First post, by HK-47
I recently got a PCIE X-Fi Titanium (SB0880), which I was planning to use for my XP rig. However, I'm unable to get it working in XP.
Looking into it further, it seems to have incorrect device ID:
VEN_1102&DEV_000D&SUBSYS_1102044
I've tried modifying driver INFs to force the drivers to install (see attached file, I added a ".txt" extension as I coulnd't attach it otherwise) with both the official 2.17 and the lastest Daniel_K drivers. While they installed successfully, I get a "device cannot start" error in Device Manager.
What's weird though is that in Linux, it's correctly identified (vendor ID 1102, device ID 000B) and seems to work perfectly.
Reply 2 of 9, by HK-47
Thanks! That does look very similar to the issue I'm having. I'm a bit confused about what what they mean by "moving a resistor" to enable in-place programming via a clip though. Do I need to move R247 to the R246 spot, then (maybe install a header on and) short out JP1?
Reply 3 of 9, by HK-47
HK-47 wrote on 2026-10-30, 06:13:
And looking at it again, I'm not sure if this is even needed. The 24C32 datasheet says the WP pin needs to be pulled high to enable write protect, and it also allows writes if left floating. By default, at least based on the images in that thread, the WP pin is just connected to a resistor and then to ground, so maybe it might work as is?
Reply 4 of 9, by ott
I considered this method (via clip) for dumping my Audigy 2 ZS card, but I haven’t tried it.
Most guides state that you need to desolder the EEPROM chip to reflash it using programmer, so that’s what I would do if the EEPROM got corrupted.
It’s easier to desolder one chip than to move bunch of other components just to unlock write access.
Reply 5 of 9, by HK-47
Reading through that thread again, it seems like moving around the components is needed to enable write protect, which does line up with what I understand from the datasheet. I ordered a programmer which I should receive tomorrow, so I'll at least give programming in-place a shot first. If it doesn't work then then I'll probably have to find someone locally to do the de/resoldering, as I could barely do a passable job soldering through-hole components. My hands are way too shaky for tiny, surface-mount stuff.
Reply 6 of 9, by HK-47
The CH341a programmer arrived, and after some finagling (the clip placement was very finnicky) I was able to successfully reprogram it in-circuit. I used the SB0880 bin file from the other thread, using IMSProg in Linux. The driver installers detect the card properly now, and the device ID changes from 000D to 000B once the driver is installed (at least with Daniel K).
The problem is, it still doesn't work. The official drivers still trigger a BSOD and reboot. The Daniel K driver installs, but I still get a "device cannot start" error. Not sure what else to try at this point. I guess the card is just defective.
Reply 7 of 9, by ott
HK-47 wrote on 2026-10-31, 11:28:
Thanks for sharing your experience. It’s great that method using clip worked for flashing EEPROM.
Have you tried installing the official driver on a clean Windows XP? After using Daniel’s driver, I also ran into issues when trying to install the official driver for Audigy 2 ZS. I had to reinstall Windows, and after that, the driver installed just fine.
Does the card still work in Linux?
Reply 8 of 9, by HK-47
It does still work in Linux.
I also tried on a fresh Windows install (after installing all the chipset, etc. drivers except for video and audio), but still no dice unfortunately. What I found intereseting is that if I disable the HDMI audio device of my graphics card (AMD R280X, Vendor ID 1002, Device ID AAA0), the official driver installer actually finishes installation without causing a BSOD/reboot. However, not matter what I do the AMD HDMI audio device automatically re-enables after a reboot. So the official X-Fi driver installer runs, asks for a reboot, but upon rebooting the HDMI audio is automatically re-enabled, and the X-Fi driver installation fails. This happens whether I have the AMD HDMI audio drivers installed or not. I don't have any other XP-compatible GPU to test with at the moment, but right now I suspect that Creative drivers might just not like the AMD HDMI audio for some reason.
Reply 9 of 9, by HK-47
So I picked up another X-Fi Titanium (also an SB0880), and I was able to install the official drivers and get it working without any issues. Looks like the other one was really just broken in some weird way.
