First post, by stalk3r
Pretty much as the title suggests, I bought an MPU-401 breakout box but I don't have an interface card for it. Will it work if I hook it up to the MIDI UART port of a sound card? I also have a MT-32 module. I know I can connect this directly to a sound card, but want to test the MPU-401.
Reply 1 of 7, by jesolo
Which breakout box did you buy? Can you post a pic?
Reply 4 of 7, by stalk3r
That I know, I was just wondering if a sound card's UART port would suffice to bring it to life
Reply 5 of 7, by Pierre32
stalk3r wrote on 2022-02-11, 21:17:
Sadly no.
There are reproduction interface cards, but they don't support all breakout boxes. Some homework required: https://texelec.com/product/lo-tech-mif-ipc-b/
More reading:
https://nerdlypleasures.blogspot.com/2013/06/ … te-vintage.html
https://nerdlypleasures.blogspot.com/2010/03/ … land-mt-32.html
Reply 6 of 7, by AppleSauce
No you'll need that LoTech mif ipc clone card or a roland original and one of these unless you want to fry it.
https://www.amazon.com/Your-Cable-Store-DB25- … l/dp/B07JPDWNKY
Reply 7 of 7, by stalk3r
AppleSauce wrote on 2022-02-11, 21:59:
This is the way. Thanks
