Socket 7 Motherboard Cpu
First post, by vkcpolice
Hi all I have a few socket 7 motherboards laying around that have Pentium MMX 200 in them
This is a little to fast for my liking and want to know if I can fit a 75mhz Pentium Cpu in them? I'm not sure what Cpu types will work with socket 7 the slower the better thanks
Reply 1 of 4, by Joseph_Joestar
Note that you can slow down a Pentium MMX using SetMul. Toggling the various test registers as well as L1 and L2 caches can give that CPU quite a bit of range.
Check out this video by Phil for more details.
My retro stuff
Reply 2 of 4, by Doornkaat
You can use a 75MHz Pentium on all boards that can set a 1.5x multi and 50MHz FSB.
Reply 3 of 4, by Kalle
Generally it shouldn't be any problem. However you have to check for each board anyway as you need to set the jumpers accordingly (voltage, etc).
