First post, by JustRob
I got a PC case that’s pretty much perfect for a PC I’m building. Unfortunately, one of the plastic slots that are used to attach the front panel to the case has broken in two pieces. I’ve tried putting it back together with the strongest glue I have, but since the plastic is so thin it will never hold for long.
It’s going to be pretty much impossible to find a replacement that matches exactly, so I’m wondering, has anyone been in a situation like this before and come up with any creative solutions?
Reply 1 of 9, by TrashPanda
got a picture so we have an idea of what part we are looking at ?
Reply 2 of 9, by JustRob
Something like this, dunno if it’s the exact same. One of the inner plastic surfaces has broken off.
Reply 3 of 9, by TrashPanda
JustRob wrote on 2022-01-21, 17:09:
Well .. being an Aussie I would hit that with Liquid Nails and then gclamp the front panel in place till it dried.
You are not removing the front panel from the case again after tho. Liquid nails as the name suggests does exactly what you think it would do 🤣, you can glue iron sheeting to the walls and roof with it and itll stay put and be nearly impossible to remove once its cured.
Reply 4 of 9, by JustRob
Yeah that is problematic as I don’t intend to do something that makes me unable to take it apart ever again. I know myself, eventually I’m going to want to change things up.
Reply 5 of 9, by TrashPanda
JustRob wrote on 2022-01-21, 17:29:
You could just glue the clip back onto the panel, I doubt it'll ever be as strong as it was originally but if I wanted to remove it again then I would do that first, liquid nails (Don't know what they call it outside of Australia) is pretty damn strong when it dries so it might be ok if you dont mess with it too often.
Reply 6 of 9, by Doornkaat
Are those Lian Li parts? If so:
Doornkaat wrote on 2021-12-30, 19:02:
They're avaliable on thingiverse. I've had my brother print some for me and they turned out pretty well. 3D print is certainly strong enough.
https://www.thingiverse.com/thing:215612
Reply 7 of 9, by JustRob
Yeah, don't have a 3D printer tho.
Anyway, the panel connects pretty snugly with just the remaining three clips, but I have to adjust the drive bays a bit with a small screwdriver while putting the panel on. So I guess it's not a huge problem for now. Would be nice to have replacements as a possibility tho.
Reply 8 of 9, by Repo Man11
JustRob wrote on 2022-01-27, 00:36:
There are people printing them and selling them on Ebay: https://www.ebay.com/p/1504947488
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
