First post, by turbooo
I’m trying to install a PCI IDE controller on my MB-1433UHT-A, as it does not have an onboard one. I’m using a Promise Ultra 100 but when the card is installed the system hangs during the POST procedure, after completing the memory check. I see the last code on the diagnostic card is 53 (Award 4.50G BIOS)
Things I’ve tried so far, with the same result:
- moving the card to different slots
- move video card to ISA so it the controller card is the only one on PCI
- swap for a FastTrak 66
- swap for a 2940UW
- swap out the RAM
Once the card is removed the system is able to complete POST. Also no issue with a VLB controller card.
Any thoughts what might help get past this issue?
