First post, by kirikl
- Member
I just received mobo, which known one of the best for overclock.
Was working in previous configuration as 115x5.5 = 633 with zero problems, BUT it was with standard IDE HDD drives.
I'm using Startech IDE-SATA converter, which is working great on 100x6 = 600mhz (K6-3+ 600). 110, 115 bus - is getting me weird stuff and refusing of loading full autoexec.bat, not windows 98 either....
Is SATA-IDE configuration sensitive to overclock?
I'm using A-DATA 120GB SATA SSD. again - No problems of using it at normal 100mhz bus speed, when PCI and AGP is 66 and 33 as well.
Other specs:
AMD K6-2+ 570 modded as K6-3+, External cache off
256-768MB depends
SATA 120 SSd
IDE HDD 160@137GB
Voodoo 3 2000 16MB
SB16
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
