First post, by Nexxen
Someone had some interest and I decided to post some pics.
I put it in a machine and it was picked up, but I have no compatible cable to test if the output is there and it actually works.
If anyone needs a better pic to troubleshoot/repair send a PM.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 1 of 19, by Nexxen
pt 2
Reply 2 of 19, by Nexxen
pt 3
Reply 3 of 19, by Nexxen
pt 4
Reply 4 of 19, by Nexxen
pt 5
Reply 5 of 19, by Nexxen
pt 6
Reply 7 of 19, by Deunan
Mini-DIN for composite output maybe? BTW it should be possible to create a simple resistor-based DAC to make it somewhat VGA-compatible. I did something llike that for CGA, except I used FPGA devkit that had VGA output with resistor DAC, and I also implemented correct brown color while at it, and manual V/H polarity switching, but otherwise it was pass-through. If that still doesn't work, put OSSC between that "VGA" and monitor to bring it up to correct frequencies. And while it seems like a lot of work, I had those on hand but no CGA/EGA monitor. At least I know my card works.
Reply 8 of 19, by Nexxen
Deunan wrote on 2022-02-21, 16:53:
Learning finnish sounds less bleak. 😀
Ok, I'm not touching this board before I'll be able to understand this 100%.
Reply 9 of 19, by Predator99
Nice card! Invest 6€ in a logic analyzer to see the picture 😉
https://www.youtube.com/watch?v=PPi47e0SOUg
https://www.youtube.com/watch?v=FvCjBuS9NBc&t=1s
6€ MCE2VGA replacement - CGA/EGA/HGC capture with logic analyzer
Reply 10 of 19, by Deunan
For the price, it's great. But otherwise it has rather bad sampling jitter - I guess clock rate is matched to 640 pixels so it looks OK-ish in games but terrible in text mode. And then even in graphics mode there seems to be issues with detecting edge of the picture when the entire screen is moving sideways...
Reply 11 of 19, by Predator99
Yes, it has some erros in text mode with 640 pixels buts its readable.
In graphics mode 320x200 its 100% accurate and playable. The scrolling artifacts you noticed are related to Commander Keen and are well known.
But you need a fast PC.
Whatever, there is no cheaper way to get a EGA picture on your screen.
Reply 12 of 19, by Nexxen
I love you people!
I mean it 😀
I used this 286 for a lot of games and tons of memories of many games I played are popping up.
Transparent like those cheap SBs 😀
Reply 14 of 19, by Nexxen
Moravec wrote on 2022-02-23, 15:38:
Hi @nexxen - I have posted more pics of the compaq deskpro 286 here
Compaq Deskpro 286
Appreciated!!!
Reply 15 of 19, by bitslasher
Hi @nexxen - apologies for the necro-post, but I was wondering if you got this EGA card working? I am curious if you were able to find out anymore about it.
By dumb luck I stumbled upon a Compaq EGA monitor. I already have restored an original 1986 Deskpro 386/16. It seems those were offered with EGA as an option. I am trying to figure out what the "correct" original EGA card would have been in that model. Would it have been the Enhanced Color Graphics II?
Reply 16 of 19, by Moravec
@bitlasher - I have this EGA card, which has Compaq on the Rom Chip:
381.42 KiB
127.76 KiB
Reply 17 of 19, by PC Hoarder Patrol
bitslasher wrote on 2023-07-11, 02:46:
Maybe refer to the QRG for your system - https://web.archive.org/web/19961225160549/ht … e1/desktop.html
or
the card settings page - https://web.archive.org/web/19961226055120/ht … 2/appavide.html
Reply 18 of 19, by Nexxen
Hi! No problem, it's sometimes better to re-animate an old post 😀
No, I didn't. I just asked a friend to test it and it is still @ his place, IIRC. He couldn't remember either if he tested it. I guess that age isn't a good factor at some point - 🤣
It was indeed seen by a board I put it in.
Mine was in a 286, if you have a 386 maybe a later version or a different card completely. I'm not an expert on the subject.
I'm glad you have a restored 386, have lots of fun with it!!
Reply 19 of 19, by bitslasher
Moravec wrote on 2023-07-11, 05:03:
Hi Moravec, somehow I just got back on this and found your post. Thank you for uploading such a clear picture!
