First post, by fando
Hey there, Dosbox is working great so far on Debian testing. It's running Sentinel Worlds without any fundamental problems.
However, the scaling doesn't seem to work. Going to full-screen SDL and messing with the options in dosbox.conf doesn't increase or decrease the default scale. It stays the same size no matter what combination of options I turn on. I'm checking here if the issue is known. The config options with hashes are the ones I've messed with:
[sdl]fullscreen=true#fullscreen=falsefulldouble=true#fullfixed=truefullfixed=false#fullresolution=1024x768#fullresolution=800x600fullresolution=640x480#fullresolution=320x240output=surfacehwscale=1.00#hwscale=4.00(sic)[render](sic)aspect=falsescaler=normal2x#scaler=advmame3x
The notes said it was built with gcc4.0 without "pic" support. I do some SDL programming and I don't think my hardware is an issue. I might've overlooked something in the docs, but they're all over the place. (The wiki is nice though.)
