First post, by BreakPoint
- Member
Recently I found this motherboard. It's fully functional but CPU socket broken. It's not possible to connect H/S. Since board not of a great value I decided to check is it possible to replace socket.
And actually it is possible! All you have to do is heat up board with IR-preheater. I used Gordak 853. Smells terrible but do the job.
