heat the CPU dissipates, because as you go higher, the need for thermal paste that provides good contact and adequate heat transfer characteristics goes higher as well.
GPUs:
  • Post-2010 models with a dedicated graphics chip may utilize NVIDIA Optimus or AMD Enduro without a display multiplexer/MUX switch. This is rarely ever stated because a lot of people see it as a useful feature that improves battery life. However, outdated applications might have issues detecting the dedicated graphics chip through this hybrid setup. Therefore, avoid them if software compatibility is a concern due to the lack of a display multiplexer.
  • Models with a removable GPU may not necessarily fully comply with MXM specifications. Some partially comply, such GPUs might have an MXM connector but their screw mounts and PCB shape do not follow the MXM specifications. Others are fully proprietary and do not follow MXM specifications at all, although these tend to be AGP-based GPUs.
  • Models with any form of PCI-based internal expansion slots (e.g. CardBus, ExpressCard, MiniPCI, MiniPCIe, M.2) are not guaranteed to support graphics cards. However, models using early 32-bit platforms may have no problems with graphics cards connected to their internal expansion slot. Newer models will likely run into PCI address space problems due to the TOLUD being set to 3 GiB or greater, which can't be changed as their UEFI/BIOS does not have a option to change it. A UEFI/BIOS modification might be necessary in this case.
RAM:
  • Models with removable RAM are not guaranteed to comply with JEDEC standards. While all newer models do comply with JEDEC standards, older models may not. Some of them only accepted JEIDA or proprietary expansion cards.
Miscellaneous:
  • Models produced in 5 March 1998 to 7 November 1999 with a floppy disk controller could potentially write corrupted data to a floppy disk. The patch was released decades ago, but I'm not sure if it has actually fixed the problem.
Recalls:
https://acadaptercheck.dynabook.com/AdapterUp … ntry=AU&lang=en
https://batterycheck.dynabook.com/BatteryUpda … ntry=US&lang=en
https://support.dynabook.com/axx2024
https://www.inversenet.co.jp/pclist/maker/TOSHIBA-note.html
https://dynabook.com/manual_download/cata1999.html
https://web.archive.org/web/20190329142605/ht … rocodelist.html
https://web.archive.org/web/20151031050129/ht … s.aspx?id=23908 Q815062_W2K_spl_X86_EN.exe Qchain.exe
https://web.archive.org/web/20000817073820/ht … mg/transparent/ Transparent42.zip
Latest 7 network drivers
Realtek WLAN PCIe Driver 2023.79.0419.2019 - for 7 x86/x64
https://dl.driverpack.io/driverpacks/repack/W … 19.2019-drp.zip
Realtek WLAN USB Driver 5001.0.13.104 - for 7 x86/x64, 10 x86/x64
https://web.archive.org/web/20260524165425/ht … ename=EP-AX1696
Intel Network Adapter LAN Driver 25.0 - for 7 x86/x64
https://www.intel.com/content/www/us/en/downl … al-release.html
Latest XP network drivers
Atheros Client Utility 8.0.0.300 WLAN Driver 10.0.0.274 - for XP x86/x64, Vista x86/x64, 7 x86/x64, 8 x86/x64, 8.1 x86/x64
https://fichiers.touslesdrivers.com/42799/Qua … _10.0.0.297.zip
https://web.archive.org/web/20260427140320/ht … _10.0.0.297.zip
https://newsupport.lenovo.com.cn/driveDownloa … l?driveId=36874
https://web.archive.org/web/20260427134730/ht … oJd6bDJTbP4Fi1h
Atheros Bluetooth Suite 8.0.0.204 - for XP x86/x64
https://fichiers.touslesdrivers.com/36747/Qua … e_8.0.0.204.exe
https://web.archive.org/web/20260427145012/ht … e_8.0.0.204.exe
https://ftp.hp.com/pub/softpaq/sp61001-61500/sp61410.exe (supports 7 x86/x64, 8 x86/x64)
Realtek WLAN PCIe Utility Driver 2012.12.0325.2014
https://www.asus.com/us/networking-iot-server … del2Name=PCEN15
https://web.archive.org/web/20260427160559/ht … =K2ITB7O97XKKCX
Realtek WLAN USB Utility Driver 1030.31.0102.2018
- XP x86/x64, Vista x86/x64, 7 x86/x64, 8 x86/x64, 8.1 x86/x64, 10 x86/x64
https://www.trendtechcn.com/upload/BrosTrend- … ows-1030-31.zip
https://web.archive.org/web/20260427170944/ht … ows-1030-31.zip
Intel Network Adapter LAN Driver 18.3 - for XP x86/x64
https://web.archive.org/web/20190904134630/ht … PRO2K3XP_32.exe
https://web.archive.org/web/20190904134629/ht … RO2K3XP_x64.exe
https://web.archive.org/web/20190807131826/ht … pro2k3xp_32.exe
https://web.archive.org/web/20190904134708/ht … ro2k3xp_x64.exe
Intel Graphics Driver 14.51.11.64.5437, 6.14.11.5437 & 5.14.00.3090 - for XP x86/x64 (needs .NET 3.0 SP2 installed for the control panel to work)
https://downloadmirror.intel.com/22642/a08/winxp_145111.exe
https://downloadmirror.intel.com/22644/a08/wi … xp64_145111.exe
Latest 2000 network drivers
Atheros Client Utility 8.0.0.168 WLAN Driver 7.7.0.509 - for 2000, XP x86 (2000 needs the Visual C++ 6.0 runtime installed)
https://support.ts.fujitsu.com/IndexQuickSear … Lifebook%20s751
https://web.archive.org/web/20260427145521if_ … D5COT1BOT5AJCg=
https://web.archive.org/web/20120707035915/ht … stsetup_enu.exe
Intel Network Adapter LAN Driver 14.0 - for 2000
https://web.archive.org/web/20181130172557/ht … 0/eng/pro2k.exe
Latest NT 4.0 network drivers
Atheros Client Utility WLAN Driver 2.4.2.40 - for NT 4.0 x86 (doesn't support all Atheros chips, supports AR5001A, AR5001X, AR5004G and WPA2 is not supported by the client)
http://ps-2.kev009.com/pccbbs/options/wcbnt4.exe
Atheros WLAN Driver 2.4.1.12 - for NT 4.0 x86, 98, 2000, XP x86 (doesn't support all Atheros chips, supports AR5001X+ and AR5004X, Atheros client is not included)
https://download.lenovo.com/ibmdl/pub/pc/pccb … es/1qwc70ww.exe
Intel Network Adapter LAN Driver 10.01 - for NT 4.0 x86 (82562EZ not supported)
https://web.archive.org/web/20190904141058/ht … /eng/PRONT4.exe
MXM 1.3
Interface: FPD-Link
Output: Composite or S-Video + VGA + 2 single-link or 1 dual-link DVI
Form factor: Type 1 (70 x 68 mm), 2 (73 x 78 mm), 3 (82 x 100 mm)
Mount: Type 1 and 2 (41 mm apart), Type 3 (46 mm apart)
Wattage: Type 1 (18 W), Type 2 (25 W), Type 3 (35 W)
Compatibility: 1.3, 2.0, 2.1, 2.1a
