Reply 40 of 49, by Nexxen
Ujeen wrote on 2024-11-23, 22:54:
rasz_pl wrote on 2024-11-23, 09:19:
Ujeen wrote on 2024-11-22, 01:28:
I replaced all MOSFETS
thats impressive dedication for a lowend nforce2 (they all die, chip is factory defective) board 😮
This is mostly for fun. I like soldering, breaking, fixing things ... kinda my leisure time "dzen"
I so understand. There is a specific term/concept in psychology (that I can't remember).
As long as it makes you feel good.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 41 of 49, by butjer1010
[/quote]
[/quote]
Next in line 😀 😀 😀
Reply 42 of 49, by Ujeen
Guys, just an update: As it was suggested above I bought Duron 900Mhz and some no-name cooler for it. I made sure radiator is properly secured and …. despite that I used some contemporary substitutions for all those old VRM’s MOSFETs and I recaped the whole VRM and I flashed in the new BIOS ….after all this the motherboard worked and Duron survived!
I’m sure mobo was all good even before I started replacing things.
The whole issue was just … me 😀
(Now I got two working Socket-A motherboards)
Reply 43 of 49, by rasz_pl
What most likely happened here:
The attachment drawing.png is no longer available
Looking at Socket 370 and 462 datasheets they look pretty much identical. Socket step height is defined as 2.55mm. I was sure AMD cores were lower than Intel ones, but AMD lists Athlon height at 1.917mm REF and 1.777mm minimum, Pentium 3 1.787mm minimum so no difference there. The only option is either putting radiator backwards, or using Tualatin radiator - those have either none or much shallower cutout because minimal heat spreader height is above socket step.
Reply 44 of 49, by Ujeen
In my case I double checked that, so must be fine
Reply 45 of 49, by PC@LIVE
Great, congratulations the work in the end was a success!
Although it is possible that the first two CPUs, would still be among us, with a little more attention ⚠️ in installing, I imagine that now you will be curious to try a third Athlon XP, but if the Duron 900 is enough, you can very well leave that one.
For my part, I hope to restart soon, a Gigabyte GA-7VAXP and an Athlon XP 2800 333, we'll see hopefully soon the final result, a success would be perfect.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 46 of 49, by Ujeen
PC@LIVE wrote on 2024-11-28, 21:21:
Hope all works for you ! I've subscribed to your topic, so will be checking how it goes 😀
Reply 47 of 49, by Nexxen
rasz_pl wrote on 2024-11-28, 06:18:
I bought a board with a Athlon 1400. Came with heatsink slanted like that and a lot of thermal paste.
When I removed the h/s I wasn't believing it actually survived.
Cpu is 100% ok and well. The core didn't crack which is almost as incredible.
Reply 48 of 49, by butjer1010
Nexxen wrote on 2024-11-29, 00:02:
I bought a board with a Athlon 1400. Came with heatsink slanted like that and a lot of thermal paste. When I removed the h/s I w […]
Looks like it depends a lot from a motherboard. I never manage to destroy any XP Athlon on my Abit NF7! Even without a cooler.... Many times i tried without cooler just to see if the board will beep or not, and i have never destroy the CPUs i tried.
Reply 49 of 49, by myne
That's impressive.
There were plenty of crispy AMDs back then.
Not something to emulate.
I built:
