First post, by HK-47
I recently got a PCIE X-Fi Titanium (SB0880), which I was planning to use for my XP rig. However, I'm unable to get it working in XP.
Looking into it further, it seems to have incorrect device ID:
VEN_1102&DEV_000D&SUBSYS_1102044
I've tried modifying driver INFs to force the drivers to install (see attached file, I added a ".txt" extension as I coulnd't attach it otherwise) with both the official 2.17 and the lastest Daniel_K drivers. While they installed successfully, I get a "device cannot start" error in Device Manager.
What's weird though is that in Linux, it's correctly identified (vendor ID 1102, device ID 000B) and seems to work perfectly.
