Better video card options for this Super Socket 7 build
First post, by Jasin Natael
I have a baby AT SS7 build that is working great, but I would like to have a bit more era appropriate video card in the system.
I know the common recommendations for such a system like Voodoo 3 and MX440.
The thing is, I already have another system with a Voodoo 3 and i would like to do something a bit different with this one.
I have tried all the AGP cards currently in my modest collection.
All of the nVidia cards seem to work to one degree or another but ALL of the ATi cards have moderate to major issues.
I am currently using a FX5500 AGP card from BFG and it works flawlessly and is 100% stable even at 2x speeds, which is usually hit or miss on a MVP3 based board.
But performance isn't spectacular and the card is just too new, and too boring for my taste.
I would like to try maybe a TNT2 Pro card (the only ones I have are m64 based and as such crap)
Or maybe a Geforce 2 GTS, maybe a Geforce 2Ti, maybe a Geforce 3?
I have two or three MX440 cards but again they are all OEM 64bit cards. And they suck as well.
What are some other suggestions from you good people?
Here are the basic specs of the machine and a few benchmarks for those that are curious
Tekram P5MVP-B4-1M (Baby AT)
Patched BIOS, 1MB Cache - Fastest RAM timings, AGP 2X forced. L3 Cache enabled
VIA MVP3 Chipset
AMD K6-2+ 550mhz (100x5.5 2.0v)
Micron PC133 CL2 256MBx2 @100mhz (512MB)
BFG Nvidia FX5500 AGP 4x @ 2x - Stock Clocks, 45.23 Driver (FX5200)
256MB DDR 128bit
WD Caviar UDMA2 IDE Primary Master
Lite-On 52x CD-ROM - Secondary Master
Aureal Vortex 1 PCI
Onboard USB 1.1
VIA 4.1 4.35 AGP installed in "turbo" (2x) mode
Windows 98SE No unofficial patches
Direct X 8.0a
3dMark 99:
Default Benchmark 800x600x16
2292 3dMarks
6359 CPU Marks
3dMark 2000:
1422 3dMarks
Final Reality:
3.16 (AGP test 29.73 MAX VRAM)
Unreal (OG version, not Gold) D3D, 800x600x16
3 pass castle flyby:
AVG: 23 fps
High: 49.5 fps
Low: 7.6fps
Reply 1 of 86, by PC-Engineer
The question is what you want to achieve.
If you want to stay period correct, then you can take a Matrox G400 (MAX) or a TNT2/GF256/GF2 or a Radeon and maybe combine it with a V2 (SLI could be difficult for Baby-AT, because of space). 3DFx has the best 3DNow! drivers, but you don't want a V3 for that. Maybe you still have a V4 or V5? I think the best try would be a GF2 (GTS/Pro/Ti ) with early drivers.
If you want to have the fastest combination, you only have to try and test with your portfolio and different driver versions. Later drivers unfortunately lose the 3DNow! support and have more CPU overhead.
Note that most baby AT boards provide the AGP voltage 3.3V via converters themselves and thus provide a very limited current supply for the graphics card. Many boards have problems with the power requirements of a GF256. This depends on whether the graphics card still has its own converters for 3.3V (from 5V) and distributes the load over the two rails on the AGP.
Many SS7 AT boards can be fed with an ATX power supply, which would then provide enough power on the 3.3V rail, but not all of them use the 3.3V from the ATX power supply, but their own converter.
Personally, I'm also thinking about a similar scenario right now and favor a combination of G400 MAX and V2 SLI. There are certainly faster combinations.
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 2 of 86, by Ydee
Isn´t used CPU a bit weak for GPU like GTS, GF2Ti or GF3? These cards IMHO needs something more powerful like PIII/Athlon/Duron.
TNT2 (Pro, Ultra) would be better option in my eyes for this build, or maybe GF2 MX(400) and GF4MX440 128bit. Personally have similar build (only with K6-2 and Ali 5) paired with Savage4 (AGP) and V3 2000 (PCI) and even for V3 2000 CPU (500MHz) doesn´t have enough power.
Reply 3 of 86, by Jasin Natael
PC-Engineer wrote on 2022-09-03, 06:29:
The question is what you want to achieve. […]
Thanks for the reply.
As I stated in the OP I already have a k6-3+ system with a Voodoo 3, I also have a PII system with another Voodoo 3. So I am set on those.
I don't really want to blow a bunch on a Voodoo 2 SLI setup but that should be interesting when you get it done.
In the meantime I ordered a cheapish TNT2 Pro, and I probably will snag a ATI Rage128 Pro as I've never really messed with them.
Reply 4 of 86, by Jasin Natael
Ydee wrote on 2022-09-03, 09:33:
Thanks for replying.
I have a K6-3+ @600mhz that is running a Voodoo 3 3000.
I also have a PIII 733 with a Voodoo 3 2000 (PCI vs AGP why they aren't swapped)
I am sure there is a bottleneck on the K6, I'm not too bothered by it. I used to have the 3000 in my PIII 1GHZ build. It was well enough matched, just wanted to repurpose that case.
In the meantime I ordered a TNT2 Pro and will probably snag a AIT Rage 128Pro just to play with.
Reply 5 of 86, by Sphere478
Agp: I have had very good luck with radeon 9000-9800 series on ss7
My record runs were on a 9800 pro but it and ss7 agp have power issues. My radeon 9000 does pretty good though. In many of my boards.
My 9800 seems to like my freeway mobo very well
Sphere's PCB projects.
Reply 6 of 86, by Jasin Natael
Sphere478 wrote on 2022-09-05, 19:49:
I wish I had a working 9700/9800, unfortunately I do not.
