First post, by pshipkov
Have two of these boards.
One of them stopped recognizing the keyboard recently.
Socketed the chip. Put new one(s) - same problem.
Tried to compare voltages, signals, etc. between the two, but not able to figure anything meaningful.
Reaching to the local hardware experts here for ideas.
Thanks in advance.
high-res board photo
retro bits and bytes | DOS media library
Reply 1 of 13, by TheMobRules
Does the keyboard controller from the board that doesn't recognize the keyboard work on the other one? If so, that would discard the chip being blown.
Also, I assume you have checked for continuity across the fuse over the keyboard connector?
Reply 2 of 13, by pshipkov
Yes, the keyboard itself is working.
I put a socket for the keyboard controller and tried few chips that work. The result was the same - no keyboard recognized.
The 4 fuses around the keyboard connector fine.
Reply 3 of 13, by majestyk
There are 4 (or 3?) inductors, but only one fuse (F1 or F2).
Reply 5 of 13, by TheMobRules
Maybe it has nothing to do, but I wonder what that voltage regulator below the keyboard chip does (LT1076)… after all that board is 5V only right?
Reply 6 of 13, by majestyk
It´s for the onboard CPU "IBM 486BL3" that needs 3.3V.
Reply 7 of 13, by pshipkov
That voltage is actually slightly different for the BL3 CPU between the two boards. Which is strange.
(A while ago i asked another member here who owns Cougar board to provide the voltages he sees. He is about to come around on that.)
Reply 8 of 13, by Warlord
are you reading voltage coming from the keyboard connector?
Reply 10 of 13, by Warlord
Multimeter in the AT keyboard socket or the leads on the back of the AT keyboard socket. It is possible you have a broken AT keyboard connector or you have broken solder joint there. Cuz like if you plug in keyboard and you get no power than thats your problem. If it gets power but it doesn't input any characters thats a seperate problem. But both could be casued by a bad connector.
Reply 11 of 13, by pshipkov
There is voltage on pins 2 and 4. That is on both boards.
The interesting part is that on one of the boards that voltage is 4.7V the other is 5.1V. These voltages are in line with what the VRMs output on the two boards.
That's why i asked that other member here to clarify what voltages he sees.
Reply 12 of 13, by TheMobRules
pshipkov wrote on 2023-01-17, 20:24:
Hmmm maybe something is pulling down the 5V line... at 4.7 you are already a bit below the expected range of many chips (usually 4.75 to 5.25). Do you also get 4.7V at the power or ISA connectors?
Reply 13 of 13, by majestyk
Are you sure that 4.7 / 5.1V are at the VRM output? This would mean they overvolted the IBM 486BL3 CPU heavily.
Where did you measure the voltage? At C17 or at the ferrite inductor in the step-down circuit?