Modules: Quadro FX Go540 128 MiB DDR SDRAM (390151-001/399008-001, Type 2)
MXM 2.0
Interface: FPD-Link
Wattage: Type 1 (18 W), Type 2 (25 W), Type 3 (35 W), Type 3 HE (75 W)
Modules: Quadro FX 560M 256 MiB DDR SDRAM (447652-003, Type 2)
Quadro FX 770M 256 MiB GDDR3 SDRAM (447652-004, Type 2)
Quadro FX 1500M 256 MiB GDDR3 SDRAM (417206-001, Type 3)
Quadro FX 1500M 512 MiB GDDR3 SDRAM (441217-001, Type 3)
Quadro FX 3600M 512 MiB GDDR3 SDRAM (490567-001, Type 3 HE)
MXM 2.1
Interface: FPD-Link
Output: Composite or S-Video + VGA + 2 single-link DVI or 2 dual-link DVI + HDMI
Modules: Quadro FX 570M 256 MiB GDDR3 SDRAM (455077-001, Type 2)
Quadro FX 770M 512 MiB GDDR3 SDRAM (502338-001, Type 2)
Quadro NVS 320M 256 MiB GDDR3 SDRAM (450484-001, Type 3 HE)
Quadro FX 1600M 512 MiB GDDR3 SDRAM (451377-001, Type 3 HE)
Quadro FX 2700M 512 MiB GDDR3 SDRAM (493983-001, Type 3 HE)
Quadro FX 3700M 1 GiB GDDR3 SDRAM (493984-001, Type 3 HE)
MXM 2.1a
Interface: FPD-Link
Output: Composite or S-Video + VGA + 2 single-link DVI or 2 dual-link DVI + HDMI + single-mode DisplayPort
Form factor: Type 1 (70 x 68 mm), 2 (73 x 78 mm), 3 (82 x 100 mm), 4 (82 x 117 mm)
Mount: Type 1 and 2 (41 mm apart), Type 3 and 4 (46 mm apart)
Wattage: Type 1 (18 W), Type 2 (25 W), Type 3 (35 W), Type 3 HE (75 W), Type 4 HE (75 W)
Modules: Quadro FX 2700M 512 MiB GDDR3 SDRAM (42W8202, Type 3 HE)
Quadro FX 3700M 1 GiB GDDR3 SDRAM (42W8204, Type 3 HE)
MXM 3.0
Interface: FPD-Link or EDP
Output: VGA + dual-link DVI + HDMI + 2 or 4 dual-mode DisplayPort
Form factor: Type A (82 x 70 mm), B (82 x 105 mm)
Mount: Type A and B (46 mm apart)
Wattage: Type A (55 W), Type B (100 W)
Compatibility: 3.0, 3.1
Modules: Quadro NVS 5100M 1 GiB DDR3 SDRAM (595820-001, Type A)
Quadro FX 880M 1 GiB DDR3 SDRAM (595821-001, Type A)
Quadro FX 1800M 1 GiB GDDR5 SDRAM (595822-001, Type A)
Quadro F500M 1 GiB DDR3 SDRAM (677907-001, Type A)
Quadro F1000M 2 GiB DDR3 SDRAM (652673-001, Type A)
Quadro F1000M 2 GiB GDDR3 SDRAM (0KDWV4, Type A)
Quadro F2000M 2 GiB DDR3 SDRAM (652674-001, Type A)
Quadro F2000M 2 GiB GDDR3 SDRAM (0PMY8Y, Type A)
Quadro FX 2800M 1 GiB GDDR3 SDRAM (63Y2057/596062-001, Type B)
Quadro FX 3800M 1 GiB GDDR3 SDRAM (63Y2058/596063-001, Type B)
Quadro F3000M 2 GiB GDDR5 SDRAM (0RDJT7/647177-001, Type B)
Quadro F3000M 2 GiB GDDR5 SGRAM (CP519179-03, Type B)
Quadro F4000M 2 GiB GDDR5 SDRAM (0DR11K/0HGXY3/647178-001, Type B)
Quadro F4000M 2 GiB GDDR5 SGRAM (CP519180-02, Type B)
Quadro F5000M 2 GiB GDDR5 SDRAM (596064-001, Type B)
Quadro F5010M 4 GiB GDDR5 SDRAM (0K9MWW/647179-001, Type B)
MXM 3.1
Modules: Quadro K610M 1 GiB GDDR5 SDRAM (728554-001, Type A)
Quadro M3000 SE 4 GiB GDDR5 SDRAM (867583-B21, Type B)
Tesla M6 8 GiB GDDR5 SDRAM (808409-001, Type B)
Notebooks with an MXM slot
[GP104:1BB6] Quadro P5000M (ThinkPad P71, Precision 7720, ZBook 17 G4, Celsius H970)
[GP104:1BB7] Quadro P4000M (ThinkPad P71, Precision 7720, ZBook 17 G4, Celsius H970)
[GP104:1BB8] Quadro P3000M (ThinkPad P71, Precision 7720, ZBook 17 G4, Celsius H970)
[GM204:13F8] Quadro M5000M (ThinkPad P70, ZBook 17 G3, Precision 7710)
[GM204:13F9] Quadro M4000M (ThinkPad P70, Precision 7710, ZBook 17 G3)
[GM204:13FA] Quadro M3000M (ThinkPad P70, Precision 7710, ZBook 17 G3)
[GM206:1436] Quadro M2200M (ThinkPad P71, Precision 7520, ZBook 15 G4, ZBook 17 G4)
[GM107:13B0] Quadro M2000M (Precision 7510, ZBook 17 G3)
[GM107:13B6] Quadro M1200M (Precision 7520, Precision 7720, ZBook 15 G4, ZBook 17 G4)
[GM107:13B1] Quadro M1000M (Precision 7510, ZBook 15 G3, ZBook 17 G3)
[GM107:13B4] Quadro M620M (ThinkPad P71, ZBook 15 G4)
[GM107:13B2] Quadro M600M (ThinkPad P70, ZBook 15 G3)
[GK104:11B8] Quadro K5100M (Precision M6800, ZBook 17 G1, ZBook 17 G2)
[GK104:11BC] Quadro K5000M (Precision M6700, EliteBook 8770w, Celsius H920)
[GK104:11B7] Quadro K4100M (Precision M6800, ZBook 17 G1, ZBook 17 G2)
[GK104:11BD] Quadro K4000M (Precision M6700, EliteBook 8770w, Celsius H920)
[GK104:11B6] Quadro K3100M (Precision M6800, ZBook 17 G1, ZBook 17 G2)
[GK104:11BE] Quadro K3000M (Precision M6700, EliteBook 8770w, Celsius H920)
[GM107:13B3] Quadro K2200M (Precision M6800, ZBook 17 G2)
[GK106:11FC] Quadro K2100M (Precision M4800, ZBook 15 G1, ZBook 15 G2)
[GK107:0FFB] Quadro K2000M (Precision M4700, EliteBook 8570w)
[GK107:0FF6] Quadro K1100M (Precision M4800, Precision M6800, ZBook 15 G1, ZBook 15 G2, ZBook 17 G1, ZBook 17 G2)
[GK107:0FFC] Quadro K1000M (Precision M4700, Precision M6700, EliteBook 8570w)
[GK208:12B9] Quadro K610M (ZBook 15 G1, ZBook 15 G2, ZBook 17 G1)
[GK107:0FF8] Quadro K500M (ZBook 15 G1, ZBook 17 G1)
[GF110:109A] Quadro F5010M (Precision M6600, EliteBook 8760w, Celsius H910)
[GF100:06DA] Quadro F5000M (EliteBook 8740w)
[GF104:0E3B] Quadro F4000M (Precision M6600, EliteBook 8760w, Celsius H910)
[GF104:0E3A] Quadro F3000M (Precision M6600, EliteBook 8760w, Celsius H910)
[GF106:0DDA] Quadro F2000M (Precision M4600, Precision M6600, EliteBook 8560w)
[GF108:0DFA] Quadro F1000M (Precision M4600, Precision M6600, EliteBook 8560w)
[G92:061F] Quadro FX 3800M (ThinkPad W701, EliteBook 8740w)
[G92:061E] Quadro FX 3700M (ThinkPad W700, EliteBook 8730w)
[G92:061D] Quadro FX 2800M (ThinkPad W701, EliteBook 8740w)
[G94:063A] Quadro FX 2700M (ThinkPad W700, EliteBook 8730w)
[GT215:0CBC] Quadro FX 1800M (EliteBook 8540w)
[G84:040D] Quadro FX 1600M (8710w)
[G71:029B] Quadro FX 1500M (nw9440)
[GT216:0A3C] Quadro FX 880M (EliteBook 8540w)
[G96:065C] Quadro FX 770M (EliteBook 8530w)
[G84:040C] Quadro FX 570M (8510w)
[G73:039C] Quadro FX 560M (ProLiant xw460c)
[NV43:014C] Quadro FX Go540 (ProLiant xw25p)
[GT216:0A2C] Quadro NVS 5100M (EliteBook 8540p)
[G84:040B] Quadro NVS 320M (8710p)
Notes: The WT72 and the ZBook 17 G5 do have an MXM 3.1 Type B slot, but they do not comply with MXM specifications due to the lack of a VBIOS chip on the card (ZBook 17 G5) or uses a custom heatsink mount and PCB shape (WT72). The WT72 is able to initialize other MXM cards, but the ZBook 17 G5 can't as the VBIOS resides on its UEFI ROM.
