First post, by drew2020
Want to build a Win98 PC around Asus P3B-F mb but I need a case. Looking for a case recommendation.
thanks
Reply 1 of 2, by Shponglefan
If you want something inexpensive and relatively modern, check out the Fractal Designs Focus G line: https://www.fractal-design.com/products/cases … /focus-g/black/
They have a pair of 5.25" bays which is perfect for CD or DVD drive, plus 1.44MB floppy. Plus you get modern benefits of increased case airflow (dual front 120mm fans, one rear), bottom mounted PSU, decent cable management, etc.
I have a couple of these cases I use on a Windows 98 and XP build respectively.
    469.8 KiB
    Windows XP Build
    361.84 KiB
    Windows 98 Build
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
