ATi RagePro drivers and software
Reply 40 of 54, by marxveix
New 3DCIF game to play with? ToCa 1 and Ati Rage II (Cif?)
This ToCa game does not use ati3dcif/ati3dcor.dll,not@cif
I think its Direct3D game, other card options work@R2R3
Ok i tested lowest Rage2 card that i have with D3D / 3DCIF
Its Rage2+DVD PCI 2MB and 3D resolution 400 x 300 x 16
Default ATi uses 15bit color, 16bit is selected for 3 pictures
Someone can test it for Rage 2 non + cards, i have 2+ / 2c?
2MB and max resolution was 400 x 300x16@these games
If possible use Rage 2+ 4MB card or Rage 2C 4MB or more
Thank you!
G-Police can be better with AGP cards and first real AGP card from ATi was original ATiRagePRO
ATi Xpert@Play from 1997 is one of my favorite Rage Pro cards and my first Rage Pro AGP card.
https://www.shacknews.com/article/100535/game … t-g-police-1997
https://commons.wikimedia.org/wiki/File:ATI_X … _1997_front.jpg
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 41 of 54, by douglar
I had a chance to test with 4 cards:
I tested on a K6-3 400 w/ 256MB ram, L3 cache disabled because it wasn't stable under windows.
I first tested with catalyst 4.3 and then installed the 5.40x2611x3D.7z driver.
I ran the MaxPerf batch file.
I tested 4 programs
  • 3d mark 99 @ 800x600x16
  • 3d mark 2k @ 1024x768x16
  • Quake 2 crusher @ 800x600x16
  • Quake 3 demo @ 1024x768x16
If a bench mark produced any unexpected result, I'd run it again to verify the result.
The attachment Untitled.jpg is no longer available
Direct X
  • Rage Pro: Very nice improvements in direct 3d. 40-50% =)
  • Rage XL was pretty much unchanged. Perhaps these "one ram chip" cards are bandwidth limited or maybe I need to check the driver or the direct X installation.
  • Rage II didn't work in Direct 3d using the 5.40x2611x3D driver, but the Cat 4.3 drivers merely produced a slide show of rendering errors, so yeah.
OpenGL
  • 20% improvement on Quake 2. Quake 3 took a step backwards in frame rate and image quality, but Quake 3 wasn't going to be playable at 1024x768 on this system with either driver.
  • Rage XL also saw a 20% improvement on Quake 2. None of the Quake 3 scores are what I'd call "playable".
  • Rage II didn't work with open GL on either driver
Reply 42 of 54, by marxveix
douglar wrote on 2025-10-31, 12:24:
I had a chance to test with 4 cards: […]
I tested 4 programs
Direct X
OpenGL
Thank you for your testings! All Quake results are way lower than expected, but then i saw that you use 800 x 600 and 1024 x 768 resolutions.
I have not tested Quake2 or Quake3 higher than 640x480 and all Rage2 cards cant use OpenGL for Win9x.
Even 3DMark scores are bit low, i have tested only 3D Mark 99 Max, i can comment about that at the moment.
My AMD K6II+400 3DMark99@800x600x16 with Rage XL AGP 8MB about 1350 up to 1375 points (all default).
What results you get with 640x480x16 res with Quake2 timedemo 1 and Quake3 640x480x16 if you can try it?
I will test the results with Rage Pro 8MB AGP card with K6-II+, just wait. 😀
Added one old info about monitor refresh rate, 85hz seems to be best for Rage Pro.
For testing i use Default settings,just my Fast or Max OpenGL settings for Rage Pro.
What refresh rate you used for testing?
Thank you!
Reply 43 of 54, by marxveix
Wait a minute, your Rage XL PCI card worked with my drivers, can you test 3DCIF game out?
Sorry for asking, but Catalyst 4.3 are from my point of view for Radeon cards and not Rage?
So RageII+ up to Rage XL works and Original RageII does not work, i have no Rage2, just R2+
Quake 3 maybe likes newer OpenGL more and some games need newer OpenGL, than 1091.
1091 is good for older Quake1 and Quake2, Hexen II (older OpenGL). Try v1073 from olders.
https://www.oocities.org/ziyadhosein/rprow98.htm
I have not tested what best suits for Quake3&newer!
Its easy to change OpenGL version with my OpenGLs
ATi Rage 3GL-Win9x.7z
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … GL-Win9x.7z?w=1
Your Rage XL PCI and AGPs are 32bit lower versions, theres comes the lower score. Usually Rage XL 64bit should be quicker than Rage Pro.