Servers and desktops with an MXM slot
[GP104:1BB4] Tesla P6 (Synergy 480 G10, ProLiant BL460c G10, UCS B200 M5, UCS B480 M5)
[GM204:13F3] Tesla M6 (Synergy 480 G9, ProLiant WS460c G9, UCS B200 M4)
[GA104:24FA] Quadro A4500 SE
[GA106:25FA] Quadro A2000 SE
[GA107:25F9] Quadro A1000 SE
[TU104:1EF5] Quadro T5000 SE
[TU106:1F36] Quadro T3000M (Z2 Mini G5)
[TU117:1FB8] Quadro T2000M (Z2 Mini G5)
[TU117:1FF9] Quadro T1000 SE
[TU117:1FB9] Quadro T1000M (Z2 Mini G5)
[GP107:1CFA] Quadro P2000 SE
[GP107:1CBB] Quadro P1000M (Z2 Mini G4)
[GP107:1CBD] Quadro P620M (Z2 Mini G5)
[GP107:1CBC] Quadro P600M (Z2 Mini G4)
[GM204:13F8] Quadro M5000 SE (DeskMini GTX/RX)
[GM204:13FA] Quadro M3000 SE (ProLiant WS460c G9)
[GF108:0DF9] Quadro F500M (Z1 G1 AIO)
[AMD/ATI] Radeon HD 7650A (8300 Elite USDT, EliteDesk 800 G1 USDT, Pro 6300 AIO, EliteOne 800 G1 AIO)
[AMD/ATI] Radeon HD 5450 (8200 Elite USDT)
PCMCIA
Canopus Power Window T64V - S3 Trio64V+ with 2 MiB SDRAM
CardBus
Village Tronic VTBook - Trident CyberBlade XP2 with 32 MiB DDR SDRAM
Margi Display-to-Go 2MB - C&T 69030 with 2 MiB SDRAM
Margi Display-to-Go 4MB - C&T 69030 with 4 MiB SDRAM
MiniPCI
MSI MS-9513 - ATI Rage XL with 8 MiB SDRAM
ADLINK mPCI-8750 - ATI Rage XL with 8 MiB SDRAM
ICOP MINIPCI-VGA-Z9S - XGI Volari Z9s with 32 MiB DDR2 SDRAM
COMMELL MP-Z9S - XGI Volari Z9s with 32 MiB DDR2 SDRAM
IAC-MVGA02 - XGI Volari Z11 with 64 MiB DDR2 SDRAM
MiniPCIe
ADLINK mPCIe-8770 - XGI Volari Z11 with 64 MiB DDR2 SDRAM
COMMELL MPX-750 - Silicon Motion SM750 with 16 MiB DDR SDRAM
Innodisk EMPV-1201 - Silicon Motion SM750 with 16 MiB DDR SDRAM
Innodisk EMPV-1202 - Silicon Motion SM750 with 16 MiB DDR SDRAM
VersaLogic VL-MPEe-V5 - Silicon Motion SM750 with 16 MiB DDR SDRAM
Cervoz MEC-DIS-M002 - Silicon Motion SM750 with 16 MiB DDR SDRAM
PCMCIA 1.0~2.1 Type III
Product Specifications Size
Xircom RealPort REM56G-100 RJ-45, RJ-11 line & phone, V.90 modem 85.6 x 54 x 10.5mm
Xircom RealPort RE-100 RJ-45 85.6 x 54 x 10.5mm
Transcend TS0MCF2PC CompactFlash Type II/I 85.6 x 54 x 5mm
Billionton PCGPRSQ-B Modem 3-band GPRS, MMCX & 3.5mm TRS, MiniSIM 85.6 x 54 x 5mm
Cisco Aironet 350 AIR-LMC352 802.11b-1T1R1S, 2x MMCX 85.6 x 54 x 5mm
Toshiba Type II PC Card HDD ATA HDD MK2001MPL/MK5002MPL 85.6 x 54 x 5mm
SanDisk FlashDisk ATA Card ATA NAND 2~2048MB 85.6 x 54 x 5mm
Margi DVD-to-Go 202861-B21/00045816 MPEG-2 DVD hardware decoder, Dolby AC-3 85.6 x 54 x 5mm
Outel USB Media Remote 2.4GHz 9m range USB 1.1 receiver, CR2025 86 x 54 x 5mm
Wireless Garden StashCard WGSTA01 Drawer 85.6 x 54 x 5mm
PCMCIA 5.0~7.2 CardBus, Type III
Xircom RealPort RBEM56G-100 RJ-45, RJ-11 line & phone, V.90 modem 85.6 x 54 x 10.5mm
Xircom RealPort RBE-100 RJ-45 85.6 x 54 x 10.5mm
FANUC A02B-0303-K150 CompactFlash Type II/I slot 63 x 54 x 5mm
Newton MoGo Mouse BT 1.1/1.2 *1 2 buttons, 500DPI optical sensor, 4.2V 165mAh 86 x 54 x 5mm
Ubiquiti SR71-C 802.11abgn-2T2R2S, 2x MMCX, AR9220 85.6 x 54 x 5mm
AKE BC138 Bluetooth 2.0, USB 2.0, 2.4mm DC, D720101GJ 85.6 x 54 x 5mm
AKE BC158 802.11bgn-1T1R1S, USB 2.0 85.6 x 54 x 5mm
AKE BC468 2x USB 2.0, 2.4mm DC *3 85.6 x 54 x 5mm
AKE BC168 2x USB 2.0, 2.4mm DC, D720101GJ/VT6214L *2 85.6 x 54 x 5mm
AKE BC178 2x ESATA, VT6421A 85.6 x 54 x 5mm
AKE BC188 ESATA, SATA 85.6 x 54 x 5mm
Franklin REX-1 PDA, 64KB flash, 160x98 STN LCD, 2x CR2025 86 x 54 x 5mm
Franklin REX-3 PDA, 256KB flash, 160x98 STN LCD, 2x CR2025 86 x 54 x 5mm
Franklin REX-5 PDA, 512KB flash, 160x98 STN LCD, 2x CR2025 86 x 54 x 5mm
Xircom REX 6000 PDA, 2/1MB flash, 240x120 STN LCD, 2x CR2016 85.7 x 54 x 5mm
Citizen DataSlim-2 PDA, 2/1MB flash, 240x120 STN LCD, 2x CR2016 85.7 x 54 x 5mm
*1: HP rebrand is RJ316AA.
