First post, by GabrielKnight123
I can't find a brand or model for the card in the pictures below I've read the back of the card as best I can make it out and I have most jumper setting set but I need help for 5 settings
J8 and J9 refer to the speed setting of either: SPD 0, SPD 2 *, SPD 4 or SPD 6 I have it set to SPD 2 * but I'm not sure what this speed setting is for its after the VL-IDE and ISA-IDE settings
J20 and J21 I have it set to SPP, the other options are EP? (? something), EPP/ECP I can't read the header above SPP in the picture so I don't know what this is for probably the LPT
J31 and J32 I have it set to W83757 the other two options are W8?777 and W8?7?7 it's the one in the pic of the top right hand corner, what is this one for
I have J11 set to "on" ISA-IDE ALE enable, what is ALE
The last one is J13, 1-2 ISA IDE ?? ???? HIPS, I don't know what this is either but I have 1+2 closed
Does someone have a manual, if you know this card and jumpers thanks if you can tell me the settings it's being used with a 486DX2 66 and VL video card
Reply 2 of 4, by root42
snufkin wrote on 2022-01-13, 12:32:
Not an exact match, but I think it's close: https://stason.org/TULARC/pc/hard-disk-floppy … HANCED-IDE.html
Looks very close. There are also a few Promise controller that are VERY similar. J13 doesn't match on this one, though. I would guess that J13 on this one is perhaps for the optional BIOS ROM, which is not populated on this board.
YouTube and Bonus
Reply 3 of 4, by snufkin
Just looked up the datasheet for the W83777 and that says it was backward pin compatible with the 83757 (on this board), 83767 and 83787. So I guess those jumpers control some configuration strap pins depending on which controller the board has. E.g. the 83777 supports 2.88MB floppy drive but the 83787 only support 1.44MB.
Don't know about the Address Latch Enable or the ISA IDE (C?)hips jumpers.
[seems to be something about ALE getting reused as both a Spindle Sync signal and the cable select CSEL signal, e.g. http://www.alexandrugroza.ro/microelectronics … face/index.html 'Principle of Operation'. Still don't know if it should be enabled or disabled. ]
