First post, by shmongu
I am trying to play a game.
The file folder CANDYLND is under the following path:
C:\OLDGAMES\
The folder CANDYLND contains two things:
CANDYLND.cue
CANDYLND.bin
After correctly mounting the CANDYLND folder, I try to IMGMOUNT the .bin and get "use parameter -size bps,spc,hps,cyl to specify the geometry."
Am I going about this in the right way? If so, how do I find the geometry parameter from the file?
If not, what should I do?
Thanks in advance from a mega-newbie.
Reply 2 of 4, by shmongu
Thanks jmarsh! I followed your clear directions and gave the following commands:
C:\CANDYLND>IMGMOUNT D CANDYLND.cue -t cdrom
The console then read:
MSCDEX installed.
Drive D is mounted as C:\OLDGAMES\CANDYLND\CANDYLND.cue
I am unsure how to proceed since there is not an .exe file to run. I only have the .bin and .cue. What comes next?
Reply 3 of 4, by AlaricD
The D: drive *SHOULD* be accessible and have the actual files (including any .EXE) in it. If D: still shows a .BIN and .CUE as contents, there's something weird going on.
