First post, by quicknick
Hey folks,
Recently got this:
895.79 KiB
FasMath, Atmel chipset and MR.BIOS? Three 'firsts' for me so I had to have it! 😀
The Varta had its way with it so at some point in the future I'll have to do a proper repair of the affected area, but fortunately for now everything works.
Did a bit of research on the Atmel chipset, and it seems to be a clone/remarking of OPTi 82C391, which is a bit disappointing. Oh well...
Unlike more common BIOSes, the MR.BIOS doesn't have an ID string, or I haven't looked where I should, so I couldn't find anything about the manufacturer.
The model is also missing from TH99, UH19 and UltimateRetro (but I think this won't be for long, so I'm attaching the BIOS and a full-res pic).
ST0386-WB VER2.0.rar
38.68 KiB
30 downloads
Reply 1 of 9, by weedeewee
nice. does it still function given the damage the battery did ?
Do not ask Why !
Reply 2 of 9, by snufkin
quicknick wrote on 2021-11-12, 21:33:
Given the damage to the power and keyboard traces that's really good to hear. I like the red resistor packs. Any manufacturer markings on the back of the board?
Reply 3 of 9, by weedeewee
snufkin wrote on 2021-11-12, 22:09:
thanks. 😁
Do not ask Why !
Reply 4 of 9, by quicknick
None whatsoever. Only the manufacturing date: 9149.
Board works (up to BIOS, at least). Played a bit there and I absolutely love the MR.BIOS, finally understood why it's so much sought after 😀
Reply 5 of 9, by Horun
Think it is same as this one: https://www.ultimateretro.net/en/motherboards/965 the picture by pixeh matches...
Deksor will want the BIOS for it !
Reply 7 of 9, by Zerthimon
Get the DLC-40 and 80MHz crystal generator next and it will be four 'firsts' 😀
Reply 8 of 9, by quicknick
Horun wrote on 2021-11-12, 23:56:
Yeah, exact same board! Atmel 40391 confirmed to be the same as OPTi 391...
Deksor wrote on 2021-11-13, 00:38:
Added everything to UR.net 😀
Thanks!
Zerthimon wrote on 2021-11-13, 10:04:
Got one of those (or is it a 33 that works no problem at 40?). Crystal, guess I can grab one from another board 😁
Reply 9 of 9, by Zerthimon
Alternatively, you can get a DLC-33, if you don't wanna change the crystal. Your Fasmath is 40MHz, so I thought upgrading the whole thing to 40MHz would be a better option.