Rage XL AGP 8MB 64bit that i use are with 4 memory chips:
Rage XL AGP 109-66700-01 / Rage XL AGP 109-66700-00
Here are my old Quake2 runs with Quake2 and AMD K6II+400Mhz and 500Mhz / Tweaked and non tweaked
I test them out with Original Rage Pro 8MB AGP as well and Motherboard was MVP3 with 256MB or less Ram.
First OpenGL version that works with SkipFlipWaitIdle is OpenGL 1084, all older versions not gain performance boost from SFWI command. Enable this option only with bilinear disabled + multitexture disabled (both disabled). Quake2 is playable with SkipFlipWaitIdle at the moment.
SkipFlipWaitIdle=1 works, i get 3fps more @ Q2 timedemo 1 demo1.dm2 640x480x16 and also no big keyboard/mouse lag for Quake2 now!
OpenGL 4.11.1091 quick test (does support SkipFlipWaitIdle=1 - enabled @ settings)
~40.5fps without vga overclock and bilinear and multitexture disabled + tweaked Q2 (k6-II+400@500Mhz)
~37.5fps without vga overclock and bilinear and multitexture disabled + original Q2 (k6-II+400@500Mhz)
~35.0fps without any overclock and bilinear and multitexture disabled + tweaked Q2 (k6-II+400)
~33.0fps without any overclock and bilinear and multitexture disabled + original Q2 (k6-II+400)
OpenGL 4.11.1073 quick test (does not support SkipFlipWaitIdle=1 - enabled @ settings)
~37.5fps without vga overclock and bilinear and multitexture disabled + tweaked Q2 (k6-II+400@500Mhz)
~34.7fps without vga overclock and bilinear and multitexture disabled + original Q2 (k6-II+400@500Mhz)
~34,4fps without any overclock and bilinear and multitexture disabled + tweaked Q2 (k6-II+400)
~32,0fps without any overclock and bilinear and multitexture disabled + original Q2 (k6-II+400)
These benchmarks are without sound, i add soon isa or pci soundcard and i make some Quake2 runs again.
Still SFWI is more experimental, Quake1 is not playable and Quake1 has no or minimal gain over OGL 1073.
OpenGL 4.11.1073 works now normally, like others, something with the chipset drivers did not like it sometimes.
Douglar you can try BencMark also with games, just Max and Fast settings are safe to use and try OpenGL v1073!
Quake3 needs more testing,i have tested more Quake1 / Quake2 from my side, my old Q2 result taken form here
Reply 44 of 54, by douglar
marxveix wrote on 2025-10-31, 13:18:
I have the original ATI reference board that works on 5v PCI, not the stripped down knockoffs that don't work with 5v PCI.
Yes, it seemed like your drivers work with my Rage XL PCI card.
Good catch. I made a mistake. While I had Catalyst 4.3 installed for Radeon cards, I had these two installed:
mach64 4.35 drivers (1997/11/21) : https://theretroweb.com/drivers/1089
rage 128 5.14 drivers (1999/2/6) : https://vogonsdrivers.com/getfile.php?fileid=341
What's the best way to verify what driver is currently in use?
What 3DCIF game would you like me to test?
Reply 45 of 54, by marxveix
douglar wrote on 2025-10-31, 17:25:
I have the original ATI reference board that works on 5v PCI, not the stripped down knockoffs that don't work with 5v PCI. Yes, […]
Thank you for the info.
Good to use some ati driver cleaners, but i have countless times sometimes just overwritten drivers, but mostly Rage Pro / XL drivers.
Its good to use clean Win9x install and i have plans to use some image dos tools, i think Symantec Ghost 11.5 is good for Win backups.
Are these Rage XL PCI also 4752 cards? Tomb Raider 1 with ATi patch or Croc 1.0 would be enough with Rage XL PCI.
From Croc 1.0 select Rage II from menu.If menu screen and text is ok and game looks ok, then good news for XL PCI.
Could you make Rage XL PCI bios backup from you card as well, i can send you tools.
Some old info here: Chinese Rage XL PCI mods, improved compatibility and looking for a good overclock.
If possible make some screenshots with Rage XL PCI like i have done with Rage2+ (One post above, before your post)
If 3DCIF works@XLPCI,can i send you 5.40 driver where card info is back (to know model number better with Win9x)
As i member i removed 4752 that is RageXL PCI from 5.40 drivers and latest 5.38 still has it,i can add 4752/4753 back
Even without 3DCIF, my XL PCI card gives black screen@ 5.40 drv, so if the driver works for your LASB41,why not here
Can you give whats written on your Rage XL PCI?
