First post, by Iarsin
Hi, I cannot achieve to get the ISA NIC working on Windows 95 OSR2.5. Also I cannot find a newer driver for Windows 95 AM2100/AM1500t. The Mainboard got a chip AMD Am79C960 on it https://www.amd.com/system/files/TechDocs/16850.pdf
The NIC works with Linux and the Lance.o Module. I was already online with lynx on a 2.4x based live Distribution. The System got 32MB RAM and a Base 1 Terratec Soundcard. I disabled the soundcard, due to resource conflicts on io and irq, dma. But also if I try to set the resources manual without any conflicts, the computer freezes, and the setting disappears on reboot. If i let it automatical configured, it doesn't freeze the computer, but pinging isn't possible, despite the right ip values for ip address, mask, dns and gateway. Also automatic retrieval doesn't work for the IP address over DHCP. But the device manager then doesn't show any conflicts.
Do have to install the NIC with the same values as in Windows 95 also in DOS via autoexec.bat and config.sys with an DOS driver and installer? I'm clueless.
