First post, by Ensign Nemo
- Oldbie
I recently pickup up one of those parallel port devices for Covox and Disney Sound Source sound in DOS. I would like to make a DIY enclosure for it, so that I'm not handling a circuit board all the time. I would appreciate some advice for a cheap and easy solution. My requirements are the following:
1. Cheap
2. Easy to cut holes in. I would like to keep three cable attached to it that come out of the enclosure: (1) a parallel port extension cable, (2) a USB cable, (3) an audio cable.
3. Easy to open the top. The device has switches to change modes, so I want convenient access to them.
I looked up DIY electronics enclosures and people recommended a variety of things, such as Tupperware, cardboard boxes, glasses cases, etc. I think I found a couple of options at a thrift store today, but would like some feedback before I use them as an enclosure. I bought a wooden box and a Nintendo DS case that both look like they could work:
A DB-25 cable should fit into either of them, although the DS case would be pretty tight:
Here is everything attached to the Covox. I laid it on top of the wooden box to give you an idea if what I'm thinking of. The wood is thin enough that I could cut openings in the ends for the cables to stick out of:
I have a few questions for the electronics gurus:
1. Is static a concern? The DS case is lined with felt, so I think that could be a potential problem.
2. Should I line the bottom of it with anything? If I go with wood enclosure, would it help to put a bit of padding on the bottom of it?
3. Do you have any suggestions for securing the circuit board in place.?
I'm leaning towards the wood enclosure. It is big enough to fit everything. The top slides off, so I could change the switches easily. I should be able to cut holes in it without too much trouble. It also has a nice pretty pink ribbon, so my Covox would look fabulous (-:
I would appreciate any feedback or suggestions. Thank you in advance.