My chinese Rage XL PCI has
Rage XL 215R3LASB41
maybe you have older?
Rage XL 215R3LASB22
From the card pics its Rage XL PCI and 215R3LASB41, like mine.
DXDIAG i have used for checking if card is working and with what driver it uses, if card is there and all ok then 3DCIF.
Reply 47 of 54, by marxveix
douglar wrote on 2025-11-01, 02:29:
Its Rage XL PCI (4752) or ATi Xpert98 PCI (4750) but the 215R3LASB41 chipset is the same like with cheap remade (4752) version
(i dont have your Rage XL PCI card). All 4750 PCI cards should be good for 3DCIF.
I removed 4752 inf from my latest 5.40 driver what you where testing as earlier mentions and my testing with this cut-down and very late (4752) version was not successful with 3DCIF driver.
Oh only now i looked your link more carefully and if its Rage XL PCI (474D) then its should be 3DCIF compatible, like Rage XL AGP (474D) is.
Also inside ATII9XAD.INF i dont have no RageXL PCI with 474D,only AGP cards have 474D.I wait for your DXDIAG screenshot,take your time.
Two Rage XL PCI exist, one with B22 and other B41, my eyes have seen only B41/LASB41/215R3LASB41
ATI RAGE XL PCI (B22)
ATI RAGE XL PCI (B41)
https://itpfdoc.hitachi.co.jp/manuals/3020/30 … 0e/DMRC0169.HTM
Reply 48 of 54, by marxveix
Added some files from before and added some new files for DOS and made one ATiDOS.zip.
If you know some useful Tool for ATi Mach64/Rage23 cards for DOS, let me know and i add.
Reply 49 of 54, by douglar
marxveix wrote on 2025-10-31, 18:00:
I made to copies of the BIOS, one using ATIFLASH 1.0, the other by putting the eeprom in a TL866
Are either of these usable for you?
The attachment Rage XL PCI BIOS.rar is no longer available
Reply 50 of 54, by marxveix
douglar wrote on Yesterday, 22:38:
I made to copies of the BIOS, one using ATIFLASH 1.0, the other by putting the eeprom in a TL866 […]
Thanks for the download, i dont know yet, but they are good at least for the same exact card, that you have.
If you gona try 3DCIF game someday when you have time with XL PCI, overwrite this file with 5.40@install.
This has naming like 5.38 release with more information (4752) or some other, did not add 474D XLPCI yet.
So far i know that 474D is with AGP card, not PCI:
474c Rage XC
474d Rage XL AGP
474e Rage XC AGP
474f Rage XL
4752 Rage XL (so far not so good luck with 3DCIF)
4753 Rage XC (from its number same as XL 4752)
https://ftp.riken.jp/Linux/kernel/v2.3/patch- … ci_pci.ids.html
Reply 51 of 54, by douglar
marxveix wrote on Yesterday, 23:37:
Is that 3DCIF tech demo still available for download on the web ?
Reply 52 of 54, by marxveix
douglar wrote on Today, 00:13:
All ATi 3DCIF Demos are here that i know about with my ATi 3D C InterFace.7z :
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … nterFace.7z?w=1
If ATi Knight demo works well @ XLPCI, then games also probably work ok.
Videos about demo1: https://www.youtube.com/watch?v=Mnahhue0VWs
Videos about demo2: https://www.youtube.com/watch?v=C86fIHU6qro
If you download this, then it has almost all Rage3 stuff i have:
https://hingetee.ee/library/ATi3DRageProSoftwarebundle.7z
Reply 53 of 54, by douglar
I lost a couple hours getting Windows 98 reinstalled on my system. I was trying to figure out if I could avoid using the Promise PCI card. I couldn't. Things would get unusably slow using the onboard IDE with my CF's after the 2nd reboot during the install. Like 100x slower. Next I had a curious episode where the entire windows directory went into lost clusters when I tried installing the Promise driver before the 4in1 driver. I just reinstalled at that point.
