First post, by dos-moe
- Newbie
Hello guys!
I am a new member to this forum. My name is Moe and I am from germany. My english my not be perfect. Sorry.
A current project is one of my many retro mainboards trying to repair it.
It's a 286 rev 2.0 NEAT mainboard from the brand Peacock.
So far:
I was able to fix all broken traces ( I guess). On the photos below, it looks like a mess on a closer look 😀
I partly removed a ISA slot, to be able to clean and repair the broken traces. I replaced the CPU socket and some caps next to the power connection (P8, P9).
At the moment a 25mhz CPU is installed. The board can start with Quartz Crystal Oscillator from 24 to 48mhz.
Now to the problems. The sympthoms are:
After powering up, the display stays black and the post analyser card shows the digits 06, which stands for "initialized system hardware". Then I have to wait about 10 seconds, then pressing the reset button and the system comes to life. It posts on screen and the analyser card shows the code 35, which means I can enter the setup.
But as soon as I try to set up a HDD (Type 49 , 504mb), after rebooting the screen stays black and the post analyser card stops at the code 06 again. This happens with different ISA HDD controller cards. Pressing the reset button doesn't help. The board just stops working at this point and seems to be stuck.
At this point is my personal limit. I am not a electrician, just a retro hardware hobbyist. So I need your help. What could cause this issue? I own a soldering station, a multimeter and a multi function tester for components.
The mainboards front side:
https://link.shutterfly.com/XQRPXAVVPBb
Repaired traces:
https://link.shutterfly.com/H90GhAXVPBb
Mainboard with ISA cards installed + hdd adapter with SD-card:
https://link.shutterfly.com/FtZvEh4VPBb
Sticker with Rev 2.0 NEAT-286 on the backside:
https://link.shutterfly.com/IEL2MFZVPBb
CPU socket backside pins:
https://link.shutterfly.com/kTZ1ML1VPBb
Chipset:
https://link.shutterfly.com/xcH5eA2VPBb
Post analyser card showing code 06:
https://link.shutterfly.com/JRY9Nk3VPBb
Post analyser card showing code 35:
https://link.shutterfly.com/Rk1hpI5VPBb
Boot Screen:
https://link.shutterfly.com/j285Um6VPBb
Setup pace one. It shows 65535kb of extended memory with 4mb installed!? Maybe that is a sign for the error source...
https://link.shutterfly.com/3iqMlt8VPBb
Page two of the setup screen:
https://link.shutterfly.com/RRrutAgWPBb
Post analyser codes explained (06 for Phoenix bios):
https://link.shutterfly.com/m2ZWsuiWPBb
My tools:
https://link.shutterfly.com/Y27Ml1jWPBb
Thank you very much!