*2: Maximum power draw for each USB port is 5 V 0.1 A, 0.5 A is supported if the DC cable is connected.
*3: Maximum power draw for each USB port is 5 V 0.1 A, 0.9 A is supported if the DC cable is connected.
ExpressCard/54
Newton MoGo Mouse X54 Pro BT 2.0 2 buttons, 800DPI optical sensor, laser, 90mAh 78 x 54 x 5mm
Newton MoGo Mouse X54 BT 2.0 *1 2 buttons, 800DPI optical sensor, 90mAh 78 x 54 x 5mm
AKE BC718 3x USB 3.0, FL1100 75 x 54 x 5mm
AKE 2 USB 3.0 & 1 USB 2.0 2x USB 3.0, USB 2.0 75 x 54 x 5mm
AKE T718 2x USB 3.0, 2.4mm DC, uPD720202 75 x 54 x 5mm
AKE BC618T 2x USB 3.0, 2.4mm DC, uPD720202/ASM1042 75 x 54 x 5mm
AKE BC398 2x USB 3.0, 2.4mm DC, uPD720202/uPD720200 75 x 54 x 5mm
AKE USB3.0 CARD 2x USB 2.0, 2.4mm DC 75 x 54 x 5mm
AKE USB3.0 & Bluetooth Bluetooth ?, USB 3.0, 2.4mm DC 75 x 54 x 5mm
AKE USB3.0 & eSATA USB 3.0, ESATA, ASM1042+ASM1051, 2.4mmDC 75 x 54 x 5mm
AKE USB3.0 & SATA USB 3.0, SATA, 2.4mm DC 75 x 54 x 5mm
AKE BC418 2x ESATA, JMB363 75 x 54 x 5mm
*1: HP rebrand is GK872AA.
ExpressCard/34
SanDisk MultiCard Reader SDAD-109 SDHC/MMC(plus)/MSDuo(Pro/Pro-HG) 75 x 34 x 5mm
SIIG 12-in-1 R/W CE-E01012-S1 (Mini/Micro)SD/(RS)MMC(mobile/plus)/xD/MS 75 x 34 x 5mm
AKE BC638 2x USB 3.0, uPD720202 75 x 34 x 5mm
AKE BC628 2x USB 3.0, ASM1042 75 x 34 x 5mm
AKE BC618D USB 3.0, 2.4mm DC, FL1000 75 x 34 x 5mm
AKE BC618 USB 3.0, uPD720202 75 x 34 x 5mm
AKE BC608 USB 3.0, FL1000 75 x 34 x 5mm
AKE BC338 ESATA, JMB360/SIL3132 75 x 34 x 5mm
AKE BC268 USB 2.0, uPD720114 75 x 34 x 5mm
AKE BC258 802.11bgn-1T1R1S 75 x 34 x 5mm
AKE BC208 Bluetooth 2.0 75 x 34 x 5mm
CompactFlash, Type I
I-O DATA Challenger CF-USB USB 1.1, OKI ML60842 *1 63.7 x 42.8 x 11.8mm
*1: USB port maximum power draw is 5 V 0.1 A.
CompactFlash, Type II
HP Pocket Camera F1869A 0.3MP f/2.4, digital zoom ?
TRENDnet TE-CF100 RJ-45 ?
HP 56K Modem FA132A RJ-11, V.90 modem ?
EOps TV CF P-01 PAL digital TV tuner ?
GlobalSat BC-337 GPS ?
Enfora GSM0110-01 4-band GSM+GPRS, MiniSIM ?
Audiovox RTM-8000 3-band GSM+GPRS, MiniSIM ?
Dell TrueMobile 1180 09X808 802.11b-1T1R1S ?
Dell TrueMobile 300 8X767 Bluetooth 1.1 ?
NormalSD
Huawei UltraStick E2131 2-band HSPDA+HSUPA, NanoSIM 37 x 24 x 2.1mm
Huawei UltraStick E2130 1-band HSDPA+HSUPA, NanoSIM 32 x 24 x 2.1mm
Spectec SDW-821 802.11bg-1T1R1S 38.3 x 24 x 2.1mm
Spectec SDW-820 802.11b-1T1R1S 38.3 x 24 x 2.1mm
Toshiba PA3370U-1BTM Bluetooth 1.2 40 x 24 x 2mm
Toshiba PA3271U-1BTM Bluetooth 1.1 40 x 24 x 2mm
Toshiba SD-BT2 Bluetooth 1.1 40 x 24 x 2.1mm
Toshiba SD-BT00 Bluetooth 1.0b 49 x 24 x 2.1mm
HP SDIO Camera FA185A 1.3MP, 4x digital zoom 50.8 x 66 x 20.3mm
Spectec SDC-003A 1.3MP, no zoom 31 x 34 x 24.5mm
Spectec SDC-001A 0.3MP, no zoom 31 x 34 x 24.5mm
Margi Presenter-to-Go SD VGA DE-15F ?
Spectec SDRS-232 RS-232 DE-9M 62 x 24 x 2.1mm
Socket Modem MO7201-559 RJ-11, V.92 modem 40.6 x 81.3 x 20.3mm
GlobalSat SD-502 GPS, 512MB eMMC 95 x 30 x 13mm
GlobalSat SD-501 GPS 78 x 31 x 17.5mm
Spectec SDG-812 Bluetooth 1.2, GPS, MicroSD 62 x 24 x 2.1mm
Spectec SDG-810 GPS, MicroSD 62 x 24 x 2.1mm
EOps SDIO DMB Tuner T-DMB digital TV tuner 55 x 89 x 9mm
AVerMedia TV E570 DVB-H digital TV tuner ?
ELSA Telebit ETLB1-SDR 1seg digital TV tuner 33.5 x 55 x 8mm
Socket Scan Card SDSC 3P Class 2 laser barcode scanner 66.5 x 29.4 x 20mm
Socket Scan Card SDSC 3M Class 1 laser barcode scanner 66.5 x 29.4 x 20mm
Socket Scan Card SDSC 3E CMOS linear barcode scanner 61.5 x 28 x 14.6mm
MiniSD
Spectec SDW-825 802.11bg-1T1R1S 21.5 x 20 x 1.4mm
Spectec SDW-822 802.11b-1T1R1S ?
Spectec SDB-832 Bluetooth 2.0+EDR 21 x 20 x 1.4mm
Spectec SDV-841 VGA DE-15F ?
Spectec SDG-813 Bluetooth 1.2, GPS, MicroSD ?
MicroSD
Spectec SDW-823 802.11bg-1T1R1S 22 x 11 x 1mm
Spectec SDV-842 VGA DE-15F ?
Elan Mobidapter USB 1.1 ?
u-blox ADP-uSD-M2 M.2-2230-E 60.7 x 30.7 x 9.4mm
Reply 1 of 7, by Solplay
Models released in 2013 and after:
Please check the warnings for all models, they are documented here as 'Warning' notes. Model tags: Removable CPU = {R. CPU}. Removable GPU = {R. GPU}. Removable RAM = {R. RAM}. Removable storage drives = {R. SSD}. Removable internal miscellaneous device = {R. name of device}. Removable CMOS battery = {R. CMOS battery}. Removable battery pack = {R. battery}.
Satellite series
Suffixes:
-x: Generation indicator (A40-A = 1st generation, A40-B = 2nd generation)
D: AMD CPU (C40D-A)
T: Touchscreen (C40T-A)
W: 2-in-1 convertible (L9W-B)
Notes: All models in this list were not built by Toshiba.
