Estel Randir wrote on Today, 04:23:
Interestingly, getting shaders working for DOSBox-X and Staging was the very first thing I did for DFendX, and was actually the motivation for starting the project in the first place. Would love to hear your feedback how it works for you!
[/quote]
I downloaded it, configured options, added a few games. Works just like Defend Reloaded did, so no surprises. Game pathing, Midi setup, etc all good and easier than other modern managers. Dosbox-x seems to be working great. Shaders work . I even added my own tweaked shader to dosbox-x directory and the drop down in the profile window picked it up as an option - that is really good. It is so much better to have them as a dropdown and not have to navigate to a path. I really don't care for the other dosbox versions. So I am good. All my hard drives (lap;top) are super fast M.2 drives. And for some reason there is a long pause in both Defend Reloaded & DefendX when opening a profile. Is there a way to optimize this? Also, I am super happy the font customization on all but the profile screens is still a feature. I run 4k monitors now.
Features / suggestions:
1) I know you can customize panel colors (to an extent) but Is it too much trouble to add customizable themes? Maybe the ability to choose a custom color in the existing system. I actually use Win 11 dark mode on many applications and it works nicely.
2) Resizable profile windows
3) Along with 2) maybe the ability to customize the font in the profile window? Windows 10 / 11 do a horrible job. No matter what you do many of the "sub windows" like the profile window are scaled to some preset scale by Windows. The text in the profile window is getting hard to read.
4) Someone already said icon view. ScummVM did this a few years ago. Seems to be all the rage with things like Launcbox, Duckstation, etc. There are a lot of nice fanmade icon covers for dos games now.
5) It is not my thing, but maybe a mobygames info lookup?
Good job making the old tride and true Defend work with modern dosbox versions. Keep up the good work.
[/quote]
Thanks for the feedback, and glad it worked well for you for the most part. Font/themes are not something I have explored yet, and the general performance of opening profiles is something I have looked at, but is largely a carry over from the way Reloaded was designed. It would require a major rewrite of the conf handling which I may get to some day, but probably not soon. Mobygames used to be a data-source, but as they are paywalled now, I can't even test against their API without subscribing, so it got replaced with TheGamesDB.
However, there is one thing you should be able to try today - the Icon View. That is already there, under View, along with Screenshots. I think they give you the view you are looking for.
And it's good that the shader combos picked up your custom shader - I spent a bit of time matching the way dosbox X/staging look up shaders from various paths so the combo would contain all possible shaders dosbox would see, so its nice to hear it worked!
Cheers!
