First post, by Sphere478
Settings for use on older systems with no auto detect. I detected this on my tyan s1564d
Sphere's PCB projects.
Reply 1 of 8, by AlessandroB
Is it safe to use this type of drive in a computer as a disk? I don't think they're designed to have the head whip around continuously like a desktop disk, but to write sequential dates as they were snapped by the camera.
Reply 2 of 8, by BetaC
AlessandroB wrote on 2022-12-19, 07:28:
They were at least able to do iPod level thrash, though that's mostly at the lower end.
Reply 3 of 8, by Jo22
This also worries me a bit.
I suppose DOS is not as cruesome as Windows 9x here.
DOS loads its drivers at boot, one by one, then it lets the HDD on its own.
16-Bit Windows or GEM/GEOS are similar, I guess.
They idle along happily ever after.
Edit: The table is fascinating, though! Over 11k cylinders in CHS mode! Yikes. 😬
Reply 5 of 8, by Jo22
Sphere478 wrote on 2022-12-19, 14:14:
I actually was not able to get it going on the particular model mobo that I am trying probably has a 500 MB limit
That's a possibility, yes.
Maybe it's also related to ATA-2 specification or 8-Bit transfers.
One reason why XTIDE uses CompactFlash is, that Compact Flash is related to PCMCIA and PC Card, I think.
Compact Flash specification allows certain things like 8-Bit transfers, which normal PATA HDDs nolonger support.
It's one of the many reasons it was so popular in embedded and single-board computer (SBC) use.
Anyway, the Micro Drive is related to the Compact Flash ecosystem.
Maybe it can do these things often, too.
Hm.. I don't really know how to help. Not sure what the problem is.
Hm. You can try these utilities, maybe they provide clues which features are available/absent.
WHATIDE:
https://web.archive.org/web/20160411025456/ht … isc/whatide.php
IDE Diag:
Re: IDE disk-on-module + 386
NSSI:
https://www.navsoft.cz/
Anyway, it's not much, I know.
Maybe other users have further ideas.
Good luck. 🙂👍
Reply 6 of 8, by douglar
Any problem using EZ Drive? It will autodetect the CHS for you, and the volumes and geometry will be compatible with USB readers.
Reply 7 of 8, by Ryccardo
BetaC wrote on 2022-12-19, 07:30:
...and, IIRC, Apple openly said that you could repartition any iPod (temporarily losing its functionality as a player) to use as a boot drive for your PowerPC Mac 😀
Or, of course, you could have turned on disk mode and used it as a "normal use" external drive...
Reply 8 of 8, by Sphere478
Jo22 wrote on 2022-12-19, 18:39:
That's a possibility, yes. Maybe it's also related to ATA-2 specification or 8-Bit transfers. […]
WHATIDE:
IDE Diag:
NSSI:
Good luck. 🙂👍
It’s not a biggie. It does work in a 8-bit isa xt-ide
I mainly wanted to document the screenshot for others who might want to use it.
I actually did end up humorously killing one of my microdrives in a speedsys benchmark. The funny part is that it was the new one that I just got not the one I have booted ME from for years. Lol