Satellite Cxx series, low-end:
C40(T)-A/C45(T)-A {R. Socket G2/G3 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C40-B/C45-B {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
C40-C/C45-C [JP: dynabook T54] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
C50(T)-A/C55(T)-A [JP: dynabook Satellite B253/B254] {R. Socket G2/G3 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C50(T)-B/C55(T)-B [JP: dynabook B25] {R. 1x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
C50-C/C55(T)-C [JP: dynabook AZ25] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 CMOS battery}
C70-A/C75-A [JP: dynabook Satellite B373/B374] {R. Socket G2/G3 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C70-B/C75-B [JP: dynabook Satellite B37] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C70-C/C75-C [JP: dynabook AZ27/AZ67/T67/dynabook Satellite B37] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery}
C40D-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C50D-A/C55D(T)-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C50D-B/C55D(T)-B {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
C55D(T)-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
C70D-A/C75D-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C70D-B/C75D-B {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. Li-Ion 18650 battery}
C70D-C/C75D-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
Notes: The C40-C/C45-C, C50D-B/C55D(T)-B, C50-C/C55-C, C55D(T)-C, C70-C/C75-C, and the C70D-C/C75D-C uses two screws to secure their non-removable Li-Ion 18650 battery pack.
Rebadges: S40DT-A, S70(T)-A/S75(T)-A, L70-A/L75-A, L70-C/L75-C, L40D(T)-A/L45D-A, and the L70D-B. Color is two tone glossy black and gray (for -A models). Satellite Pro C40-A, C50-A, C70-A, C70-B, and the C70-C, color is single tone matte black.
Warning: The C40-B/C45-B, C40-C/C45-C, C50(T)-B/C55(T)-B, C50D-B/C55D(T)-B, C55D(T)-C, C70D-B/C75D-B, and the C70D-C/C75D-C used their main battery pack as a CMOS battery. They do not have a dedicated CMOS battery. If the main battery pack completely loses charge, the UEFI and the RTC settings will be cleared. The C40(T)-A/C45(T)-A, C50(T)-A/C55(T)-A, and the C70-A/C75-A had an optional NVIDIA GeForce 710M 2 GiB DDR3 (64-bit) with Optimus [10DE:1140] or a NVIDIA GeForce GT 740M 2 GiB DDR3 (64-bit) with Optimus [10DE:1292] (S70(T)-A/S75(T)-A and L70-A/L75-A only). The C50-C/C55(T)-C and the C70-C/C75-C had an optional NVIDIA GeForce 930M 2 GiB DDR3 (64-bit) with Optimus [10DE:1346]. The C70-B/C75-B had an optional AMD Radeon R7 M260 2 GiB DDR3 (64-bit) with Enduro [1002:6900].
Predecessor: Satellite Cxxx series.
Satellite Exx series, mid-end:
E45T-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with SATA}
E45(T)-B [JP: dynabook P54] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
E55(T)-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with SATA}
E55D(T)-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with USB+PCIe}
Notes: The E45(T)-B uses two screws to secure its non-removable Li-Ion 18650 battery pack. The E55(T)-A had an optional M.2-2242 slot with SATA.
Rebadges: S45(T)-B, U40(T)-A/U45(T)-A, U50(T)-A/U55-A, U50D(T)-A, M50-A, and the M50D(T)-A. The M50-A had an optional NVIDIA GeForce GT 740M 2 GiB DDR3 (64-bit) with Optimus [10DE:1292].
Warning: The E45T-A, E55(T)-A, and the E55D(T)-A have a soldered CR2032 battery, which is a 2-pin blue cell that can be found on the motherboard. The E45(T)-B uses its main battery pack as its CMOS battery. It does not have a dedicated CMOS battery. If the main battery pack completely loses charge, the UEFI and the RTC settings will be cleared.
Predecessor: Satellite Exxx series. There are no models that came equipped with an Ivy Bridge CPU in the Exxx and Exx series.
Satellite Lxx series, mid-end:
L10(T)-C [JP: dynabook N51] {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
L12-C {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
L15-B {R. full MiniPCIe with SATA} {R. M.2-2230 with USB+PCIe}
L40(T)-A/L45(T)-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe}
L40-B/L45-B {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
L45-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
L50(T)-A/L55(T)-A {R. Socket G3 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe}
L50(T)-B/L55(T)-B [JP: dynabook AB15/AB35/T45/T55/T65/T75/T85] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
L50-C/L55(T)-C [JP: dynabook AZ45] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
L50-D [JP: dynabook AZ45/EX/T45/T55/T65/T75/TX/X4/X5/X6] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
L40D(T)-B/L45D(T)-B {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
L45D-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
L50D-A/L55D(T)-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. CR2032 CMOS battery}
L50D-B/L55D(T)-B {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
L50D-C/L55D(T)-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
L70D-A/L75D-A {R. Socket FS1r2 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
Notes: The L40-B/L45-B, L50(T)-B/L55(T)-B, L50-C/L55(T)-C, L40D(T)-B/L45D(T)-B, L45D-C, L50D-B/L55D(T)-B, and the L50D-C/L55D(T)-C uses two screws to secure their non-removable Li-Ion 18650 battery pack. The L50(T)-A/L55(T)-A generally used Socket G3 CPUs, but most used BGA CPUs. The L50-C/L55(T)-C had an optional M.2-2280 SATA slot or a standard SATA slot depending on the configuration.
Rebadges: Satellite Pro L50-A, L50-B, and the L70-A. Some configurations of the L50-C/L55(T)-C are rebadged P50(T)-C configurations with no changes. S50(T)-A/S55(T)-A, S50D-B, and S70D-A/S75D(T)-A. The L50-D seems to reuse the Tecra C50-C's internal board layout, except for the speakers' placement and the trackpad's position.
Warning: The L10(T)-C, L12-C, L50(T)-A/L55(T)-A, L50(T)-B/L55(T)-B, and the L40D(T)-B/L45D(T)-B used their main battery pack as their CMOS battery. They do not have a dedicated CMOS battery. If the main battery pack completely loses charge, the UEFI and the RTC settings will be cleared. The L40(T)-A/L45(T)-A has a soldered CR2032 battery, which is a 2-pin blue cell that can be found on the motherboard. The L50(T)-A/L55(T)-A had an optional NVIDIA GeForce GT 740M 2 GiB DDR3 (64-bit) with Optimus [10DE:1292]. The L50(T)-B/L55(T)-B had an optional AMD Radeon R7 M260 2 GiB DDR3 (64-bit) with Enduro [1002:6900].
Predecessor: Satellite Lxxx series.
Satellite Pxx series, high-end:
P40(T)-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with SATA}
P50(T)-A/P55(T)-A {R. Socket G3 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 2-pin CMOS battery}
P50(T)-B/P55(T)-B [JP: dynabook T95] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery}
P50(T)-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 CMOS battery}
P70(T)-A/P75-A {R. Socket G3 CPU} {R. 4x DDR3L RAM} {R. 2x 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
P70-B [JP: dynabook Satellite T97/T87] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
Notes: The P40(T)-A was never released, although the U40(T)-A/U45(T)-A seems to be the same model. The P50(T)-C uses two screws to secure its non-removable Li-Ion 18650 battery pack. All P50(T)-C configurations with dual-core Skylake CPUs contain a SATA ODD bay, but all quad-core Skylake configurations do not as the space was reused to extend the motherboard for the HM170 chipset and a second fan to fit. The chassis is entirely different as well, which makes it impossible to install dual-core motherboards in a chassis meant for quad-core motherboards or vice-versa.
Rebadges: S70(T)-B/S75(T)-B and L70-B/L75-B, color is two tone glossy white and black. S50(T)-C/S55(T)-C, color is two tone matte silver and black. Qosmio X70-B. This rebadged P70-B retains the color scheme used in the Qosmio X70-A/X75-A.
