First post, by Macca70
Hi all
Just after some advice on replacing capacitors on these graphics cards , I have a GF 6600GT an FX5500 and an Ati 9550 , I know they're not worth anything really but I wanted to get some practice soldering on these as I have a couple of old motherboards need caps replacing and would rather use these for practice than the motherboards.
I have a decent soldering station and everything else I need to do the soldering and have plenty of experience soldering wiring etc on vehicles, the orientation and reading the uf and volts on the std electrolytic caps is no problem but what about the surface mounted aluminium ones , I'm not 100% on the markings and what I should be buying for them.
The 9550 has a clearly busted cap next to the heatsink but boots fine into windows but has artifacts on screen the whole time.
The FX5500 looks like it has a missing SMD (photo) but I don't know what to replace it with ? This one doesn't show a screen at all and doesn't boot. (I tested it before I realised it had a tiny missing cap)
The 6600GT has bulging caps , boots fine and goes into windows fine , plays 3d apps ok but with artifacts.
If anyone could help with what the tiny cap missing is off the FX5500 that would be great and whether you think that might be the problem with it not booting ?
Sorry for sounding like a noob but I kind of really am when it comes to this tiny soldering , should be some fun trying to get them to work though , I've even resorted to watching some you tube tutorials and practising soldering and desoldering on some old circuit boards, maybe you can teach an old dog new tricks ? hah
Thanks in advance
Lee
Build 1
Win98se
Dell Dimension XPS B866r
1.0ghz PIII
512mb 800mhz Rdram
Asus GF2 Ti 64mb
Build 2
XP System
Lian Li PC65 USB
Athlon 64 x2 4800+
Asus A8N SLI Premium
2gb Corsair XMS 2
Asus 6600GT 256mb
Reply 1 of 7, by Macca70
more pics
Build 1
Win98se
1.0ghz PIII
512mb 800mhz Rdram
Asus GF2 Ti 64mb
Build 2
XP System
Lian Li PC65 USB
Athlon 64 x2 4800+
2gb Corsair XMS 2
Asus 6600GT 256mb
Reply 2 of 7, by cyclone3d
The LB31 that is missing on the FX5500 is some sort of inductor/coil. For 100% assurance of correct replacement, you would need to find another of the same card and measure it out of circuit to get an idea of the original value.
Chances are that there are other LB?? labeled ones in the same area and they would most likely be the same exact as LB31 is supposed to be.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 7, by Macca70
Realised I posted the wrong pic
Build 1
Win98se
1.0ghz PIII
512mb 800mhz Rdram
Asus GF2 Ti 64mb
Build 2
XP System
Lian Li PC65 USB
Athlon 64 x2 4800+
2gb Corsair XMS 2
Asus 6600GT 256mb
Reply 5 of 7, by Macca70
The closest I could find to LB 31 is this at LB22 , so if I desolder LB22 and check it's resistance ?
What component would I search for to buy this ?
Also the question on the surface mounted Alu caps , could you help me there ?
Thanks very much for your replies , greatly appreciated.
Build 1
Win98se
1.0ghz PIII
512mb 800mhz Rdram
Asus GF2 Ti 64mb
Build 2
XP System
Lian Li PC65 USB
Athlon 64 x2 4800+
2gb Corsair XMS 2
Asus 6600GT 256mb
Reply 6 of 7, by cyclone3d
Oh, that's funny. They just used a 0 ohm resistor on the other LB?? spots from what I can tell... basically just a jumper.
See here for the aluminum surface mount capacitors:
https://forum.digikey.com/t/smt-electrolytic- … tage-rating/974
YMF7x4 Guide
Reply 7 of 7, by Macca70
Oh wow , I didn't even realise it had a 0 on it 🙄 That's easy enough then.
That link is great , thank you very much for your replies , I'll get the bits ordered and repost if I manage to fix them ( or blow something up 😂😂)
Lee
Build 1
Win98se
1.0ghz PIII
512mb 800mhz Rdram
Asus GF2 Ti 64mb
Build 2
XP System
Lian Li PC65 USB
Athlon 64 x2 4800+
2gb Corsair XMS 2
Asus 6600GT 256mb