Here is the install order that I used:
  1. Scripted install of WIN98se
  2. Installed 4in1 v443 driver
  3. Installed Promise TX2 driver
  4. Installed Rage 5.14.159.0 (4.13.0001.2655 (English))
  5. Installed Direct X 9C
My PCI Rage XL card works OK with the 4.13.0001.2655 driver---
Display Devices
Card name: RAGE XL PCI
Manufacturer: ATI Tech. - Enhanced
Chip type: Mach64: XL/XC
DAC type: Internal
Device Key: Enum\PCI\VEN_1002&DEV_4752&SUBSYS_80081002&REV_27\BUS_00&DEV_11&FUNC_00
Display Memory: 8.0 MB
Current Mode: 800 x 600 (16 bit)(optimal refresh rate)
Monitor: Smart Cable
Monitor Max Res: 1600,1200
Driver Name: ati2drae.drv
Driver Version: 4.13.0001.2655 (English)
DDI Version: 8
Driver Attributes: Final Retail
Driver Date/Size: 11/5/2001 11:26:06, 271952 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: *vdd,*vflatd
Mini VDD: ati2vxae.vxd
Mini VDD Date: , 0 bytes
Device Identifier: {D7B71EE2-0412-11CF-2960-09A085C2C935}
Vendor ID: 0x1002
Device ID: 0x4752
SubSys ID: 0x80081002
Revision ID: 0x0027
Revision ID: 0x0027
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
I didn't realize that your driver was older than my driver. When installing 4.11.0001.2611 driver over the 4.13.0001.2655 drivers, I didn't keep any of the newer files. I ended up with limited functionality.
Display Devices
Card name: ATi 3D Rage II PCI
DAC type: Internal
Display Memory:
Current Mode: 640 x 480 (4 bit)(optimal refresh rate)
Driver Name: ati2ddad.drv
Driver Version: 4.11.0001.2611 (English)
DDI Version:
Driver Date/Size: 9/29/1999 10:01:18, 270720 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: *vdd,*vflatd
Mini VDD: ati2ddad.vxd
Device Identifier: {D7B71EE2-0412-11CF-B273-08A088C2CD35}
Vendor ID: 0x1002
Device ID: 0x4752
Revision ID: 0x0027
Revision ID: 0x0027
Video Accel:
Registry: OK
D3D Status: Not Available
AGP Status: Enabled
Odd that is says AGP Status: Enabled
I'll reinstall windows and try doing a clean install of the 4.11.0001.2611 drivers
Reply 54 of 54, by marxveix
douglar wrote on Today, 00:43:
I lost a couple hours getting Windows 98 reinstalled on my system. I was trying to figure out if I could avoid using the Promis […]
Display Devices
DAC type: Internal
DDI Version: 8
WHQL Logo'd: No
VDD: *vdd,*vflatd
Vendor ID: 0x1002
Device ID: 0x4752
Revision ID: 0x0027
Revision ID: 0x0027
Video Accel:
Registry: OK
D3D Status: Enabled
Display Devices
DAC type: Internal
Display Memory:
DDI Version:
WHQL Logo'd: Yes
VDD: *vdd,*vflatd
Vendor ID: 0x1002
Device ID: 0x4752
Revision ID: 0x0027
Revision ID: 0x0027
Video Accel:
Registry: OK
AGP Status: Enabled
Its the newest that still has CIF, but other than that, its one modded driver.
5.38 release has more changed files than 5.40 release if i am more honest.
To repeat exactly the same situation again can be sometimes not that easy.
You may have experienced similar that i have here with multiple driver install.
Still clean install with one driver i have not managed to have with Rage XL PCI 4752.
Re: Proprietary 3D API's
I can send here driver with Old and New Control Panel working together if someone is intrested, not well working for the 3D part, both ATi Control Panels present.I have made many tests and ATI2DRAB 3DCIF driver is in the making, i just take it easy and like before, 4.11.1xxx has no Rage XL PCI 4752 support.
Take it easy and game some CIF games with AGP card if you want and have fun, dont worry if its not gona work with Rage XL PCI (4752). Its the only card that does not work at the moment, maybe same with Rage XC (4753) that someone dont have. PhilsComputerLab and Gona have tested it, i have tested it, all is good. Most Demos i can get to work with Rage XL PCI 4752 and thats it. Of course D3D and OpenGL also works, but not all 3DCIF games and no Knight demo so far.
If someone with more experieneced at hexedit could help, i can point what is needed to change in some of the newer driver files. File names are different lenght inside dll, that maybe easier part for someone and so far i have edited names only with the same lenght. Other and bigger part that is missing from newer driver is atid16ab.dll or atid16ae.dll files and missing atid16ab.dll or atid16ae.dll names from inside some driver files.
When someone wants to know when my ati driver making started,
then read from here and continue reading below with other pages:
Started collecting drivers and OpenGL files even before that time.
Takedasun has better ATi drivers collection and i use his site a lot.