Warning: The P50(T)-A/P55(T)-A and the P70(T)-A/P75-A had an optional NVIDIA GeForce GT 745M 2/4 GiB DDR3 (128-bit) with Optimus [10DE:0FE3]. The P50(T)-B/P55(T)-B and the P70-B had an optional AMD Radeon R9 M265X 2/4 GiB GDDR5 (128-bit) with Enduro [1002:6823]. The P50(T)-C had an optional NVIDIA GeForce 930M 2 GiB DDR3 (64-bit) with Optimus [10DE:1346], other configurations of the P50(T)-C had a NVIDIA GeForce GTX 950M 2/4 GiB DDR3 (128-bit) with Optimus [10DE:139A]. All P50(T)-C configurations with Broadwell CPUs contain the SATA ODD bay, but they lack a dedicated CMOS battery and used their main battery pack as a CMOS battery. If the main battery pack completely loses charge, the UEFI and the RTC settings will be cleared.
Predecessor: Satellite Pxxx series. The Qosmio Fxxx series had no direct successor starting from the Ivy Bridge era, which made the Satellite P850/P855 its indirect successor. This carried on with the Pxx series as the Qosmio Fxxx series never returned.
Satellite Sxx series, mid to high-end:
S40(T)-A/S45(T)-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe}
S50(T)-B/S55(T)-B {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
S50D(T)-A/S55D(T)-A {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with PCIe} {R. CR2032 CMOS battery}
Notes: The S40(T)-A/S45(T)-A, S50(T)-B/S55(T)-B used their main battery pack as their CMOS battery. They do not have a dedicated CMOS battery. If the main battery pack completely loses charge, the UEFI and the RTC settings will be cleared. The S50(T)-B/S55(T)-B uses two screws to secure their non-removable Li-Ion 18650 battery pack.
Warning: The S50(T)-B/S55(T)-B has a nonsensical heatsink design as it reuses the L50(T)-B/L55(T)-B's chassis; it places the fan in the ODD bay while leaving the original fan location unoccupied. The S50(T)-B/S55(T)-B had an optional AMD Radeon R7 M260 2 GiB DDR3 (64-bit) with Enduro [1002:6900]. The S50D(T)-A/S55D(T)-A had an optional AMD Radeon HD 8570M 1 GiB DDR3 (64-bit) with Enduro [1002:6663].
Predecessor: Satellite Sxxx series.
Satellite Wxx series, high-end:
W30T-A/W35T-A {R. 2.5" SATA SSD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery}
W30DT-A/W35DT-A {R. 2.5" SATA SSD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery}
Notes: Might be a Satellite Click, although it is officially known as a Satellite. All models utilize the SFF-8784 SATA connector, they are not the regular SATA slot that you see on most notebooks.
Predecessor: No predecessor.
Satellite CLxx series, low-end:
CL15(T)-B {R. M.2-2230 with USB+PCIe}
CL10(T)-C/CL15-C {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery}
CL45-C {R. M.2-2230 with USB+PCIe}
Notes: The CL45-C uses two screws to secure its non-removable Li-Ion 18650 battery pack.
Warning: The CL15(T)-B and the CL45-C used their main battery pack as a CMOS battery. They do not have a dedicated CMOS battery. If the main battery pack completely loses charge, the UEFI and the RTC settings will be cleared.
Satellite NBxx series, low-end:
NB10(T)-A/NB15(T)-A {R. 1x DDR3L RAM} {R. 2.5" SATA SSD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 2-pin CMOS battery}
Notes: The NB10(T)-A/NB15(T)-A uses two screws to secure its non-removable Li-Ion 18650 battery pack.
Rebadges: Satellite Pro NB10(T)-A, color is single tone matte black.
Predecessor: NB series.
Satellite Click series, low to high-end:
Mini L9W-B [JP: dynabook S29/N29]
10 LX0W-C/LX5W-C [JP: dynabook S40/N40]
2 L30W-B/L35W-B {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
2 Pro P30W-B/P35W-B {R. full MiniPCIe with SATA} {R. M.2-2230 with USB+PCIe}
Warning: All models in this series used their main battery pack as a CMOS battery. They do not have a dedicated CMOS battery. If the main battery pack completely loses charge, the UEFI and the RTC settings will be cleared.
Satellite Radius series, low to high-end:
11 L10W-B/L15W-B [JP: dynabook N61] {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
11 L10W-C {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery}
11 CL10W-B {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
11 CL10W-C {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery}
12 P20W-C/P25W-C {R. M.2-2280 with SATA} {R. M.2-2230 with USB+PCIe}
14 L40W-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
14 E40W-C/E45W-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
15 P50W-B/P55W-B [JP: dynabook P75] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
15 P50W-C/P55W-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
14 L40DW-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
14 E45DW-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe}
Warning: All models in this series used their main battery pack as a CMOS battery, except for the 11 L10W-C and the 11 CL10W-C. They do not have a dedicated CMOS battery. If the main battery pack completely loses charge, the UEFI and the RTC settings will be cleared.
Qosmio series
Suffixes:
Qosmio Xxx series, high-end:
X70-A/X75-A [JP: dynabook Qosmio T974] {R. Socket G3 CPU} {R. MXM 3.0 Type B GPU} {R. 4x DDR3L RAM} {R. full MiniPCIe with SATA} {R. 2x 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
Notes: Built by Quanta (Quanta BDD). MXM GPUs without an LVDS display-out are not guaranteed to work in the X70-A/X75-A. Most MXM GPUs will have contact problems with the GPU heatsink's placement as the VRM and VRAM may be in different positions. Modifications will be needed if the GPU heatsink makes no contact with the MXM GPU.
Warning: The X70-A/X75-A has a NVIDIA GeForce GTX 770M 3 GiB GDDR5 (192-bit) with Optimus [10DE:11E0]. It is recommended to use 37 W CPUs as the CPU heatsink has insufficient thermal mass for cooling 47 W CPUs and will throttle under load.
Predecessor: Qosmio Xxxx series.
Tecra series
Suffixes:
T: Touchscreen (Z40T-A)
Notes: All models in this list were built by Toshiba.
Tecra Axx series, mid to high-end:
A40-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A40-D {R. 2x DDR4 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A50-A [JP: dynabook Satellite B453/B553] {R. Socket G2 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A50-A [JP: dynabook Satellite B454/B554/B654] {R. Socket G3 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. M.2-2242 with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A50-C {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} [/i] {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
A50-D {R. 2x DDR4 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The B453 and the B553 were Japanese variants of the Socket G2-based A50-A, which did not have dedicated graphics as an option. The A50-A's Japanese variants and a few EMEA variants were sold with a single-tone matte gray color applied and a tile-style keyboard (G83C000DV2US) as an option. Some configurations had a docking port, smart card reader, fingerprint reader, backlit keyboard and a pointing stick. Configurations without these features will still have the fingerprint reader's connector present, but the rest don't. Note that the WWAN board (FMEP3G1) is installed in an ODD adapter that replaces the SATA ODD as all configurations lack PCB space for an M.2-2242 slot, except for some configurations of the A50-A which do have a dedicated M.2-2242 slot. The A40-C was never offered with Broadwell CPUs as an option, unlike the A50-C.
Rebadges: Satellite Pro A40-C, A40-D, A50-A, A50-C, and the A50-D. Tecra Z50-C and the Z50-D. The Z50-C and the Z50-D reuses the Z50-A's color scheme, which is also an option for the A40-C and A40-D.
