First post, by fsmith2003
I have the below card. The larger capacitors are marked as 10, 6s, then some random numbers (0G2) which I am sure is a date code of some sort. The smaller 2 capacitors in the bottom left though are marked 22, N, 6. I know the larger ones are 10uf 6V but what would the smaller ones be? Are they 22uf 6V or would it be 22nf 6V because of that N marking on there?
1.79 MiB
Reply 1 of 6, by BitWrangler
Well the one of mine I can find, is a different PCB, the voltage reg is rotated 90 degrees upward, and in that area on that one, I don't have cans, but surface mount black block types ones that just say 22-16 on them.
Reply 3 of 6, by BitWrangler
It's probably a roll of the dice, have not had to get into it yet myself, some hints to try in this thread, several of which are less work than cap replacement to try first..
Help me repair a Voodoo 3 3000 PCI.
