Usb gamepad DOS
First post, by Bhuthogg
Hiya. (again)
I have an old pc that has usb 1.1 and was wondering if I can get a usb "SNES style" pad drivers in DOS ?
I did Google this and most results show gravis.
Reply 1 of 4, by Lylat1an
Making DOS recognize USB was a pain when I tried it last year, I ultimately gave up on it.
If you don't want to use an "Advanced Gravis" pad in your game port, there's a program called SNESKEY that allows you to connect a real SNES pad to a parallel port.
There are schematics online for building your own adapter, or you can order one from Raphnet.
https://www.raphnet-tech.com/products/snes_co … rport/index.php
Reply 3 of 4, by Bhuthogg
I'm at a certain stage now where I've discovered loading usbuhci.com + usbjstik.com + joykeys which I believe were all written by Bret Johnson..
This for the most part works it's going to require some tweaking in the buttons.
However I'm still in need of a bit help on how to get these files to autoload on boot that would save me a lot of time between reboots ?
Can anyone assist ?
Scrap that.. .this works at c:\ prompt for up down left right tied to cursors and space and enter all works great. However on loading Duke3d or doom it won't do any of the keypress'
Reply 4 of 4, by oso2k
Bhuthogg wrote on 2022-01-02, 18:56:
I'm at a certain stage now where I've discovered loading usbuhci.com + usbjstik.com + joykeys which I believe were all written b […]
Can anyone assist ?
Brett is active on bttr forum and he has his own forum. I don’t know if he has an account here.
http://bretjohnson.us/forum/
