First post, by 386SX
Hello,
can someone suggest a functional and precise CPU usage tool for Win 98 First Edition? I did try a sort of Task Manager clone but I think had problem giving real CPU usage values which I'd like to monitor to test multimedia video card accelerations. Any real time software with good reading capabilities?
Thanks
Reply 1 of 5, by Hoping
Windows 98 SE has it's own resource monitor, a task manager, and a network monitor they aren't installed by default you have to select it on the personalized install. But I don't know about Win98FE, never used it since the 90's
Reply 2 of 5, by 386SX
I'm trying to search a good one but I had mixed results on some in the past where sometimes they seems to work ok other times they gave impossible readings (like 0% CPU). I'd like one software enough good to have always the right values of the real cpu usage like other o.s.
Reply 3 of 5, by Warlord
You can see if Proc EXP will run. This is the oldest version I have, never tested it on 1st edition but it runs fine on Vanilla Second edition.
Theres also WinTop from the 95 kernel Toys. It might show CPU usage of a program.
    ProcExp.7z
    1014.22 KiB
    83 downloads
Reply 4 of 5, by Tiido
This version is a bit newer than one I had been using (10.20 vs 10.1), I'll try it sometime on my machines.