Warning: The A50-C and A50-D can be easily bent due to their low structural stiffness. The A50-A had an optional NVIDIA GeForce GT 730M 1 GiB DDR3 (64-bit) with Optimus [10DE:1290]. The A50-C had an optional NVIDIA GeForce 930M 2 GiB DDR3 (64-bit) with Optimus [10DE:1346]. The A50-A's Japanese variants were sold without a numpad as an option (G83C000DU2JP), these variants were never offered with dedicated graphics as an option. All compatible keyboards with a numpad (G83C000DV2JP) can't be installed since the no-numpad variant's keyboard connector on the motherboard is shifted closer to the battery terminals, which means a motherboard swap and a matching palmrest is necessary to install a keyboard with a numpad. The only English keyboard (C800-US/AEBY3U02130-US/AEMTCU00130-US) that is electrically compatible with the no-numpad variant can taken from a working Satellite C840(D)/C845(D) or C40(D)-A. However, keep in mind that the screw post(s) must be removed before installation as they do not fit in the A50-A.
Predecessor: Tecra Mxx series & Tecra Axx series. The Tecra Mxx had no direct successor during the Sandy Bridge to Broadwell era, which was filled in by the Tecra R840, R940, Z40(T)-A, and the Z40(T)-B. The Tecra Axx had a direct successor during the Sandy Bridge to Ivy Bridge era, which was filled in by the Satellite Pro S750 and the S850.
Tecra Cxx series, low-end:
C40-C [JP: dynabook B54] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
C40-D {R. 2x DDR4 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
C50-B [JP: dynabook Satellite R35/B35] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 CMOS battery} {R. Li-Ion 18650 battery}
C50-C [JP: dynabook AZ35/AZ55/BZ35/BZ55/B25/B35/B45/B55/B65/B75] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
C50-D [JP: dynabook B25/B35/B55/B65/B75] {R. 2x DDR4 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: Rebadged Tecra Axx series with a single-tone matte black color applied. Options such as a fingerprint reader, smart card reader, 4 USB 3.0 ports, WWAN, pointing stick, backlit keyboard, or a docking port were not offered on these models. The C50-B's early configurations (C50-B1500/B1503)were sold with a tile-style keyboard (G83C000FF4US/MP-13R93US-356), but later configurations were sold with a chiclet-style keyboard (MP-14A76UI-354). The C50-C and the C50-D's Japanese variants were sold with a memory cover as a standard option on some configurations, but these lack an opening for the docking port. International C50-C and C50-D configurations were offered without 4 USB 3.0 ports, instead, they had 2 USB 3.0 ports on the motherboard and 2 USB 2.0 ports on the I/O board. Japanese variants of the C50-C and the C50-D offered 4 USB 3.0 ports on some configurations, and some international C50-C and C50-D configurations didn't come with a base housing that has an opening for the docking port. The copper heatsink from the dynabook P1-X6UP-EG can be installed in the C50-C and the C50-D, however, this will add weight and cause more heat to concentrate at the exhaust vents.
Rebadges: Satellite Pro R40-C, R40-D, R50-B, R50-C, and the R50-D. The R50-B was sold with a chiclet-style keyboard (MP-14A76UI-354), the C50-B's tile-style keyboard was never offered as an option.
Warning: Some Japanese variants lack an integrated webcam, microphone, WLAN (including its antennas), and Bluetooth. The C40-C's Japanese variant and the C50-C's 2016 AZ55/A and AZ55/B Japanese variant (oddly configured with a NVIDIA GeForce 930M 2 GiB DDR3 (64-bit) with Optimus [10DE:1346]) had an optional fingerprint reader (G83C000DH310). All Japanese variants excluding the C40-C's Japanese variant (G83C000HA5JP) had a tile-style keyboard (G83C000GH5JP) resembling the keyboard used in the C50-B's older configurations (G83C000FF4JP). The C50-C and the C50-D's Japanese variants were sold without a numpad as an option (G83C000GK5JP). Compatible English keyboards do not exist for these no-numpad variants, even the Satellite C40(D)-A's keyboard will not fit as its FFC cable is too short and is in the wrong position to reach the keyboard connector. Any C50-C and C50-D configuration with USB 2.0 can't accept USB 3.0 I/O boards due to the lack of a USB 3.0 FPC connector on their motherboard.
Tecra Wxx series, high-end:
W50-A [JP: dynabook Satellite WS754] {R. Socket G3 CPU} {R. 4x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. M.2-2242 with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The W50-A is a rebadged A50-A with a NVIDIA Quadro K2100M 2 GiB GDDR5 (128-bit) without Optimus [10DE:11FC], optional 15.6" 3840x2160 eDP display panel, and a optional micro serial port (requires a Molex 83421-9037 converter cable). All optional features of the A50-A are standard for the W50-A, excluding the rare WWAN option. The W50-A's motherboard and heatsink can be transferred to an A50-A's chassis if necessary.
Warning: Any attempts to install a keyboard without a numpad will not work as the W50-A was never offered with a keyboard without a numpad. The power connector is incompatible with all chargers except for the 180 W charger. Replacing the power cable with the A50-A's power cable will allow it to use lower wattage chargers but the 180 W charger will no longer fit and the power connector will sit loosely as a result. This can be fixed by swapping the W50-A's base housing with the A50-A's base housing, and charging with the Delta ADP-180HB D instead of the 180 W charger.
Tecra Xxx series, high-end:
X40-D {R. 2x DDR4 RAM} {R. M.2-2280 with SATA+NVMe} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
Notes: No dedicated GPU, no docking port, but retains the touchscreen for some configurations despite lacking a T suffix. Some configurations lack an M.2-2242 slot, which is located on the USB+audio board.
Predecessor: Tecra Zxx series.
Tecra Zxx series, high-end:
Z40(T)-A [JP: dynabook R644] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. Ni-MH 2-pin CMOS battery}
Z40(T)-B [JP: dynabook R64] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
Z40(T)-C [JP: dynabook R64] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
Z50-A [JP: dynabook R654] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. Ni-MH 2-pin CMOS battery}
Notes: The Z40(T)-A, Z40(T)-B, Z40(T)-C, and the Z50-A had an optional M.2-2242 slot and/or smart card reader. All configurations have a backlit keyboard, pointing stick, docking port, and a fingerprint reader.
Warning: The Z40(T)-A and the Z50-A had an optional NVIDIA GeForce GT 730M 1 GiB DDR3 (64-bit) with Optimus [10DE:1290]. The Z40(T)-B and the Z40(T)-C had an optional NVIDIA GeForce 930M 2 GiB DDR3 (64-bit) with Optimus [10DE:1346].
Predecessor: Tecra Rxxx series (indirectly).
Portege series
Suffixes:
T: Touchscreen (A30T-C)
W: 2-in-1 convertible (X20W-D)
Portege Rxx series, mid to high-end:
R30-A [JP: dynabook R734/R83/R73] {R. Socket G3 CPU} {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. half MiniPCIe with USB+PCIe} {R. M.2-2242 with USB} {R. Ni-MH 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R30-B [JP: dynabook R73] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R30-C [JP: dynabook R73/RX73/RZ83] {R. 2x DDR3L RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
R30-D [JP: dynabook R73/RX33/RZ33/RZ73/RZ83/R3] {R. 2x DDR4 RAM} {R. 2.5" SATA SSD} {R. SATA ODD} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery} {R. Li-Ion 18650 battery}
Notes: The R30-A, R30-B, R30-C, and the R30-D may or may not have an M.2-2242 slot, docking port, touchscreen, fingerprint reader, smart card reader, pointing stick and a backlit keyboard. The R30-A's WWAN (FASR3G0) option is rare. The R30-B's keyboard (G83C000GV5US) is the same part that was used in the Tecra A40-C and A40-D, with the exception of the screw posts' position differences (G83C000HA5US). The R30-C and the R30-D's Japanese variants were sold with a memory cover as a standard option on some configurations, but they lack an opening for the docking port. These rare configurations' base housing can't be installed in models that originally did not have a memory cover, unless the palmrest from the with-a-memory-cover variant is installed.
