ASUS p3c-d, looking for high res pictures
First post, by CachoAlpuy
Hi, i have the HP variant of the p3c-d motherboard and im looking forward to make the conversion to the asus p3c-d motherboard so i can use the ASUS Bios, for that reason im looking for high resolution pictures of the following area:
photo5127543704603699959.jpg.
I need to be able to see the resistor values.
Thanks to everyone who can provide something.
Reply 1 of 33, by dionb
I might be able to, I think I have the retail version.
That said, wasn't the HP version green?
To get you pics good enough to see resistor values I need to use a microscope (no decent camera with macro function), which gives a much smaller field of view than this pic. Could you perhaps indicate exactly which resistors you need?
Reply 2 of 33, by CachoAlpuy
dionb wrote on 2022-01-20, 15:20:
Yes, the board is green, than photo was taken from the internet of the retail version.
This is the zone i need, maybe you can make a picture with a camera and if some values cannot be seen i ask you later.
Thanks!
Reply 3 of 33, by dionb
Here's the best I can do without the microscope:
The attachment IMG_20220121_162137.jpg is no longer available
Hope it's good enough - I can read most of the SMD stuff ...
Reply 4 of 33, by CachoAlpuy
dionb wrote on 2022-01-21, 15:28:
It looks perfect, i will start spotting the differences, maybe i ask you some values later.
Thank you!
Reply 5 of 33, by pshipkov
I tried before but didn't work.
Dionb, did you try to push the vanilla board past its specs ?
133 fsb with tulies at least ?
retro bits and bytes | DOS media library
Reply 6 of 33, by dionb
pshipkov wrote on 2022-01-22, 05:34:
No, I have two P3-933EB on it running at 133MHz FSB (in-spec). GIven how fragile these P3C-D boards seem to be I don't want to push it. I have enough other ones for that.
Reply 7 of 33, by pshipkov
Altered one of the two HP-Kayak-crippled P3C-D boards here and it does not start now. Kind of expected that, since the last time i tried few years ago on another board resulted in the same issue.
There are 3 areas that i am still unsure about.
@Dionb, can you clarify the values of these elements please, or provide pictures of the areas ?
Maybe this will make the difference.
Reply 8 of 33, by CachoAlpuy
pshipkov wrote on 2022-01-24, 04:14:
Altered one of the two HP-Kayak-crippled P3C-D boards here and it does not start now. Kind of expected that, since the last time […]
Did you remove the HP HW monitoring circuitry?
The eeprom ic is different, i think that the asus one is smaller, maybe you should solder a socket.
Did you add r231a resistor?
Also there is a resistor under the dip switches on the asus that must be removed on the hp board.
Searching on the web i saw that someone made it work removing the hp circuitry and soldering a 256KB eeprom.
Reply 9 of 33, by pshipkov
Stripped the entire HP circuitry.
I already had EEPROM socket in place from previous mods.
Yes, using the ASUS BIOS.
Yes, removed the resistor under the dip switch packages.
Can you point on the picture the other resistors you mentioned ?
Reply 10 of 33, by CachoAlpuy
pshipkov wrote on 2022-01-24, 19:03:
Stripped the entire HP circuitry. I already had EEPROM socket in place from previous mods. Yes, using the ASUS BIOS. Yes, remove […]
These are the difference i spotted, some are missing components, some are different values. Maybe there are more components with different values.
Reply 11 of 33, by dionb
Gave it my best shot again, two out of three look better, but that third one on bottom left is just a blur.
The attachment IMG_20220127_204001.jpg is no longer available
The attachment IMG_20220127_204026.jpg is no longer available
The attachment IMG_20220127_204044.jpg is no longer available
Reply 13 of 33, by MadYoshi
Hi,
I looking for high-res pictures from the back of the board. Especially the area from the northbridge. ASUS P3C-D or the HP Kayak XM600, it doesn't matter.
Reply 14 of 33, by karakarga
Are you really sure about, the problem is resistor related? Did you get a spare bios chip and make it programmed with a pic programmer?
Reply 15 of 33, by dm-
got this board.
no need to cut any circuit. just reflash the bios with 2x asus image.
hp bios image is for 4mbit intel fw hub eprom, just flash asus double sized flash and you'll be good.
was
The attachment 5389103046811842245.jpg is no longer available
now
The attachment 5389103046811842247.jpg is no longer available
Reply 16 of 33, by pshipkov
i obtained p3c-d board recently, waiting for delivery. hope it comes as one piece.
but regardless of that, thank you for the excellent hint, didnt realize this is the problem.
i dont feel great now, after destroying 2 of these hp boards with attempted hw mods, and third one under surgery (that i have to revert now)
Reply 17 of 33, by dm-
i soldered a socket for flash just in case, and did all flashing in my programmer.
also soldered a pin headers for speaker, leds, reset, power on/etc...
that's all.
checked with tualatin 1.4 and it's working. yes, cpu microcodes are missing and hw monitor compaining but working fine.
overall, the board is slower than any bx 440 dual boards -(
Reply 18 of 33, by pshipkov
same here, socketed flash chip.
i spent time with the hp versions of the board.
as you said, it is in general slower, but in some tests outdoes bx440, for example - opengl graphics and in some heavy cpu/mem loads.
these are clock to clock 1000/133mhz tests with best bios settings on both.
but since i was using the hp bios which is stripped from most tweaks i felt there may be perf left on the table with the p3c-d.
also, was not able to explore overclocking past 133mhz fsb because the board is capped to that.
Reply 19 of 33, by dm-
there is no option for overclocking in Asus bios.
maybe it's hidden and can be unlocked, anyway, will be nice to have latest cpu microcodes installed.
