First post, by Almoststew1990
- Oldbie
So I'm planning on messing with sound cards and stuff and I am thinking it will probably upset my otherwise blank Windows 98 install.
Can I install W98, chipset and graphics drivers, then plug the CF card into my main PC and copy its entire contents (including hidden folders) into a folder on my PC. And then copy that back up onto another CF card and have the same PC boot from it as if nothing happened?
Assuming I format both drives the same way with same partitions and same drive labels...
