List of open-source PC hardware projects
Reply 40 of 62, by BitWrangler
For half a second I was excited, was hoping it was an adjustable PLL
Reply 41 of 62, by BitWrangler
ISA EEPROM flashing card...
Not sure of licensing on this one, by publication in this form we may assume I think that one has the right to build it for personal non-commercial use, probably the PCB layout is copyrighted though, so would advise respinning that if you want to make more than personal requirement. http://web.archive.org/web/20050403215640/htt … er/flasheng.htm
Reply 42 of 62, by weedeewee
BitWrangler wrote on 2021-08-11, 14:33:
Original article is still online at https://www.heise.de/ct/artikel/Pannenhelfer-286064.html in german.
Do not ask Why !
Reply 43 of 62, by BitWrangler
Great! Also searching ISA brings up a lot of interesting stuff.
Reply 47 of 62, by wiretap
Retro OTA Broadcaster to send Composite Video + Stereo Audio to an old CRT that only has an antenna. Programmable via I2C for which channel frequency you want. (VHF, up to 3 channels switchable via the jumper block -- use only one jumper in the vertical position to select channel -- A maps to CLK0, B maps to CLK1, C maps to CLK2 when programming chip U3) Range is short, maybe 50 feet or so. Check legality of broadcasting on the frequency you choose to program it to. It's made to connect a short F-type coax antenna to for broadcasting, so a small extendable whip antenna will be fine. Uses a 5VDC 5.5x2.1mm jack power supply (1A or greater).
Based on the Isotope Engineering PiMod-Zero for the RF circuit, my Full Can Clock Oscillator project, and the Wideband RF Power Amplifier datasheet for chip U2 and antenna output on the board.
Not tested, boards and parts ordered.
Circuit Board Repair Manuals
My Project List
Reply 48 of 62, by digger
@wiretap As cool as that project is, wouldn't it always be preferable to solder a bypass in the CRT's circuitry to feed a composite signal directly into it, without going through the tuner? Extreme purists might disapprove, but adding a composite mod to TVs that only had RF inputs would be a period-correct thing for tech-savvy tinkerers to do, even back in the day, right?
I guess it might be still be cool to play with if you want to do some actual broadcasting, though.
Reply 49 of 62, by wiretap
Of course going directly into the CRT's circuitry would work, if you wanted to tear apart the TV and trace it down. Most people don't want to do that though.
My Project List
Reply 50 of 62, by BitWrangler
digger wrote on 2021-09-09, 07:45:
Need a repro "Pickles and Trout" board or something, not that it looks terribly complicated, the info of where in each set to hook it up is probably more valuable... https://hackaday.com/2021/07/27/black-and-whi … al-input-board/
Edit: Don Lancaster in his classic work "The TV Typewriter Cookbook" expounds upon methods to get video into a TV in Chapter 8... tinaja.com is his website and he offers this free download of his book in pdf format. https://www.tinaja.com/ebooks/tvtcb.pdf
Edit2: We have some current experimenters like Jorge, whose schematics speak the universal language of electronics in his video, even if youtube autotranslate mangles his Spanish a little. Re: HOMEDADE CGA&
Reply 51 of 62, by shimart
I was looking for a wavetable board for my sound card and found it.
https://github.com/hkzlab/DWAVE_MIDI_Wavetable
151.47 KiB
Reply 52 of 62, by RayeR
I also made a SMD xtal adapter for old boards with DIP sockets, but it was just a side project to fill free space on 10 x 10cm panel 😀
I also finished and tested my 4MB WRAM memory expansion module for Matrox Milllennium II (fixed ver 1.1), mentioned in this thread:
Re: Matrox Millennium II 16MB - exists? If so, why?
Gigabyte GA-P67-DS3-B3, Core i7-2600K @4,5GHz, 4GB DDR3, 128GB SSD, GTX670(GF7900GT), SB Audigy + YMF724F + DreamBlaster combo
Reply 54 of 62, by wiretap
I guess we can add the PicoPSU to AT adapter to the list: ATX to AT pico Adapter! + Fan Headers, -5v, and 3.3v (Released)
48.28 KiB
73.52 KiB
My Project List
Reply 55 of 62, by Jura Tastatura
wiretap wrote on 2022-02-23, 14:34:
I wish someone would make similar but ATX-ATX adapter with -5v. That would be neat. Or something like that smart ATX-AT adapter, but for ATX mobos.
Reply 56 of 62, by matze79
Well, a PCB with 2 Connectors and just a 7905 is bit useless/expensive.
You can simply buy 2x 0805 Capacitor, solder it on 7905 legs and solder -12V to In, -5V to Out and GND to GND.
And put Stuff inside shrink tubing.
Less then 2-2,50€
Co2 - for a endless Summer
Reply 58 of 62, by Sphere478
Did we ever figure out how to get flat pin to fit this?
At OP:
Re: New clock gen for tyan s1564d
Low Profile PCI Riser For AT/ATX Motherboards (Research)
Socket 5/7/SS7 (Motherboard) Tweaker (Released)
Socket 5/7/SS7 (Processor Shim) Tweaker (Released)
Socket 5/7/SS7 (Voltage Interceptor) Tweaker. (Beta)
Sphere's PCB projects.
Reply 59 of 62, by wiretap
Sphere478 wrote on 2022-04-28, 04:52:
Did we ever figure out how to get flat pin to fit this? […]
At OP:
There was never any right angle flat pin female board mount connector manufactured. The solution is to swap out the motherboard side connector, or use the adapter on a board that already has the square pin connector.
My Project List
