(SOLVED) 286 "CHIPS" mainboard with missing parts...
First post, by Locutus
Hello retromaniacs 😉
I got another cool looking mainboard that is missing parts 🙁
This time a 286 with "CHIPS " chipset.
Please let me know if somebody has such MB/photo of it/any info, that can help me identify missing ICs, jumpers, etc...
Thanks !
974.49 KiB
Reply 1 of 64, by mR_Slug
I tried searching in UH19 for this board (link below in sig) but we don't have it, so can't help with the jumper settings. I can tell you it has the C&T CS8220 PC/AT compatible CHIPSet, details:
http://66.113.161.23/~mR_Slug/chipset/chipset … 455&3=4533#2043
This is one of the very first chipsets so has some limitations. But you have a fast motherboard for '85-86.
Please can we use your picture in the UH19 DB?
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 4 of 64, by Anonymous Coward
Did you try powering it on? Sometimes the chips that go in the empty sockets aren't needed.
Reply 5 of 64, by Locutus
Miracles happen - the story will continue....
Stay tuned 😉
    862.83 KiB
Reply 6 of 64, by Locutus
mR_Slug wrote on 2021-09-13, 19:24:
Here is the photo of complete mainboard.
1.21 MiB
BIOS:
PHOENIX_286_BIOS_Plus_3.10.02.7z
16.78 KiB
51 downloads
Reply 7 of 64, by Locutus
The mainboard completes POST but there is another problem...
It has a very old PHOENIX BIOS with 'external' setup program.
But in order to run it I need to boot the system... I only have a 1.2MB 5.25" drive.
Looks like this MB has the drive 0 set to 360kB by 'default '.
Can somebody confirm it ?
    640.45 KiB
Reply 9 of 64, by Deunan
Locutus wrote on 2023-07-20, 19:08:
It says seek failure, does it actually seek the floppy on boot? That is, the heads move forward and back?
- If the heads don't move then you have some kind of FDC issue, try a different card maybe.
- If they do move then yes, it would indicate the BIOS is expecting to find a 40-track drive (so a 360k DD one).
Reply 10 of 64, by Locutus
majestyk wrote on 2023-07-20, 20:22:
You´re extremely lucky that someone pillaged the cheap/common logic circuits and spared the PALs!
Absolutely true !!!
I guess it is because I got it from the university... and a guy who took them out knew what he was doing... and most likely just needed them 😉
Reply 11 of 64, by Locutus
Deunan wrote on 2023-07-20, 20:25:
It says seek failure, does it actually seek the floppy on boot? That is, the heads move forward and back? - If the heads don't m […]
Thanks for the answer.
YES, the FDD makes a 'proper' seek . FDD + used controller are 100% OK.
When I disconnect the drive, I get the message about failed FDD O seek (just like about FDD1 in the attached picture).
Oh man, 360kB dives are extremaly hard to find around 🙁
Reply 13 of 64, by Deunan
Locutus wrote on 2023-07-20, 20:42:
The mobo is not THAT old, it's already using semi-integrated chipset solution, and BIOS ROM is 2x 27C128, there's plenty of space for some setup code.
What keys did you try to enter BIOS? Did you try CTRL+ALT+ESC? If you can't find a 360k drive (and the SETUP program itself) it might be easier, and cheaper,to look for alternative BIOS for this mobo.
Reply 14 of 64, by Locutus
Deunan wrote on 2023-07-20, 22:34:
Hi.
Maybe, instead of 'OLD BIOS', I should have used 'primitive BIOS ' 😉
This one, for sure, needs 'external' software for setup just like here:
How to enter old Phoenix 386 BIOS?
I've already tried 286 BIOS PLUS from Tulip's MB (with similar chipset) with no success .
I only have four 27C128 EPROMs , therefore trying alternative ones (erasing/programing) is pretty time consuming 😉
Reply 16 of 64, by weedeewee
fairly certain you could also attach a 720K DD drive and boot from that.
and aside from a speed difference... which should be handled by the multi io board, I don't see a reason why booting from a 1.2 or 1.44 HD floppy drive wouldn't work.
Do not ask Why !
Reply 17 of 64, by Predator99
You can add a XT-IDE Bios and boot from a HD or CF that you have prepared in another PC or Emulator. Xt-IDE does not care about the CMOS settings. No need to get the floppies running.
Or you use another main BIOS, MRBIOS for 286 may be a good choice.
Reply 19 of 64, by Deunan
Locutus wrote on 2023-07-20, 23:47:
Since you have a way to program chips, can you do a dump of the existing BIOS ROMs and link them here?
Also, here's an AWARD BIOS for this mobo, that I know will respond to CTRL+ALT+ESC because I have this exact mobo and it came with this BIOS. It does have some limitations though, there is no support for user-definable HDDs I'm afraid. So either you need to find something that matches the BIOS parameter table, or you need to use XTIDE. Or SCSI. My mobo works with MFM drive and controller but the SCSI card worked nice as well.
EDIT: Don't let the filename fool you, the date is from the last 16 bytes, where the first long jump is. The actual date of this BIOS is 10/20/87, this is AWARD 3.03.