I have a Radeon 9250SE in 128bit memory bus, but I couldn't get it to work properly on the Tekram board either.
I might try to get all of the AGP cards working in the Soyo board, since it's the same chipset. Just to see how they line up.
Reply 7 of 86, by Sphere478
A radeon 9700 seems like it might be a very good match for ss7 lower power draw and aux connector. Also slightly older. But still good performance.
Would be worth a try. I don’t have one to try myself though.
Reply 8 of 86, by Jasin Natael
Sphere478 wrote on 2022-09-05, 19:59:
Yeah I am sure they would perform well.
I would think that it would be a pretty notable bottleneck though, I don't think even a very fast K6-3+ can provide the bandwidth for a 9700.
But I could be wrong.
Reply 9 of 86, by Sphere478
Jasin Natael wrote on 2022-09-05, 20:02:
Yeah I am sure they would perform well. I would think that it would be a pretty notable bottleneck though, I don't think even a […]
I played halo all the way through on my k6-3+ at 1280x1024 on my 9800 pro.
Reply 10 of 86, by Repo Man11
Sphere478 wrote on 2022-09-05, 20:39:
I installed Halo on my M930 with a P4 2.8/533/512, Win98, a Creative Live 5.1, one gig of DDR, and a 9800SE with Omega drivers (8 pipelines!); the more crowded areas had serious lag. Maybe because I had vsync disabled? I just bought an X800 Pro because I'm stubborn and I want to play Halo on this machine rather than one of the others I have that will play it fine as is.
Reply 11 of 86, by Jasin Natael
Oh for sure, I am sure that it works well. I'm just not sure that the 9800 Pro can really stretch it's legs with the K6-3+
For example one of my retro laptops has a 9700 Pro (mobile of course) It has a Pentium M @ 1.70ghz and seems to be a decent match.
Reply 13 of 86, by Jasin Natael
Sphere478 wrote on 2022-09-05, 21:17:
That’s fine the 9800 pro isn’t the point, stretching the k6-3+’s legs is the point :p
Yeah I get you.
Currently running some benchmarks on the K6-3+ 600 Soyo board to get a somparison, forcing AGP with Powerstrip.
Going to run with Radeon 7200 SDR32MB , Radeon 7500 DDR 64MB, Radeon 9250SE 128Mb (128bit), and I can throw in the FireGL 8800 (Radeon 8500) if it would be interesting?
Reply 14 of 86, by Repo Man11
I did these just for you. Quadro 2 Pro, 7.76, the rest is in the screen shots. The early driver is a big help - I think 3D Now support was dropped rapidly after that.
Reply 15 of 86, by Jasin Natael
Repo Man11 wrote on 2022-09-05, 22:09:
Awesome!
Thank you. It looks like that 112mhz bus speed it making a difference as well.
I have been busy benchmarking some Radeon cards on my K6-3+ system. 600mhz but otherwise very similar system to the k6-2+
I have had to force AGP 2x with Powerstrip
They are somewhat surprising results:
Radeon 7200 SDR 32mb:
3dmark 99 800x600x16
2522
7724
3dmark 2000 1024x768x16
2549
Radeon 7500 DDR 64mb:
2676
7774
2552
Radeon 9250SE (128bit) 128mb
2832
7646
2577
So it seems to me like I have hit a bottleneck.
So yeah, i would say the driver overhead you are talking about it a real threat. I am using 6.2 Catalyst for all of these cards.
It looks to me like nVidia with it's earlier drivers really make a big difference in performance. That and the aforementioned bus speed.
Reply 16 of 86, by Sphere478
That quadro 2 is a geforce 2 the geforce 2 and 3 have some sort of weird driver thing that lets them get really high 3d mark scores.
Does this translate into games?
Reply 17 of 86, by PC-Engineer
The GeForce 2 is a very good card for DX7 and earlier in combination with 3DNow! and suitable drivers (12.x or lower), and partly faster than some DX8 successors. It also does not put much load on the AGP, which actually makes it an ideal partner for SS7. The good benchmark results are also reproducible with Q2 and Q3. Later drivers lose the 3DNow! support, which causes the K6-2 and above to lose some performance in games, in addition to the larger overhead. ATI's support for 3DNow! was rather poor compared to nVidia or even 3DFx.
Comparison w(ith) and w/o(ut) 3DNow! support
https://www.anandtech.com/show/160/10
https://www.tomshardware.com/reviews/amd,68-3.html
So i recommend to make sure, that your Graphics card and it's drivers makes use of 3DNow!
Also interesting:
https://www.voodooalert.de/board/forum/index. … 9774#post449774
Reply 18 of 86, by Repo Man11
I decided to stop being a slacker and mod the chip. The result was typical, but it won't do the hoped for 672 MHz. A giveaway that this card is CPU limited is that overclocking it makes no real difference in the score.
Reply 19 of 86, by Jasin Natael
Repo Man11 wrote on 2022-09-06, 21:13:
Still a nice little performance bump.
I might try to get higher FSB settings working with my chip.
I doubt that I can hit your overall clock speed, but I might squeeze a few more out than I have now.
Currently trolling ebay for a cheapish Geforce 2 card....you have me convinced 🤣.
Anyone know if the Dell OEM ones are any count? The GTS models? Or better suggestions?
They seem to be everywhere, I seem to remember reading somewhere that they were ghostbuilt by some decent board partner. But can't remember which one.
I can't for the life of me find my old Asus Geforce 2Ti and my 256 is sadly dead 🙁