Rebadges: Portege A30(T)-C, A30-D, Satellite Pro A30(T)-C, and the A30-D.
Warning: The R30-A must be charged with a 90 W charger if a quad-core CPU is installed. The R30-B, R30-C, and the R30-D can be easily bent due to their low structural stiffness. Some Japanese variants do not have an optical drive bay (not a blank insert, the base housing doesn't have an opening for it), WWAN, integrated webcam, and a microphone.
Predecessor: Portege Rxxx series.
Portege Xxx series, high-end:
X20W-D [JP: dynabook V62/V72/V82/VC72/VZ42/VZ62/VZ72/VZ82] {R. M.2-2280 with SATA+NVMe} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
X30-D [JP: dynabook U63] {R. 2x DDR4 RAM} {R. M.2-2280 with SATA+NVMe} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
Notes: The X30-D had an optional touchscreen and/or an M.2-2242 slot, which is located on the USB+audio board. Touchscreens are standard for the X20W-D despite it lacking a T suffix.
Warning: The X30-D's Japanese variant may lack an integrated webcam, microphone, pointing stick and a backlit keyboard.
Predecessor: Portege Zxx series.
Portege Zxx series, high-end:
Z10T-A/Z15T-A [JP: dynabook VT712/V713/VT714/V714] {R. full MiniPCIe with SATA} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. Ni-MH 2-pin CMOS battery}
Z20T-B [JP: dynabook RT82/R82] {R. M.2-2280 with SATA} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
Z20T-C [JP: dynabook R82] {R. M.2-2280 with SATA} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
Z30(T)-A/Z35-A [JP: dynabook R634] {R. 2x DDR3L RAM} {R. full MiniPCIe with SATA} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. Ni-MH 2-pin CMOS battery}
Z30(T)-B [JP: dynabook R63] {R. 2x DDR3L RAM} {R. full MiniPCIe with SATA} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
Z30(T)-C [JP: dynabook R63/RX63/RZ63] {R. 2x DDR3L RAM} {R. M.2-2280 with SATA} {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with USB} {R. CR2032 2-pin CMOS battery}
Notes: The Z10T-A/Z15T-A, Z20T-B, Z20T-C, Z30(T)-A/Z35-A, Z30(T)-B, and the Z30(T)-C had an optional M.2-2242 slot. The Z10T-A/Z15T-A, Z30(T)-A/Z35-A, and the Z30(T)-B needs an adapter to install half-length mSATA cards as they lack the screw posts required to secure them. The Z30-D unofficially exists as a low-end configuration of the Z30-E, which normally uses Kaby Lake-R CPUs instead of the Kaby Lake CPUs found in the Z30-D. As the X30-D was intended to replace and fill in the lack of a Z30-D, the newer Z30-E was no longer positioned as the high-end ultraportable which resulted in the M.2-2242 slot being dropped from the Z30-E's motherboard. However, unlike the X30-D, the Z30-E retains the docking port as featured on the Z30(T)-C.
Rebadges: Portege WT20-B (Z20T-B), Satellite Z30-A and Z30-B.
Warning: The Z30(T)-A/Z35-A, Z30(T)-B, and the Z30(T)-C's Japanese variants may lack an integrated webcam, docking port, pointing stick and a backlit keyboard.
Predecessor: Portege Zxxx series.
KIRA series
Suffixes:
KIRA series, high-end:
2013 [JP: dynabook KIRA V632/V832] {R. full MiniPCIe with SATA} {R. half MiniPCIe with USB+PCIe} {R. Ni-MH 2-pin CMOS battery}
2014 {R. full MiniPCIe with SATA} {R. M.2-2230 with USB+PCIe} {R. Ni-MH 2-pin CMOS battery}
2015 [JP: dynabook KIRA VZ63/VZ73/VZ83/VB73/VB83/V63/V73/V83] {R. full MiniPCIe with SATA} {R. M.2-2230 with USB+PCIe} {R. Ni-MH 2-pin CMOS battery}
L93 {R. full MiniPCIe with SATA} {R. M.2-2230 with USB+PCIe} {R. Ni-MH 2-pin CMOS battery}
Notes: The L93 was a Japan exclusive, but needed a special charger (PA5201U-1ACA, 19 V 45 W) with a 3-pin half-octagonal plug for some odd reason. An adapter for this type of plug does not exist.
Predecessor: Satellite Uxxx series.
Chromebook series
Suffixes:
Chromebook series, low-end:
CB30-A/CB35-A {R. half MiniPCIe with USB+PCIe} {R. CR2032 2-pin CMOS battery}
2 CB30-B/CB35-B {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with SATA} {R. CR2032 2-pin CMOS battery}
2 CB30-C/CB35-C {R. M.2-2230 with USB+PCIe} {R. M.2-2242 with SATA} {R. CR2032 2-pin CMOS battery}
Notes: Built by Quanta. CB30-A/CB35-A = Quanta BU9. CB30-B/CB35-B = Quanta BUH. CB30-C/CB35-C = Quanta BUI. The 2 CB30-B/CB35-B had an optional M.2-2242 slot.
Reply 2 of 7, by MAZter
Portege 3xxx series:
DynaBook SS 3330V
Doom is what you want (c) MAZter
Reply 4 of 7, by Solplay
Thanks. Corrected that mistake and added the 3330V to the list. I assume that's based off the 3020CT?
I should stress the fact that whatever I've documented is not 100% correct and complete, there's just too many Japan exclusives to look out for and their compatibility with international counterparts. Could use some help for the DynaBook V486 series for example...
Reply 5 of 7, by acadiel
My compiled list of parts:
https://github.com/hexbus/toshibalaptopparts
A good source of used parts: https://www.impactcomputers.com/
NOS service parts I have that I would love to get rid of for shipping and donations (I paid $1000 for a truckload of all their Toshiba parts plus about $500 in shipping to get these from Computer Reset - so far have realized minimal % recouped from the rescue, but I did this to get stuff back into the community’s hands to fix systems!)
Due to my disability I would love to have people like the guy from NC near me (I’m in NE Atlanta suburbs) pick up a carload at a time of stuff. I just don’t have energy to do a lot of single part shipments. Most of the models for each part I have is identified. Assume anything needs a recap that has a 486 or older. I’ve had Pentium stuff work out of the box. Belt driven floppies need new belts. Some plastics are discolored due to age but many are actually new looking.
https://docs.google.com/spreadsheets/d/1B11gJ … EwmgxaseXI/edit
(Keep in mind someone that fixes T4000 series got those particular parts last week so I updated that - I know who it is and can direct you to them; they got more than they needed and may be persuaded to help fix a unit.)
I’ve fixed so many of these systems up that I know a lot of the tips and tricks too. You’ll find a 1.25mn to 1.0mm FPC floppy adapter in my GitHub as well. I’ve also put servo driven floppies in the 100 series by using a different FFC cable and drilling new holes in the floppy mount, I’ve used later backlight inverters by using VHB that had the same connectors that work just fine, etc. So many ways to fix these…..
Reply 6 of 7, by GueTech
Looking for anything related to deskstation V plus (PA2710U) or Tecra 780DVD for resto project. Desperately need a set of keys for the deskstation or someone willing to loan one so I can make copies!
Thanks in advance.
Reply 7 of 7, by Bike Forever
[/quote]
Did you have the maintenance disks for any of the machines? I have a T4500 that has a password and need the relevant disk to reset it.
